Where do you put your jacks? - Mustang Evolution
Old 04-21-2015, 08:22 PM   #1
Kustumb's Avatar
Hey guys,
Just got jacks and want to know where exactly to place them. Anyone got pics?
Thanks as usual.
Kustumb is offline   Reply With Quote
Old 04-22-2015, 01:01 PM   #2
Voltwings's Avatar
Well, jacks or jack stands?
I jack the front of my car up from the pad in the K-member and the rear from the diff. I just place the jack stands in the designated spots on the pinch welds. Theres actually little arrows pointing to where the stands should go.
Old 04-22-2015, 01:28 PM   #3
Be glad your car isn't an sn95 or new edge.... I know someone who jacked up a new edge before and placed jack stand at the designated location and it punched straight through it.
Old 04-22-2015, 01:30 PM   #4
You can see my jack stands
2010 GT Done: FR Intake Manifold-FRPP Hot Rod Cams-Granatelli 62mm TB-BBK Ceramic Longtubes-BBK Catted X-pipe To do:-One piece aluminum driveshaft-Gears-Staggered wheels when my tires are done
theonekyle is offline   Reply With Quote
Old 04-22-2015, 03:02 PM   #5
c_rizzle's Avatar
I've heard differing opinions about jacking up the whole rear from the rear diff.
I've seen people do it for decades.
But I've also heard some people more recently say that it is bad. That its too much weight which can distort stuff and can cause leaks from diff. cover, etc. I'm sure it depends on the car/truck... its weight and the way its built, etc..
But whats you all's take on it for the S-197 ?
c_rizzle is offline   Reply With Quote
Old 04-22-2015, 03:30 PM   #6
zinc03svt's Avatar
Use the frame rails.
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 04-22-2015, 06:58 PM   #7
Voltwings's Avatar
The axle supports the weight of the car anyways, not sure i agree with that, but hell i could be wrong.
Old 04-22-2015, 08:39 PM   #8
olerodder's Avatar
Region: Oregon
If you jack the car directly under the third member, in an 8.8 with a hydraulic jack you don't even come close to touching the rear cover. You are jacking on the bottom of the housing which is a good 1/2" thick and at least 1/2" away from the attachment point of the cover. It's really the only way to get both tires off the ground at the same time unless you use a hoist.
Old 04-22-2015, 09:51 PM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Here's the recommended jack points
2012 Kona Blue 3.7L V6:
Old 04-23-2015, 11:31 AM   #10
c_rizzle's Avatar
Not the axle that was in question, but the rear diff. housing.
(and not my words, just something I've heard from SOME people, that the newer housings aren't as rigid and shouldn't be used to hold up the whole rear end.)
Old 04-23-2015, 11:34 AM   #11
fenixignition's Avatar
Originally Posted by Kustumb View Post
Hey guys,
Thanks as usual.
I place them in my storage unit.
2002 GT 5sp. 16x,xxx miles
Old 04-23-2015, 12:00 PM   #12
olerodder's Avatar
Region: Oregon
Total
Old 04-23-2015, 02:01 PM   #13
That's good...
Where do you put your jacks? Kustumb 2011-2014 Mustang GT 21 04-22-2015 05:56 PM
Do I need ramps and jacks for exhaust install? dacm99 2011-2014 V6 Mustang 24 04-22-2015 04:43 AM
Finally off the jacks!!! Stanglover1966 Pictures and Videos 19 04-19-2013 10:40 PM
Car Jacks - Caliper Cover Install Quikstang 2011-2014 V6 Mustang 3 08-06-2012 04:58 PM
Jacks, jack stands and late model Mustangs CurbRash General Mustang Discussion 18 04-29-2012 08:36 PM
09:33 PM
