Coyote oil leak?? Greasy spot on timing cover. - Mustang Evolution
Old 04-12-2015, 08:43 AM   #1
94gtconvert's Avatar
The other day I was checking my oil level which I usually do once every two weeks. I noticed a wet greasy looking spot on top of the ac compressor on the passenger side of the block, as well as a greasy spot on the timing cover. This is really annoying to me, because one of the reasons I sold my 94 was because it leaked oil from every sealing surface, and I needed a reliable DD. I don't know where to begin with finding the leak, and or repairing it. It's a early build 5.0 may I mind you.
94gtconvert is offline   Reply With Quote
Old 04-12-2015, 09:50 AM   #2
Blogger
99ford's Avatar
Dang! Have you noticed anything on the on the ground? Have you, or someone else recently changed the oil?
Old 04-12-2015, 09:52 AM   #3
No it's not that severe of a leak. And I changed the oil about 3,500 miles ago. I only use mobile 1 synthetic, and the motorcraft filter.
Old 04-12-2015, 10:18 AM   #4
Blogger
99ford's Avatar
What I was thinking was that maybe when you changed it, you got some oil on the timing cover, it can take it a while to show up, but as the engine gets dirty, it can create a grease spot.
Now if it's gotten worse, or larger than it may be something to look into. I'd watch it over the next week and see if it gets worse.
I think it's fine, but that's just my opinion. Let's see what some others have to say.
Old 04-12-2015, 10:19 AM   #5
I don't think I spilled oil down there. Maybe the past owner did. I think I'll degreese it and see If it showes up again
Old 04-12-2015, 10:22 AM   #6
Blogger
99ford's Avatar
Yes do that and if it reappears then it's time to diagnose. The easiest and simplest thing first.
Old 04-12-2015, 02:08 PM   #7
Here's what it looks like
ID:	179814   Click image for larger version
ID:	179816   Click image for larger version
Old 04-12-2015, 10:31 PM   #8
Blogger
99ford's Avatar
Uh yeah there might be a problem there. Dang I was really hoping my theory was correct
Old 04-13-2015, 01:07 PM   #9
rocknbronco's Avatar
Use the Mobil One High Milage Full Synthetic it will work on expanding the seals which may work for your case.
rocknbronco is offline   Reply With Quote
Old 04-13-2015, 06:31 PM   #10
I do remember hearing that Mobil 1 is the worst for leaks. No idea why - but you might try RP or Amsoil instead. The high mileage idea sounds good.
jd864 is offline   Reply With Quote
Old 04-14-2015, 05:13 AM   #11
Ahaaa. I think I may have found the problem! I had a warm day here yesterday and my AC didn't work. I hooked my AC gauges up and what do you know. It has more than enough Freon charge. So I check the fan clutch fuse. BAM! It's blown. That fuse also shares the high rpm pcv valve and the radiator cooling fan which both kicked on when I replaced the 5amp fuse. 5 amp seems a little small to run all those things. But hey, I think it may have fixed all my issues, knock on wood.
Old 04-14-2015, 07:39 AM   #12
Blogger
99ford's Avatar
Cool
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 10:12 AM
found the leak, can timing cover be welded? wootman101 Pre-2005 V6 Mustang 2 12-23-2013 12:41 AM
Timing cover removel Dexter 1979-1995 Mustang GT 3 01-31-2011 10:02 AM
i am looking for a timing cover for a 1994 v6 bearbackcowboy Pre-2005 V6 Mustang 4 08-13-2008 10:34 AM
Timing Cover Gasket Black95GT Pre-2005 V6 Mustang 3 08-20-2003 08:55 PM
02:40 PM
