sealer in the stock axle back exhaust, is that possible? - Mustang Evolution
Old 04-16-2015, 08:56 PM   #1
alex6es's Avatar
I received yesterday my gt 500 axleback exhaust and today i was in the installation process.Following the instruction (& hundreds of youtube video) i remove the axle back clamps with no problem also the mid pipe was disconnected as well. With everything loose, I wasn't able to removed the mid pipe from the connection between the axle and the mid pipe. looking close to the connection between the pipe and the axle, i saw something that at first look appear to be weld it together. I took my screw driver to clean the rust from it and i notice that what i thought was a welding it is some kind of sealer. Believe or not i wasn't able to take it appart. I was thinking to cut the old axle pipe and work in the mid pipe to remove the old piece of axle pipe connector. Am i in the correct track or are any other way to do it. thanks
alex6es is offline   Reply With Quote
Old 04-16-2015, 09:02 PM   #2
natestang07's Avatar
Not sure if I am understanding this properly or not... Midpipe shouldn't be touched when doing axlebacks and the clamps are tac welded on so it should pop off with a little force...
Let me know if I completely misunderstood or maybe post some pictures
Old 04-16-2015, 09:25 PM   #3
alex6es's Avatar
Sorry first time dealing with the exhaust. In the picture show as part 5A212 is what i call mid pipe.What is inclosed in a red circle highlight in yellow is what i cant take it appart.
Old 04-16-2015, 09:39 PM   #4
Cooolbreeez's Avatar
That should come apart with a little force. Is this a new car or used? Maybe someone traded it in and put some sealer in there to keep it together after taking off aftermarket axle backs. Weird though, you would think if it was sealer it would burn off. What color is it? Could be a high temp gasket sealer.
Cooolbreeez is offline   Reply With Quote
Old 04-16-2015, 09:51 PM   #5
alex6es's Avatar
back in 2013 i got a problem with the exhaust, i could be wrong but i think was a p401 code. i took to the dealer only 18k miles and they fixed. Now im wonder if the dealer put this Black "sealer" or high temperature gasket. This thing is black in color and look like a plastic. Could be a gasket but it is holding the two pipe together like glue and i dont see away to take apart.
Old 04-16-2015, 10:18 PM   #6
Could be something like this
Permatex/Water pump and thermostat RTV silicone gasket 22071 at AutoZone.com
Old 04-17-2015, 10:06 AM   #7
Is the black stuff all the way around the pipe or just in one spot?
Wayne
2014 GT/automatic/Sterling Gray Metallic/GT500AB/GT500 OTA pipes/Bob's oil catch can/Ford aluminum finned diff cover. Ford STB.
70monte is offline   Reply With Quote
Old 04-17-2015, 04:20 PM   #8
alex6es's Avatar
Because the GT is my daily ride , i need to put it back together. I go to give another try tonight. I want to reused the stock axle if it is need it in the future(probably between axle upgrade). I go to take some picture of the black stuff for future reference.
Why seek ye the Living among the Dead?
Lk24:5
Old 04-17-2015, 04:26 PM   #9
olerodder's Avatar
Region: Oregon
I just put my twin tip Shelby mufflers on my 14 today, and there was no type of sealer on the ball joint...........mine has 6700 miles and has never been touched. Maybe the dealer put some type of sealer there, but they shouldn't have because it's not needed.
Do you have a small propane torch, maybe you can heat it up and get it loose. I'd have a fire extinguisher handy just in case.
Send us some pictures.
exhaust
2011+ Roush Axle Back Exhaust Possible Sale nosympathy Mustang Parts for Sale and Wanted 9 12-02-2012 09:31 PM
Tech question about exhaust? Axle back bolt to Cat back? 2012Coyote 2011-2014 Mustang GT 3 02-28-2012 04:56 PM
Is it possible to turn my p71 crown vic into a muscle car possible? Woodruff General Mustang Discussion 6 04-11-2010 08:30 PM
Is it possible to still possible for something to go wrong with the car? pueblo70 1996-2004 Mustang GT 4 08-26-2009 07:47 AM
04:25 PM
