Shifter bracket for 6 speed manual - Mustang Evolution
Old 04-06-2015, 12:08 PM   #1
I have a 2011 Mustang GT 5.0L with 6 speed manual transmission.
The shifting from 2 to 3, 3 to 4, 4 to 5 is kind of sloppy (missing the gears sometimes if I shift fast.
Went to the AM web site and found replacement shifter brackets since I was told that replacing the stock bracket would help the "sloppy feel" shifting. Looked at the Barton Shifter bracket for $64.99, the Barton 2 post shifter bracket for $104.99 and the Steeda shifter bracket for $79.99 with 2 bushings included ( the black one for racing, the red one for street driving) the black one is a harder durometer then the red one. Since I'm not going to race or drag, I thought the red one would be fine if I go with the Steeda. I picked the Steeda because the 2 choices in bushings. Also, I can keep my stock shifter too.
Any comments/suggestions would be greatly appreciated.
jgreen523 is offline   Reply With Quote
Old 04-06-2015, 12:23 PM   #2
Your choice is fine if you are sticking with stock. I use the red bushing in racing applications all the time and ther are no issues. There is little to no NVH problems with it on red but black is noticeably louder and more vibey.
I also have a modern billet knob, whiteline bushing insert, MGW shifter arm bushing. All of these helped the shifter a bit at a time and were cheap.
Old 04-06-2015, 01:24 PM   #3
Thank you for your quick reply. I think I'm going to use the red bushing myself. I never did any installation like this before. Other then having a lift, any installation issues should I be aware of or would I be better off having my mechanic who takes care of my other sedan do the installation ??
Old 04-06-2015, 01:31 PM   #4
Goose's Avatar
I installed my MGW on jack stands and that wasn't too bad. I'm sure you can do it. It's just two bolts for the bushing. Spray it with wd40. That should make it easier
Goose is offline   Reply With Quote
Old 04-06-2015, 07:32 PM   #5
You may find it pretty tight in there. I needed to gently file a little off one edge of the bracket to get it slide up the drive shaft and onto the studs. Alternatively you could loosen the crossmember bolts a touch
Old 04-06-2015, 07:55 PM   #6
20bmr14's Avatar
hopefully, like it did, you wont like it so much that you say to yourself....self, I should have just got the Barton w/bracket. I dont drag race my car either but love to drive and the red and or black bushing made a diff but not enough to really enjoy shifting.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 04-07-2015, 12:58 PM   #7
MGW race spec and be done!!!!!
Teak 14 is offline   Reply With Quote
Old 04-07-2015, 01:09 PM   #8
scott_0's Avatar
this/
Old 04-09-2015, 03:20 AM   #9
It was recommended to me to just buy the bracket and see if this helps alone. Apparently most people are happy with just the red bracket.
It didn't do enough for me. Still have the uneven feel into 2nd. I know its still cold in the mornings but I'm thinking I should have just shelled out the $$ and got the MGW full package.
davesnothere is offline   Reply With Quote
Old 04-10-2015, 12:04 AM   #10
Thanks to all the replies, I am getting the Steeda and putting the red thing.
47297 is offline   Reply With Quote
Old 04-11-2015, 09:50 AM   #11
me too............
Barton shifter bracket with stock shifter 2011 2011 2011-2014 Mustang GT 5 03-11-2013 07:48 AM
Barton 2 Post Bracket vs Standard Barton Bracket SilverBullet12 2011-2014 Mustang GT 8 08-23-2012 09:43 AM
Barton Industries shifter Bracket FXDWG11bm 2011-2014 Mustang GT 12 02-24-2012 05:28 AM
(Rear Deck Tweeter Bracket) Mach 460 Tweeter Pod (Custom Bracket) HGFoxfire Mustang Audio & Video 3 04-14-2010 09:45 AM
06:48 PM
