replacing rear axle bearings? - Mustang Evolution
Old 04-03-2015, 03:56 PM   #1
I'm getting a fairly loud howling from my right rear wheel, gets louder with speed, I have been told it sounds like a axle/wheel bearing. I know the parts are cheap, how hard is this to do? Any links to videos or articles ?
rwheels is offline   Reply With Quote
Old 04-03-2015, 04:11 PM   #2
yellowconve's Avatar
my car has been whining at low speeds from about the same area mentioned does urs make a whining sound? i was told i might need a lubricant additive added to my cars rear end lol that sounds funny
0-100 REAL QUICK!!!
yellowconve is offline   Reply With Quote
Old 04-03-2015, 04:14 PM   #3
Grabber Blue5.0's Avatar
Make sure your axle isn't bent.
Old 04-03-2015, 04:14 PM   #4
no more of a howling, but i do have the motorcraft friction additive in already
Old 04-03-2015, 04:17 PM   #5
It's messy but straightforward.
Drain the axle
pull off the brake calipers and hang em
pull the differential cross pin
push the axles in a touch and remove the c clips
pull the axles and there be the bearings.
install is reverse
fill with diff lube of your choice and friction modifier for the diff plates.
That's about it; pretty standard stuff for all stick axles of this type.
Old 04-03-2015, 04:21 PM   #6
Drain the axle
install is reverse
perfect, thanks! sounds simple and i like learning and doing new things with my car, although it does make me nervous to remove axles and get into the rearend. any special tools or presses needed?
Old 04-03-2015, 04:26 PM   #7
that was my case but even after ford fixed it it still seems to whine at low turning speeds i bent the axle but replaced it why is it whining could i of messed somthing else up cause runs fine at any speeds over 5mph without making noise?
0-100 REAL QUICK!!!
Old 04-03-2015, 05:28 PM   #8
Negative. Commonplace tools only. A good socket set primarily. Would be nice to have a cheap suction gun (any parts store, about $5) to fill the rear axle.
Old 04-03-2015, 05:29 PM   #9
whining at low speed while turning could be the differential. Maybe want to add a bit more friction modifier.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 04:16 PM
Supercharging and replacing rear axle and gears for my mustang 2008 bmx_20055 Pre-2005 V6 Mustang 25 02-07-2009 09:06 AM
bearings/ball joints in the rear tigerfan2771 Pre-2005 V6 Mustang 5 08-06-2008 07:19 AM
Wheel Bearings? Thomas91169 Mustang Wheels & Tires 6 09-06-2006 12:11 AM
02:33 AM
