Went to the track.... Need a few more tenths... - Mustang Evolution
Old 04-20-2015, 03:31 PM   #1
UrMaster's Avatar
So finally got to the track and only got 2 good passes in. Best one was 11.6 @ 116. 1.62 60' (put challenger hellcat in the mirror that pass) . I want consistent 11,30's. That's my goal on motor. My current times are full weight glass roof premium model on sve drags using mickey Thompson et Street radials 28" tall. The 295's and front runners. Mods are long tubes or-x pipe, kooks axle back boss manifold, bbk 85mm tb, jlt cai with a dirty filter, AED tune for 93 and a circle D 5c converter. Also running a 373 gear. Im taking it down to a 331 since I'm going into 4th. Current shift points are 7500. I picked up some BMR lower control arms, adjustable panhard bar, adjustable upper control arm and body mount. Also my converter is locking up in 3rd gear about 6200 rpm. I am going I talk to AED about raising this to around 7200 ish unless that's a bad idea? So should these suspension mods get me where I'm wanting to be or a waste since the car is already making a nice 60'? Scale was broke so couldn't weight it but only weight out was spare tire. Was also on 5/8th a tank since the track was an hour away. Also considering some 90/10's for the front. Thoughts or suggestions?
Sent from my SM-G925V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 04-20-2015, 03:34 PM   #2
UrMaster's Avatar
I'll add my first pass was 11.7 at off idle launch. Second pass listed above I left at about 2200-2500. Tried leaving at 3200 but got wheel hop and had to let out of it. Screwed up a bushing or something because my friend said the rear end looked crooked or tweaked a little after that incident and almost looked like it had a minor dog walk one Highway on the trip home. Will know more when I swap that suspension in.
Old 04-20-2015, 09:44 PM   #3
UrMaster's Avatar
What, no suspension guru's in here? Lame...
Old 04-20-2015, 09:47 PM   #4
Give a little time. Grabber will eventually chime in.
Old 04-21-2015, 03:54 AM   #5
Grabber Blue5.0's Avatar
Install the suspension parts you bought and definitely switch to the 3.31's and see where you stand. A good set of adjustable shocks/struts will help. The 60' is pretty good but you should be able to get a 1.5x with the 5C.
Any idea what the DA was?
Old 04-21-2015, 12:50 PM   #6
UrMaster's Avatar
No not sure. How would I find that out? Does the mph seem right? I see a lot running in the 115-116 range then some in the 120 range all Similar times.
Old 04-21-2015, 02:50 PM   #7
MPH is okay but until I see what your D/A was it's tough to give a real evaluation.
Plug your info in here.
DA Calculator - Density Altitude Calculator - DragTimes.com
Old 04-21-2015, 07:26 PM   #8
UrMaster's Avatar
Track Elevation: 730 feet above sea level
Air Temperature: 60.1 degrees F
Barometric Pressure:30.26 inches Hg
Relative Humidty: 35%
Density Altitude: 668 feet
Relative Density: 98.06 %
Old 04-21-2015, 07:49 PM   #9
UrMaster's Avatar
Grabber what do you think of the strange 10 way adjustable struts? Ever used em?
Old 04-21-2015, 07:59 PM   #10
WhiteCali5oh's Avatar
Region: West Virgina
I heard those are excellent drag shocks.
WhiteCali5oh is offline   Reply With Quote
Old 04-21-2015, 09:33 PM   #11
UrMaster's Avatar
Good, glad to hear. Should be direct bolt in even in Stock Springs right? Nothing else needed?
Old 04-21-2015, 09:43 PM   #12
Shouldn't need anything else. But I'd double check with someone that runs a drag setup
Old 04-21-2015, 09:57 PM   #13
UrMaster's Avatar
Hoping someone in here knows
Old 04-21-2015, 10:03 PM   #14
BLKBETTY13's Avatar
I'm running Strange struts up front with Viking doubles in the rear. Also running BMR springs tho so can not relate to stock. Have not been to the track this season but ride is great and have not had any issues.
BLKBETTY13 is offline   Reply With Quote
Old 04-21-2015, 10:04 PM   #15
BLKBETTY13's Avatar
I also went with 05-09 struts and used GT500 strut mounts.
Old 04-21-2015, 10:15 PM   #16
BLKBETTY13's Avatar
I would say if you went with the 11-14 struts you may want to replace your stock mounts. They're around $40+ each. And at that price you may as well go with the GT500 mounts which are a stronger design however you will need to use the 05-09 struts due to the strut shaft length.
Old 04-22-2015, 03:45 AM   #17
That's what I run.
Old 04-22-2015, 10:06 PM   #18
UrMaster's Avatar
Thanks for the info guys. Gf ordered my the 11-14 version for the 11-14. Why would I need to replace the strut mounts? Car only has 37k on it.
Sent from my SM-N900V using Mustang Evolution mobile app
Old 04-22-2015, 11:12 PM   #19
BLKBETTY13's Avatar
11-14 stock mounts tend to separate when disassembling your struts. Be careful and you may be ok. Others have had a "clunk" or popping noise threw time after replacing struts and or springs.
If not to late I would recommend going with 05-09 set and spending the extra $100 for a set of GT500 mounts. Direct replacement and much stronger setup. Ask around and I'm sure others will agree.
Old 04-23-2015, 04:00 AM   #20
Agreed
Old 04-24-2015, 02:25 PM   #21
UrMaster's Avatar
Originally Posted by Grabber Blue5.0 View Post
Agreed
Little more info? So get the strange 10 way for the 05-09 and get 05-09 gt500 strut mounts? Just more durable?
Old 04-24-2015, 02:34 PM   #22
Yes. That's what I did.
Old 04-24-2015, 03:40 PM   #23
BLKBETTY13's Avatar
Yes. Saves you in the long run.
Old 04-24-2015, 03:47 PM   #24
What about koni adjustable sports?
Old 05-17-2015, 08:49 PM   #25
UrMaster's Avatar
Si just to clarify here, if I go with the 05-09 style strange struts I need the strut mounts for an 05-09 gt500 not a 10-14 gt500, correct?
Old 05-18-2015, 02:34 AM   #26
BLKBETTY13's Avatar
You want the mounts for the 11-14 GT500 and pair them with 05/09-10 struts. At least that's what I did.
Old 05-18-2015, 02:40 AM   #27
BLKBETTY13's Avatar
Believe I ordered mine from LMR and they only carry one set stating "original equipment on '11 GT500"
Will state 05-14 mustang but that is only with the use of the 05-09 struts.
Old 05-18-2015, 02:45 AM   #28
BLKBETTY13's Avatar
I take that back. I ordered everything thru JPC. Strange struts, Viking shocks, and the GT500 mounts.
Old 06-08-2015, 10:35 AM   #29
UrMaster's Avatar
So I swapped the 11-14 Strange 10-way adjustable struts for the 05-09 style. Called AM to get the mounts and they're telling me the mount in universal 05-14 GT, GT500 etc. Don't seem right. Can someone provide me the part number I need? My car is an 11. Confused on if I need 05-09 GT500 mounts since I have the 05-09 style struts or 11-14 GT500 style mounts as my car is a 2011???????
Old 06-08-2015, 12:05 PM   #30
Logiq's Avatar
I believe you would need the 05-09 strut mounts since you have the 05-09 springs/shocks.
Black 2014 Mustang GT /w Track Pack - Multiple exterior mods, Borla S-Type axel backs, Lund Tune, ARH LT Headers, O/R H, Steeda Tansmission Mount Insert, Steeda Panhard bar and brace, Koni Yellow Shocks/Struts, Steeda HD upper strut mounts, Steeda LCA/UCA and mount. BMR LCA relocation brackets, Steeda Sport Springs, Boss IM, Steeda CAI.
Logiq is offline   Reply With Quote
Old 06-08-2015, 12:12 PM   #31
jp1seattle's Avatar
GT500 mounts are the same for all GT500's. 2007-2014
So just get the mounts and the 05-10 struts and you'll be set.
jp1seattle is offline   Reply With Quote
Old 06-08-2015, 12:14 PM   #32
jp1seattle's Avatar
Part number M-18183-C
$84.70 at white bear lake auto nation ford.
Old 06-08-2015, 12:41 PM   #33
BLKBETTY13's Avatar
^^^ Correct
Old 06-08-2015, 02:05 PM   #34
UrMaster's Avatar
What's their website? Thanks guys
Old 06-08-2015, 02:30 PM   #35
jp1seattle's Avatar
http://parts.autonationfordwhitebear...-14/m-18183-c/
went to the track tonight stovalini69 1996-2004 Mustang GT 14 07-15-2006 03:44 PM
A few meets in SC the next few weeks AlmostN8 Regional Mustang Discussion 1 04-18-2005 06:23 PM
Went to the track for the last time in 2004 slvr2000stang The Bar 4 11-14-2004 09:04 AM
Finaly went to the track Black00GT 1996-2004 Mustang GT 15 04-07-2004 12:25 PM
well i went to the track... Zim Pre-2005 V6 Mustang 13 03-10-2004 12:23 PM
» Members Mustangs
Hubbs
hubbs
My Girl
NewMtang
Add your Mustang
12:18 AM
