Springs or Bags - Mustang Evolution
Old 04-20-2015, 05:04 PM   #1
cdouglas12's Avatar
Springs or Bags
I'm looking to lower my 2014 mustang 5.0 and I'm trying to decide either between springs or an air lift suspension. I'm leaning more toward the air lift because I don't want to loose the ride quality I currently have with the stock setup. I have had lowering springs on my previous mustangs and the ride quality felt terrible but I never upgraded the stock shocks or struts. Does anyone have experience with the air lift? And if so should I go that route or just do the springs with upgraded shocks and struts?
cdouglas12 is offline   Reply With Quote
Old 04-20-2015, 05:43 PM   #2
The reason it felt terrible was because you didn't upgrade the shocks and struts
Old 04-20-2015, 07:40 PM   #3
20bmr14's Avatar
If you are doing spirited driving or more bags are not for you. I have done lots of springs without struts and shocks and it is the wrong way to go. Either springs/adj struts or even coils would be better since you would be able to dial in the perfect ride for you.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 04-20-2015, 07:54 PM   #4
I've seen a 1k horsepower GT500 on slicks launch on bags....
Old 04-21-2015, 07:18 AM   #5
How far are you lowering? I talked to a guy recently who went with roush because their setup felt very close to factory ride quality but still dropped height an inch. His testimony.
However I have no personal experience with the roush setup. Can anyone confirm or deny his claims? Only person I met so far with those parts.
Just_Greg is offline   Reply With Quote
Old 04-21-2015, 10:57 AM   #6
lysinger's Avatar
I wouldn't do bags there very expensive, you have to buy a lot of wiring the bags a aircompesor and technology equipment to change the ride height, thats not evening including the equipment to make space for ThE Bags
lysinger is offline   Reply With Quote
Old 04-21-2015, 11:07 AM   #7
rockhillgt's Avatar
also, it depends on what type of springs you purchase...example progressive like the eibachs would give a better ride.
rockhillgt is offline   Reply With Quote
This is why ****** bags shouldn't have money Seph Pictures and Videos 12 01-12-2007 04:20 PM
91 mustang air bags 91conv.guy 1979-1995 Mustang GT 0 10-30-2006 02:45 PM
air bags STEVE The Bar 10 10-13-2004 06:18 PM
Air Bags BlkStang4Me The Bar 12 07-13-2004 06:14 PM
04:34 PM
