My Suspension Build Thread - Mustang Evolution
Old 04-07-2015, 04:38 PM   #1
So I finally started my first step today by putting my BMR LCA's on. At the end I realized I left the relocation brackets upstairs...guess I'll be doing those on Friday (had planned on doing the UCA). Anyway, here we go.
All the parts:
Name:	ImageUploadedByMustang Evolution1428445699.344676.jpg
Put the rear up on ramps, blocked the front tires and released the parking break. Supported the left side of axle with a jack.
Stockers:
Name:	ImageUploadedByMustang Evolution1428445725.375298.jpg
Was a pain getting the parking cable on/off
Name:	ImageUploadedByMustang Evolution1428445838.095142.jpg
While I was under I noticed my axle vent was leaking like crazy, going in Friday for that.
Name:	ImageUploadedByMustang Evolution1428445892.239375.jpg
Parking cable off
Name:	ImageUploadedByMustang Evolution1428445943.732006.jpg
First arm off
Name:	ImageUploadedByMustang Evolution1428445966.026581.jpg
Time for new parts!
Name:	ImageUploadedByMustang Evolution1428445985.934474.jpg
I tried for a good 45 to get this bolt back in the hole. Found out all I needed to do was lower the jack about an inch...
Name:	ImageUploadedByMustang Evolution1428446021.869070.jpg
New arm installed!
Name:	ImageUploadedByMustang Evolution1428446076.196868.jpg
Parking break put back on and zip tied to the LCA.
Name:	ImageUploadedByMustang Evolution1428446102.493039.jpg
About to be greased.
Name:	ImageUploadedByMustang Evolution1428446134.692432.jpg
Other side was done in 30 minutes. Left the jack on the driver side axle, didn't need to move it over. Torqued the bolts to 130ft lbs and was good to go!
Name:	ImageUploadedByMustang Evolution1428446220.017144.jpg
Drive it around the block with no squeaks, we will see how she does in the morning.
I plan to do the adjustable UCA next. Anyone have any tips on install?
Old 04-07-2015, 05:16 PM   #2
oxford5pointoh's Avatar
Looking good man!
Old 04-07-2015, 05:46 PM   #3
Famine's Avatar
Region: South Dakota
All I have is lca's right now. I can't wait to get the money for everything else. I had the same install issues.
Famine is offline   Reply With Quote
Old 04-07-2015, 08:02 PM   #4
Yeah, when CJ Pony Parts did it in their YouTube video they make it look so simple. I want to see all of the edits they have to do to make it look so seamless, haha.
Old 04-08-2015, 10:08 PM   #5
Oh2freshstang's Avatar
That UCA can be a PITA but it just takes some patience! I attached my UCA mount to the control arm before putting on the car & I tried to adjust the UCA closest to the OEM one so I wouldn't have to do too much adjusting or at least have a starting point. The less work u have to do in that tight spot the better.
Oh & if ur doing it with hand tools have fun with the bolt under the seat! Haha.
Old 04-09-2015, 04:14 AM   #6
Haha, thanks. Can't wait!
Old 04-09-2015, 05:20 AM   #7
Lorraine's driver
ab_mach1's Avatar
Nice work!
Instagram: @ab_mach1
Old 04-09-2015, 04:25 PM   #8
Good job.
motoreyes is offline   Reply With Quote
Old 04-09-2015, 06:58 PM   #9
Famine's Avatar
Is doing it in that order the best way to do it?
Old 04-09-2015, 08:28 PM   #10
I think I will put my shocks/struts/springs on next. Then I'll get to my panhard and uca soon.
Old 04-10-2015, 04:59 AM   #11
DylanWhisnant's Avatar
The UCA was not near as bad as it seems, just gotta have small hands to get up above the differential
2013 Mustang GT Brembo, BMR LCA with Relo Brackets, UCA with mount, Panhard bar, Ford Racing Trackcal Tune, Borla S Type Catback Exhaust, K and N Air filter, 275 MPSS tires
DylanWhisnant is offline   Reply With Quote
Old 04-10-2015, 01:41 PM   #12
Idk about the best way but for me attaching the UCA to the mount before I put it in seemed way easier then attaching the mount to the car then the UCA to the mount. It's a tight space in there!
Old 04-10-2015, 01:52 PM   #13
You don't know tedious and annoying until you try to take off your driveshaft with a massive torque arm in the way. Geez talk about unnecessary work.
Old 04-10-2015, 07:33 PM   #14
Took a detour and put my roush grille delete on today. I'd like to never have to do that again.
Old 09-09-2015, 07:53 AM   #15
All right guys, finally got a DD so I can revive this thread.
Quick question, when lowering my car do I need to change out the bump stops or anything else?
Primer2tone's suspension build for all you thirsty *****es! primer2tone General Mustang Discussion 127 11-30-2013 10:26 PM
Suspension Build List Slow4V 1996-2004 Mustang GT 0 07-17-2013 07:30 AM
02:58 PM
