HELP! Confused on getting an alignment after dropping car - Mustang Evolution
Old 04-09-2015, 06:53 PM   #1
DylanWhisnant's Avatar
So I plan on purchasing The Ford Racing Adjustable handling pack for my 2013 mustang GT. I asked ford racing and they said take it to the dealer and they will get everything put back into Boss alignment (which I wanted). I would've figured I would need camber plates or camber bolts but am not sure. According to them I don't. If a camber plate was needed I was considering purchasing the Steeda HD Strut mounts but wasn't sure which to buy the 11-14 (which is my year car) or 05-10 (which the shock/spring is based off of). Any help appreciated. Car is a DD and autocross/mountain road car.
DylanWhisnant is offline   Reply With Quote
Old 04-09-2015, 06:57 PM   #2
Region: Oregon
That pack is a 1" drop all around so you should not need camber plates or camber bolts. all cars are a little different but it starts to get hairy around the 1.5" mark.
Instafire is offline   Reply With Quote
Old 04-09-2015, 07:49 PM   #3
scott_0's Avatar
-1.5 degrees is within spec so I'm sure you'll be fine, but if you do get camber plates, you'll want the 05-10 pieces since that's what you say the kit struts are based off of
Old 04-09-2015, 07:56 PM   #4
Yeah it comes normally with GT500 strut mounts which I believe means its an 05-10 strut. Also I see you have a good suspension setup, did you need anything to get it back in line?
Old 04-09-2015, 08:09 PM   #5
2014oxstang's Avatar
I'm dropped 1.5" all around with -1.3 camber. No issues whatsoever. Even tire wear.
2014oxstang is offline   Reply With Quote
Old 04-09-2015, 08:23 PM   #6
InfinibandGT's Avatar
I got the ford racing handling package. The suspension guy installing it said he "almost" had it aligned perfectly and recommended the bolts. I went for it. My tires are wearing straight and the car doesn't handle wobbly at high speed anymore, is lowered and dive with braking is eliminated. It's been over a year since I had this suspension upgrade installed.
InfinibandGT is offline   Reply With Quote
Old 04-09-2015, 08:26 PM   #7
olerodder's Avatar
Region: Oregon
Have helped lower 5 late model Mustangs and non of them required camber plates or the useless/dangerous bolts. Yes, -1.5 is the minimum Camber that Ford recommends on their tech sheet.
-1.5 and even -1.6 will be ok, I'm at -1.6 and with the Sportlines and GT500 265's up front and the cornering is nothing short of great. The only issue is that the car doesn't want to drive in the rutted roads, but does like the crowns though.
Old 04-09-2015, 08:38 PM   #8
Damn I should've went wider than 245 up front lol
Old 04-09-2015, 09:00 PM   #9
hobo1's Avatar
I also have that frpp kit. No camber bolts. Alignment within spec and only slight inside wear after 8000 miles. Barely measurable... just a bit visually. Eibach bolts are still sittin in the garage.
A bit of off camber in that direction isnt a bad thing for handling, either
Piloting a '13 GT with track, frpp handling, glass, mgw, bmr and sct
hobo1 is offline   Reply With Quote
Old 04-09-2015, 11:12 PM   #10
Yeah a bit of negative camber definitely helps with handling. Especially for someone who auto x's/road races
Old 04-10-2015, 04:39 AM   #11
Sweet guys I appreciate it. I plan on just piecing together the FRPP adjustable handling pack because I already have a Panhard bar. Just going to buy the Adjustable dampeners, p springs, jounce bumper kit, and Sway bar kit all from ford racing, then put it together myself and save money.
2013 Mustang GT Brembo, BMR LCA with Relo Brackets, UCA with mount, Panhard bar, Ford Racing Trackcal Tune, Borla S Type Catback Exhaust, K and N Air filter, 275 MPSS tires
Old 04-10-2015, 09:15 AM   #12
olerodder's Avatar
Region: Oregon
Depending on your wheel size and offset you could even go a little bigger, 275/40-19's. The track wheels are 19.5" front and although they have 265's on them now I can't wait until they wear down so I can get some 275x40-19's.
Old 04-10-2015, 09:41 AM   #13
scott_0's Avatar
Im using GT500 mounts with the arrows facing IN which reduces the amount of negative camber. fyi you can get away with a good bit of negative camber with no excessive tire wear, its the toe being off that chews up the inside edge
Old 04-10-2015, 05:00 PM   #14
19x8.5 +30. And while it isn't flush, it's pretty close. What do you think I could fit on there? 255-265?
Name:	ImageUploadedByMustang Evolution1428706819.812545.jpg
Old 04-10-2015, 05:01 PM   #15
That's exactly what I did with facing the mounts in. Got back about -.2
Old 04-10-2015, 09:01 PM   #16
olerodder's Avatar
Region: Oregon
Attachment 179682
Since you have a small offset of 30 I'm sure the 265's would fit although they may stick out a little. The 255's would work great and still be within the body. The Shelby wheels are 9.5" wide front and rear although the fronts have 44 offset and rears are 50. I think next time around I'll go with 275's in the front and maybe a little larger in the rear........width anyway.
Old 04-10-2015, 10:06 PM   #17
Dang it should've went 255's lol. Oh well.
Alignment after lowering robin_gt 1996-2004 Mustang GT 10 12-15-2013 10:33 AM
Alignment after lowering my car question Spiney 1996-2004 Mustang GT 11 10-08-2013 06:44 PM
Dropping my car suggestions 2013stang3.7 2011-2014 V6 Mustang 4 07-14-2013 12:19 PM
Do i need a Wheel alignment after installing new wheels Mdazi 2011-2014 Mustang GT 8 05-29-2013 02:50 PM
Same problem after alignment Venomouz831 1996-2004 Mustang GT 46 03-24-2013 07:09 AM
04:30 AM
