Oil change - Mustang Evolution
Old 03-25-2015, 09:53 PM   #1
stangz13's Avatar
Oil change
I'm going to be taking my car in for an oil change. Should I take it to the dealership or use the same shop that I've been using with all my other vehicles in the past (never had an issue with the shop).
Information on my car that might help with suggestions for my next couple of questions. It's a 2013 GT, auto with 23-24k miles on it and is my dd. Performance wise (if it makes much of a difference) it just has rousch axel backs, airaid CAI, and a boss IM.
What are some of the best brand and weights that I should consider? Should I ask the shop to do anything specific? Also should I have any additives mixed in with the oil?
Thanks in advance for any suggestions and advice that's given.
13 GT Fully loaded glass roof Airaid CAI, Boss 302 intake, Eibach Pro System Plus, Roush Axle Back Exhaust
stangz13 is offline   Reply With Quote
Old 03-25-2015, 09:58 PM   #2
Black8thElement's Avatar
Royal purple is my choice
Black 2008 Decepticon GT "If it ain't hooking, it ain't booking" edition
Black8thElement is offline   Reply With Quote
Old 03-25-2015, 10:05 PM   #3
christianh's Avatar
There are some good threads on this, but generally it seems keeping motorcraft oil in there is good, but also Royal Purple. You should check with your local shop if they carry it. I just take mine to the dealership so you know it's done properly
christianh is offline   Reply With Quote
Old 03-26-2015, 07:40 AM   #4
Region: Nebraska
Reply to stangs13: If you look at the additives in an oil , you will have several choices that will serve your engine well. Of course Royal Purple is a good choice. Also, ( considering price without sacrificing quality) , Mobil 1 Extended Performance is an excellent choice. Valvoline and Pennzoil also have good products in their line up. The most important factor is go strictly FULL SYNTHETIC !!!
The Grey Ghost is offline   Reply With Quote
Old 03-26-2015, 07:49 AM   #5
Waylap1's Avatar
Region: New Hampshire
A lot of people here have run the recommended Motorcraft synthetic blend and then had analysis on it and say it's just fine and actually an excellent choice. I would tend to agree with them but there's the very legitimate placebo effect of running more expensive fancy full synthetic stuff.
If putting in *higher quality stuff makes you genuinely feel like your Mustang is safer, then it's worth it to YOU. It will mean a better driving experience (mentally) which is nothing to laugh about....
I do run Mobil 1 full synth mainly for that reason. I know the cheaper Motorcraft synth blend would prolly be just fine but....
Same with additives. I don't use any but in the past, I used Duralube or whatever because...it made me FEEL like my car was being super protected. I have since found different non car related things to splurge my money on like putting it aside in a savings account. THAT gives me more peace of mind and feels safe to me.
I run Motorcraft only filters (they're actually excellent) *for now. Because.....warranty and the tendency for dealership assholishness.
After warranty, I'll run whatever comparable quality filter makes me feel good....except Fram.
*At 44 years old now, I have had two dozen different cars. Some I did the basic and simple preventative maintenance on and others I went overboard with expensive (high quality) stuff.
NONE of my cars blew up or had motor problems or otherwise gave me issues that would have been related to oil or oil filters. Sooooo some of those cars,i wasted money on expensive purple crap. But not really because in MY head, it ran better and drove better. And in the end, that's what makes your driving experience even better.
Waylap1 is offline   Reply With Quote
Old 03-26-2015, 08:11 AM   #6
Grabber Blue5.0's Avatar
Mobil 1 is a base 3 oil so calling it fully synthetic is a stretch.
Old 03-26-2015, 08:20 AM   #7
c_rizzle's Avatar
Since your car is fairly new & I assume under warranty still. I would get most of my maintenance work done at your preferred Ford dealership, so in case you have any warranty issues they'll see you have a service record with them. That you're a loyal customer, etc... and are more likely to help you out when/if they can. Also, often times when you go in for an oil change, etc.. there might be TSB/Recall work that they can do while you're in there. Or update your Sync software at your request, etc.
c_rizzle is offline   Reply With Quote
Old 03-26-2015, 08:28 AM   #8
Region: Nevada
I run Motorcraft 5W-20 semi synthetic in my street (not track) application ‘14 GT and have it checked with used oil analysis.
Name:	03-25-2015 01;35;51PM - smaller Copy - Copy.JPG
2014 SGM GT, 300A base coupe, 6R80, daily driver.
silverstate777 is offline   Reply With Quote
Old 03-26-2015, 08:52 AM   #9
Waylap1's Avatar
Those numbers and comments from Blackstone look good! They also say that you added a supercharger? And recommend going to 7k miles next time? Sounds like Motorcraft Synth blend is just fine and saves money and is what Ford says to use.
Grabber...what is base 3 oil and which full synth is not that and why?
Old 03-26-2015, 09:10 AM   #10
Don't assume just because it's a synthetic it's going to be better. Back in the day I was a big fan of Mobil 1 and used it in all of my vehicles. I bought a new 98 chevy truck with the 5.7L. I ran the truck on conventional oil for about the first 10,000 miles and then switched over to Mobil 1.
I kept oil change intervals to every 3,000 miles like the manual called for while under warranty. After my truck went out of warranty at around 30,000 miles, I extended my interval to 5,000 miles on the Mobil 1 and then had an oil analysis done.
Analysis came back with high wear rates in several of the categories and the lab recommended going back to 3,000 miles oil changes. I did go back to 3,000 mile changes and continued to have oil analysis done with results that I was not happy with. I ended up going back to a Chevron conventional oil and my oil analysis results got better and the lab recommended trying 4,000 mile intervals with it.
My point is that Mobil 1 was touted as the best oil out there at the time. My analysis results along with the engine being more noisy and using more oil with Mobil 1 showed me that for my application, it was not the best. I was not getting my money's worth. I also got pretty much the same results and recommendation for my ex-wife's 98 Grand Prix GT at the time.
This is why even though I know the oils have improved since the early 2000's when I ran Mobil 1, I won't use Mobil 1 again. I still see oil analysis results on Mobil1 over on the bobistheoilguy website that don't impress me.
That is why I hate hearing people blindly recommend a synthetic just because it's a synthetic. Sometimes synthetics don't work as well in certain applications as well as a regular conventional might.
Wayne
2014 GT/automatic/Sterling Gray Metallic/GT500AB/GT500 OTA pipes/Bob's oil catch can/Ford aluminum finned diff cover. Ford STB.
70monte is offline   Reply With Quote
Old 03-26-2015, 09:14 AM   #11
Region: Nevada
Yes, I added a Roush phase 1 supercharger kit after a 1,000 mile (naturally aspirated) break in period. The factory fill oil was changed at 3,500 miles and tested. I’ve since upgraded to the Roush phase 2 supercharger which is what the second sample report reflects. I'll run the fresh 5W-20 oil change to 7,000 miles and submit another sample.
Old 03-26-2015, 09:38 AM   #12
SK GT's Avatar
I know not everyone likes mobil 1 but they have a pretty good deal going right now until May I believe.
They send you a rebate for 12 dollars off a 5 quart jug of full synthetic, limit 2 per household. Most retailers are honoring the program. I did mine at walmart. Did the 5-20w for mine. They were about 25 dollars each before rebate.
Grabbed 2 additional 5-30w jugs for my wife's G37. Did the rebates through a family member for these. Thats 2 oil changes in her car, damn our 8+ quarts.
SK GT is offline   Reply With Quote
Old 03-26-2015, 04:33 PM   #13
Amsoil and Redline are the only true full synthetics that are a Group IV left on the market. All the rest are a Group III hydrocracked petroleum based oil. That includes Mobil 1 and Royal Purple among others.
Old 03-26-2015, 05:34 PM   #14
Waylap1's Avatar
I never knew that until now. I also did some research online today and see what you're talking about. It's a shame those two brands aren't more easily available in local stores.
Old 03-26-2015, 05:44 PM   #15
There's a reason Amsoil will never sell out to the likes of Walmart.
Old 03-26-2015, 05:59 PM   #16
phatspeed7x's Avatar
I'm going to run Mobil 1 my next oil chance. Been running it for years. Never had an issue.
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 03-26-2015, 06:31 PM   #17
Grabber, I was just getting ready to say the same thing. Royal Purple use to be a group IV, but not anymore. I prefer Amsoil in my cars.
litfuse is offline   Reply With Quote
Old 03-26-2015, 06:33 PM   #18
You also own a 2004 so that has nothing to do with what we're discussing here.
Old 03-26-2015, 06:34 PM   #19
Yep, they have sold out as well.
Old 03-26-2015, 06:38 PM   #20
Rapinator126's Avatar
Royal purple is the only one who makes a oil thay can withstand e85 as of right now though. It's there xpr line. $20 a quart but it makes a difference.
Old 03-26-2015, 07:01 PM   #21
Waylap1's Avatar
I wouldn't put E85 in my worst enemies car! How does motor oil care what fuel you use? I mean....they're not supposed to mix in the crankcase right? Or am I doing this wrong?
Old 03-26-2015, 07:08 PM   #22
Well you obviously have no clue what your talking about.
Old 03-26-2015, 07:29 PM   #23
Waylap1's Avatar
I don't know much about oil and fuel mixing but I know I drove Ford test cars on E85 and they were destroyed within 6 months. The E85 ate every component like acid. It wasn't developed for performance but because government forcing renewable energy vehicles.
Old 03-26-2015, 07:34 PM   #24
Exactly. It breaks down oil extremely fast due to the alcohol in it.
It wasn't developed for performance, but is the best bang for the buck. 105 octane makes a hell of a difference with the timing you can add. It's been the only fuel running through my car since the built motor
Old 03-26-2015, 08:58 PM   #25
SK GT's Avatar
A lot of high horsepower vette builds run e85, especially boosted cars.
Old 03-26-2015, 08:59 PM   #26
2011 Kona Blue's Avatar
Gonna have to disagree with you there sir. Mobil.1 Extended Performance is a true base IV synthetic! That's different than regular Mobil 1.
Since when is Royal Purple no longer a Base IV synthetic oil?
Sent from my SCH-I535 using Mustang Evolution mobile app
Old 03-26-2015, 09:24 PM   #27
Everyone runs e85.
Old 03-26-2015, 09:29 PM   #28
natestang07's Avatar
Originally Posted by Rapinator126 View Post
Everyone runs e85.
It would be nice to have it available
Old 03-26-2015, 09:49 PM   #29
Waylap1's Avatar
Well after checking prices for Amway oil and Redline, I've decided I feel just fine running Mobil 1 on sale. My opinion...it's not even necessary but I feel like I'm treating my car better. I'll spend a few extra dollars but I'm sure not going to spend $75 just on 8 qts of oil.
Some people keep their cars forever and that sort of thing may give piece of mind. I typically don't and I'll do great preventative maintenance but not go extremes.
This thread sounds like people talking about fine wines.....they all make you drunk and taste the same after the first 6 glasses.
Old 03-26-2015, 10:44 PM   #30
WhiteCali5oh's Avatar
Region: West Virgina
No kidding. Closest e85 here is 2 hours from my house.
WhiteCali5oh is offline   Reply With Quote
Old 03-26-2015, 11:00 PM   #31
Stang_u_14's Avatar
did that void any of your warranties by the boss intake
Stang_u_14 is offline   Reply With Quote
Old 03-26-2015, 11:51 PM   #32
Waylap1's Avatar
Ummmmm.....what? I missed the part about Boss intakes..
Try putting down this intake
Old 03-27-2015, 12:01 AM   #33
Ha ha ha
Old 03-27-2015, 04:29 AM   #34
New study from Amsoil
Old 03-27-2015, 05:35 AM   #35
OX1
That's good info if true since I think it is the same price, right?
Any good links that talk about it, just like to read more.
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is online now   Reply With Quote
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Oil Change problems 94sexystang Pre-2005 V6 Mustang 20 09-30-2003 10:14 PM
11:07 AM
