Roush AB previous posts error - Mustang Evolution
Old 04-01-2015, 08:15 AM   #1
Waylap1's Avatar
Region: New Hampshire
I've previously posted comments regarding a 2011 GT that I used to own (used) which had Roush axle backs.
I was evidently making assumptions about the setup I had and commented that Roush axle backs drone pretty bad and sound like nascar. This in my opinion now is incorrect.
I had assumed my 11GT had the Roush AB and still had factory resonators.
I now have a 14 GT with Roush AB and it has factory resonators in place. It does not drone whatsoever, sounds pretty sweet and is a nice setup.(maybe even not loud enough)
On my 11GT, I most likely had Roush AB with resonator delete or some type of x pipe etc. (Maybe even cat delete, idk, they did pass it on state inspection though) The 11 was loud on cold startup and revs. Also, if you got on it, it did sound like a nascar and was clearly loud even a mile away! Very loud! But also an incredible and mean sounding GT. If you babied it, it was milder but I mean you really had to go easy.
so there you have it, I was incorrect for sure and posted comments based on me not knowing what I was talking about And not knowing for certain how my 11 was set up.
now, does anyone have suggestions for making it loud like that again BUT being able to easily go back to having resonators for inspection time? Something I can switch myself in the garage without a welder?
Waylap1 is offline   Reply With Quote
Old 04-01-2015, 08:27 AM   #2
Resonators shouldn't matter at all during inspection.
Old 04-01-2015, 09:32 AM   #3
oxford5pointoh's Avatar
I second this. They probably have no clue they would even be there. But if your concern is that they wouldn't pass it because it was loud then I get that. But you could always throw stock mufflers on before an inspection. It's an easy swap.
If you really have your heart set on being able to swap the resonators in and out you could always have an exhaust shop weld in some connectors and make you a straight through pipe section the same length as the resonator so you can bolt it in and out. But then you get the headache of getting exhaust leaks ect. Seems like more trouble then it's worth.
Old 04-01-2015, 09:37 AM   #4
Get OTA pipes. Borla and Lethal Performance make some. No resonators.
Old 04-01-2015, 05:29 PM   #5
Famine's Avatar
Region: South Dakota
I think they sound great with longtubes and retaining the resonators.
Famine is offline   Reply With Quote
My previous '92 is getting further and further from home.. MonteCitan The Bar 2 01-24-2010 04:29 PM
Follow up on my previous post dch61407 1996-2004 Mustang GT 2 01-22-2008 10:04 PM
Changed up two of my previous songs sonic04edge The Bar 0 11-17-2007 06:10 AM
Previous Owner going back to the Stang belmor2 The Bar 10 07-13-2004 03:45 PM
08:06 PM
