Error code P0442 - Mustang Evolution
Old 03-21-2015, 05:58 PM   #1
Kstangs2002's Avatar
Error code P0442
So my check engine light came on and marks check fuel fill inlet the guys at autozone said thats its probably not sealing right air is coming in at the fuel inlet how can i fix this
Kstangs2002 is offline   Reply With Quote
Old 03-21-2015, 05:59 PM   #2
This is what i got Click image for larger version
Name:	ImageUploadedByMustang Evolution1426982343.643876.jpg
Old 03-21-2015, 07:54 PM   #3
oxford5pointoh's Avatar
Well there is a rubber gasket that's on the fuel door itself. Is yours jacked up?
Old 03-22-2015, 11:14 AM   #4
There's a funnel in the trunk. Use that to work the little door down the tube a bit and see if it goes away. Also check the overflow line on the filler tube isn't blocked or burnt on the exhaust. I quick look from under the left rear quarter panel should let you know.
Old 03-22-2015, 06:38 PM   #5
Thanks cleaned it and removed the negetive cable from the battery for 2 min so far so good ☝️👌👍
Error Code P0411 Shahrum Pre-2005 V6 Mustang 33 06-29-2016 06:59 AM
CEL p0442 bsyo1021 2011-2014 Mustang GT 3 06-21-2014 12:42 AM
99-04 Fuel Solenoid having trouble with fuel dtc p0442 Ford_guy1984 1996-2004 Mustang GT 0 11-11-2013 06:22 PM
CEL and code P0442 TwoSeveN 2005-2010 V6 Mustang 6 08-16-2011 08:15 PM
P0442 and P0456PD CEL OsirisGuy 1996-2004 Mustang GT 4 09-01-2009 11:57 AM
10:21 PM
