Ghost Knock - Mustang Evolution
Old 04-14-2015, 01:35 PM   #1
k1DBLITZ's Avatar
Ghost Knock
TL;DR If you have an aftermarket exhaust, make sure those bolt clamps are tight!
I'm convinced I was an unknowing victim of ghost knock.
Several months after my exhaust was installed I developed a really bad rattle. Long story short, I tracked it down to one of the bolts on the X-Pipe clamp that needed to be tightened.
Rattle gone.
However, at some point within the last year I also noticed a "flat spot" had developed. I couldn't pin point exactly when it happened... and it most likely developed gradually. But it seemed like a my low end "ooomph" wasn't there... pretty much anything below 3k RPMS seemed lacking.
Over the months of reading several hundred forum posts, and watching multiple mustang related youtube videos I discovered the existence of Ghost Knock. I didn't really think much of it...until this weekend.
Since I was under the car to install the Cervinis Lower Grille I went ahead and checked all the bolt clamps and gave them a few tugs to make sure they were snug.
To my surprise I noticed an immediate difference in the low end response.
Unfortunately I don't have any logging data to back any of this up, but I know it's not a placebo.. there is a definite difference in how much harder the car pulls now under 3k. The "Flat" spot is gone.
I'm convinced the pipes were causing a rattle or knocking I couldn't hear, which the knock sensor was interpreting as knock and retarding the timing.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 04-20-2015, 08:32 AM   #2
k1DBLITZ's Avatar
Update: So it's been about a week and I"ve noticed 2 things. Gas mileage seems to have gone up approximately 2-3mpg and the surge/bucking while taking off after a cold startup (yes, I give it time to warm up first) has ceased to exist.
Old 04-20-2015, 10:57 AM   #3
c_rizzle's Avatar
Interesting.
That's why I'm pretty meticulous when doing installs. I go back and recheck each bolt when tightening to unspecified specs.
Unless I was using a torque wrench and keeping track of each of them.
c_rizzle is offline   Reply With Quote
Old 06-26-2015, 07:25 AM   #4
k1DBLITZ's Avatar
Video of the rattle:
Old 06-26-2015, 07:58 AM   #5
oxford5pointoh's Avatar
Mine makes a similar noise usually at start up. Sometimes you can hear it when you take off. I also have a magnaflow true x. But I too have checked all my bolts several times and they are tight. I never dropped my cats when I did the install so I know they are tight. But I haven't noticed and performance issues like you mentioned
IG @Oxford5pointoh
SCT tuner and knock and pinging ajpturbo 1996-2004 Mustang GT 10 09-13-2010 07:17 AM
91 tune and engine knock classman Pre-2005 V6 Mustang 0 09-03-2010 12:50 PM
Knock Knock *Language* Brent Pictures and Videos 3 04-03-2008 04:18 PM
Some kind of knock Ibanezplayer272 Pre-2005 V6 Mustang 19 02-02-2007 10:50 PM
95 Mustang GT engine knock 95 GT 1979-1995 Mustang GT 7 09-12-2006 06:30 PM
06:39 AM
