Paint lifting on edge of hood. - Mustang Evolution
Old 04-16-2015, 06:02 PM   #1
partsman68's Avatar
This has to be a warranty issue. Am I wrong?
partsman68 is offline   Reply With Quote
Old 04-16-2015, 07:13 PM   #2
Waylap1's Avatar
Region: New Hampshire
All 2010+ mustangs do this. Warranty depends on your dealer. Some say they won't fix it. Even when they do fix it, it comes back.
Waylap1 is offline   Reply With Quote
Old 04-17-2015, 08:20 AM   #3
That's a ludicrous statement. they don't *all* do this or Ford would be in the grips of a GM-style recall years ago. It happens, yes, to some and yes, take it back to the dealer for remedy, if the car is still in warranty. Expect resistance at the dealer level but be polite and persistent.
I believe the cause is galvanic corrosion at the steel to aluminum interface. I suspect it occurs in places where there might be a little less seam sealer bonding the metals together. Just a theory because I don't have any of this on my 2012 GT.
Old 04-17-2015, 08:46 AM   #4
Region: West Virgina
My '14 has it, Ford is replacing the hood.
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 04-17-2015, 08:49 AM   #5
oxford5pointoh's Avatar
Like actually replacing the hood and repainting it, or repainting your hood you have now?
Old 04-17-2015, 08:54 AM   #6
Replacing the hood entirely. The dealer service adviser told me that the problem would return with the old hood, they only do replacements and it was approved by Ford in a few days.
Old 04-20-2015, 12:16 AM   #7
SK GT's Avatar
Which edge does this usually occur? Gonna check mine out.
SK GT is offline   Reply With Quote
Old 04-20-2015, 12:38 AM   #8
Devil Strider's Avatar
If this happens to mine will they replace my racing strips I put on? I don't have this issue yet but I'd hate to have to deal with them.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 04-20-2015, 08:38 AM   #9
BlackKnight92's Avatar
I have the same issue, except my dealership told me they wont cover it unless the hood actually starts to rust and causes a hole.
2012 Mustang V6
BlackKnight92 is offline   Reply With Quote
Old 04-20-2015, 09:01 AM   #10
iguanaman3's Avatar
Of course a hole will never happen since it is an aluminum hood and can't rust thru. There are 2005 and newer Mustangs all over my area with bare spots on the leading edge of the hood. It may not happen to everyone but every one should check under their hood for bubbles in the paint. My 2012 just developed a few. The corrosion will only grow if the bubble stays sealed from the air. I removed mine and sanded them clean. The bubbles are filled with white powder. If left alone they will grow and eventually move to the top of the hood. You need to look carefully along the edges of the hood on the underside. You can scrape these bubbles off with your fingernail and sand them to the bare aluminum which will never corrode. Mine were all smaller than a quarter.
iguanaman3 is online now   Reply With Quote
Old 04-20-2015, 09:29 AM   #11
Damnit. I believe I have some of those on my hood. On the underside. They will move to the top?
Old 04-20-2015, 09:56 AM   #12
Escalate to Ford. The dealer is playing games with you.
Old 04-20-2015, 10:16 AM   #13
iguanaman3's Avatar
I think they will continue to grow and many people with corrosion on the top stated that they seemed to spread from the bottom. I would not take a chance. Scrape them off now. A few bare spots on the underside are far better than bubbles on the top. It is ironic that bare aluminum will never corrode but under paint it is worse than steel! I will probably touch up my spots after a while.
Old 04-22-2015, 08:21 AM   #14
primemover's Avatar
I wonder if the fact that I'm opticoated that this will help mitigate any possible problems?
primemover is offline   Reply With Quote
Old 04-22-2015, 08:23 AM   #15
I'd say no. It's under everything. Doesn't matter if you gold plate it. If it's under the paint and wants to come out, it's going to come out.
Old 04-23-2015, 02:58 PM   #16
vik912's Avatar
My dealer painted my hood under warranty, no questions asked. As soon as I mentioned it, the service advisor immediately grabbed her camera and went out to take pictures. She said it's very common, but she still has to file a claim with ford and have it approved for warranty (which she claims they always approve).
I have racing stripes that were put on by the dealer, as part of the sale when I bought the car. So my stripes were covered as well. Don't know if it mattered that the stripes came on the car or not, it didn't sound like it mattered.
2013 Mustang GT
Premium, Brembo Brake Package, 6 MT, 3.73 gears
vik912 is offline   Reply With Quote
Old 05-21-2015, 09:35 AM   #17
Sean313's Avatar
Name:	ImageUploadedByMustang Evolution1432222412.268079.jpg
ID:	183054Click image for larger version
Name:	ImageUploadedByMustang Evolution1432222455.570333.jpg
ID:	183055Click image for larger version
Name:	ImageUploadedByMustang Evolution1432222470.271881.jpg
ID:	183056Click image for larger version
Name:	ImageUploadedByMustang Evolution1432222485.496237.jpg
2013 mustang gt hood and trunk lid started to bubble and peel
Sean313 is offline   Reply With Quote
Old 05-22-2015, 03:26 PM   #18
Grimkreg's Avatar
My dealer gave me no issues and explained how common it was as stated above, mine was kind of minor but noticeable on the lip and edge of previous owners terrible stripe thing and it allowed me to get rid of the previous owners horrible taste. They even offered to put my "stripes" back on for free since it was on the car when I purchased it(not even through that same dealer).
Grimkreg is offline   Reply With Quote
Old 05-22-2015, 03:48 PM   #19
Sean313's Avatar
I'm at 39,600 miles had to call ford customer service dealer is not fixing, on Monday I will get a call back from ford to see if they will fix this bull**** problem , they didn't seal their hoods and trunk lids good that's why we have this issue the estimate is about $2000 for mine
Old 05-25-2015, 06:12 AM   #20
Dealer bodyshop did a good job:
Old 05-25-2015, 10:06 AM   #21
Well put me down as a casualty of this as well. I'm heading to ford tomorrow.
Name:	ImageUploadedByMustang Evolution1432570010.553103.jpg
IG @Oxford5pointoh
Old 05-25-2015, 12:30 PM   #22
mav351w's Avatar
I had mine fixed 6 months ago. It didn't come out very well though. There are a lot of fish eyes in the paint and I'm worried it'll just make it worse if I have them do it again.
14' GT Premium
GT500 axle back
AirAid CAI
Lund 93 octane tune
mav351w is offline   Reply With Quote
Old 05-25-2015, 12:36 PM   #23
^damn. Did they replace your hood or just repaint it? Luckily for me white is easier to lay down. They will repaint it until they can get it right. I have no problem calling their asses out. I used to do body work so I have zero tolerance for BS excuses and shortcuts.
IG @Oxford5pointoh
Old 05-25-2015, 11:51 PM   #24
nicholasmadill's Avatar
Happened on my 2011 v6. (Trunk and hood ) and is now starting on the hood of my 2011 5.0 😔
Sent from my iPhone using Mu
nicholasmadill is offline   Reply With Quote
Old 05-26-2015, 07:46 AM   #25
Happened on my 13, dealer repainted no questions asked. That was almost a year ago now, if it comes back I'll push for a new hood.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 05-26-2015, 08:26 AM   #26
I went today and they took pictures and submitted the claim. They said they don't ever replace the part. Just sand the effected area and repaint the entire hood. I'm fine with that. I just don't want bubbles creeping up the hood. Good news is that I will have rock chips repaired and a small dent and some scratches all fixed for free. I just hate leaving my car anywhere. But I already told the service manager I am picky beyond picky, also the car is not to leave the property. I will be taking a picture of the mileage along with programming a mykey that won't allow them to have ANY fun at my expense. Half tempted to leave the hood and take my car home. I just don't trust anyone with my stuff.
IG @Oxford5pointoh
Old 05-26-2015, 10:48 AM   #27
Mlp07's Avatar
IG @Oxford5pointoh
A friend on his way to work he saw my car in front of a house around 5:30am. When I got to work he told me he knew where I lived already since he saw my car in "my house". When we got out of work we went and he told me what house it was, the car wasn't there. I went to pick up my car from the dealer that same day and brought my friend with me and told them about that. He answered "oh there's a car the same as yours, your car hasn't left from the shop". They have cameras there and asked for the recorded videos, but he said they didn't worked. I wished I knew about all those features with mykey and didn't took a pic of my mileage. I knew they were having fun with my car since my mpg dropped from 17- 14.
Mlp07 is offline   Reply With Quote
Old 05-26-2015, 12:06 PM   #28
Yeah they def enjoyed your car. I have worked in shops before. I know what goes on
IG @Oxford5pointoh
Old 05-26-2015, 06:20 PM   #29
BlackBetty2012's Avatar
Region: Rhode Island
I bought mine used, and the dealership wont fix it. I joined a class action law suit against Ford. They need to fix this nonsense...
BlackBetty2012 is offline   Reply With Quote
Old 05-26-2015, 09:18 PM   #30
Mine is also used. Bought off a dealer at 38,000km (24,000 miles). It has the bubbles starting 😢
Old 05-26-2015, 09:39 PM   #31
^^if it's still under 3yrs 36k it should be covered right. Correct me if I'm wrong.
IG @Oxford5pointoh
Old 05-26-2015, 09:45 PM   #32
IG @Oxford5pointoh
Some of this may be under the 5 year unlimited mile corrosion warranty as well.
Old 05-26-2015, 09:50 PM   #33
^ehhh maybe depending on where it is. They sure scrutinized my mileage and we're sure to take pics of my odo for the claim. Guy even asked me before he would even come look at it. He said "what year..again? Hmmm what's the mileage?" And it was in the tone of maybe I won't have to get off my butt right now if it's not going to meet the qualifications
IG @Oxford5pointoh
Old 05-26-2015, 10:00 PM   #34
IG @Oxford5pointoh
Yeah, corrosion warranty is a lot more difficult to actually get a claim under. Most will be the B2B warranty.
Old 05-27-2015, 06:28 PM   #35
mav351w's Avatar
IG @Oxford5pointoh
They just painted it. It took a few days to get the sealant they use so it was almost a week. It looks good from 5 feet away but as you was it or really look at it you can see all the imperfections.
14' GT Premium
GT500 axle back
AirAid CAI
Lund 93 octane tune
Hood lifting at speed Bloodybobber 2005-2010 Mustang GT 27 04-28-2012 12:10 PM
Weight lifting, curling Tbird232ci The Bar 15 04-22-2006 03:33 PM
Yea so v8 owners can be dicks... and someone calls bs on v6 lifting tires Brent The Bar 16 03-23-2005 06:51 PM
lifting a mustang sweet stang94 The Bar 14 07-18-2004 02:21 PM
Weight Lifting Gurus Wanted. ItWouldAppearSo The Bar 16 01-25-2004 11:33 AM
12:40 PM
