Kam Reset? SCT X4 question - Mustang Evolution
Old 04-22-2015, 05:00 PM   #1
Coyote2820's Avatar
Hey guys, I'm wondering if anyone knows what this is for and if anyone has any experience with it. At idle my car struggles to stay alive and dies frequently so I'm wondering if this is a good idea or not.
2014 5.0 GT Premium - Active Duty
2013 5.0 GT - Retired
2003 GT - Retired
Coyote2820 is offline   Reply With Quote
Old 04-22-2015, 05:03 PM   #2
Rapinator126's Avatar
Who is your car tuned by? Mods?
Old 04-22-2015, 05:06 PM   #3
Coyote2820's Avatar
Steeda tuned.
Mods:
Kooks 1 3/4 headers
Kooks Catless H pipe with FRPP Boss Side pipes
Kooks 3" catback
Boss Manifold
Steeda CAI
2003 GT - Retired
Old 04-22-2015, 05:12 PM   #4
Ok well how long have you been running the tune? Been doing this since day 1? Boss manifold been on car since day 1 or just recently? Just update tune recently?
Old 04-22-2015, 06:14 PM   #5
Coyote2820's Avatar
Put the boss mani on about 2 months ago, tuned it, noticed a small difference. Did the exhaust 2 weeks ago then tuned it and has been this way since. It was all smooth up until the boss mani install/tune
2003 GT - Retired
Old 04-22-2015, 06:17 PM   #6
Well it could be a few things then
You have a vacuum leak. How did you tighten down the manifold? Follow the proper sequence ?
Or your tuner could be off.
I'm betting vacuum leak though
Old 04-22-2015, 06:54 PM   #7
chopper's Avatar
What do you mean by the computer may be off, I'm having trouble with my manifold also and it's not a vacuum leak. ...
---------- Post added at 11:54 PM ---------- Previous post was at 11:53 PM ----------
I meant tuner. ..
chopper is offline   Reply With Quote
Old 04-22-2015, 06:55 PM   #8
*tune. Not sure why my phone put a "R" at the end
Old 04-22-2015, 06:58 PM   #9
chopper's Avatar
Ok mine is not the tune either, I've been though that. ..
Old 04-22-2015, 07:00 PM   #10
What kind of trouble are you having then?
Old 04-22-2015, 07:07 PM   #11
chopper's Avatar
The car has been running lean and stalling random misfires on 93 tune. For mods I have boss manifold, off road xpipe, jlt cold air kit and Roush axel back exhaust. It will only run on the cammed tune, because that shuts off the front 02 sensors.
Old 04-22-2015, 07:11 PM   #12
Well if the car is running lean it's the tune.
And the random miss fire can be a few different things. Have you removed the transmission at all?
Also you never shut off the front o2's bc that would be your widebands. You shut off the rear ones.
Old 04-22-2015, 07:17 PM   #13
chopper's Avatar
Sorry I meant rear 02 sensors, the computer is showing it's lean but it's not it's been data loge by lund ,lm not sure if the transmission has been out I'm the 2nd owner.
Old 04-22-2015, 07:23 PM   #14
It could be your wideband is messed up. But that should have showed up in a datalog.
Which code is it throwing. Is it Saying "stuck lean"?
And has it been doing the random miss fire since you got the car? Or did all this start at the same time? If so after what mods?
Old 04-22-2015, 07:23 PM   #15
chopper's Avatar
After the 2nd time taken the manifold off we noticed a inch of oil on number 6 cillinder, but the car doesn't smoke or make any noise and all fluids are good.
Old 04-22-2015, 07:28 PM   #16
chopper's Avatar
This all started after the boss manifold, I know when the data log was done I heard lund said that it was pegged I'm not sure what he meant he was talking to the installer.
Old 04-22-2015, 07:30 PM   #17
He is talking about your MAF sensor. Did he happen to give a rpm at which he was noticing it?
Old 04-22-2015, 07:34 PM   #18
chopper's Avatar
Yes, and he did say that the maf was good. I did change it and also the front 02 sensors.
Old 04-22-2015, 07:35 PM   #19
chopper's Avatar
I'm not sure what rpm it was.
Old 04-22-2015, 07:39 PM   #20
chopper's Avatar
Here is the codes, 93 tune P0100,P2195,P2197.cammed tune 93 P0507
Old 04-22-2015, 07:45 PM   #21
Well since all those codes are for MAF and running lean. Only thing I can think of is the tune or he SENSOR themselves.
I used to have the p2195 code and it was a bad wideband. Easiest way to figure that out is with a idle log. It could also be the tune though.
Old 04-22-2015, 07:49 PM   #22
chopper's Avatar
I thought about it being the tunes so I had Bama send me a 93 tune and there's no difference it does the same thing.
Old 04-22-2015, 08:01 PM   #23
It has to be the sensors then man.
Like I said, I had the p2195 one and it was a bad wideband.
Try cleaning the MAF sensor also.
Do a iddle log
Old 04-22-2015, 08:09 PM   #24
chopper's Avatar
Just changed maf sensor and front 02 sensors, still nothing changed. I know it's going have to be data loge again but I'm trying to catch up money wise, all my friends have to get paid since I not able to work on cars anymore.
Old 04-22-2015, 08:12 PM   #25
You sure you bought the right widebands?
Old 04-22-2015, 08:17 PM   #26
chopper's Avatar
Yes, I got them at a Ford dealership, and also gave them the last 8 digits of my Vin number.
Old 04-22-2015, 11:20 PM   #27
Coyote2820's Avatar
I considered it could be a vacuum leak also but I did the boss mani install exactly as directions read so I'm just confused as to what the issue could really be. I went ahead and tried the kam reset but it didn't do anything really. If I took it to ford to get my 15k mile service could they determine what the issue is and fix that for me?
2003 GT - Retired
Old 04-23-2015, 03:09 AM   #28
chopper's Avatar
I don't think that would be a good idea, once they see you put a tune in it and mods you're they won't touch it.Also probably lose your warranty. ..
Old 04-23-2015, 06:34 AM   #29
chopper's Avatar
Have you tried disconnecting the battery for 30 minutes.If not turn on headlights disconnect negative battery terminal wait 30 minutes then reconnect the battery start engine, let it idle for 10 minutes and then drive it till the computer resets itself.
Old 04-23-2015, 08:25 AM   #30
utm18's Avatar
That's pretty much a kam reset.
utm18 is offline   Reply With Quote
Old 04-23-2015, 08:27 AM   #31
chopper's Avatar
Yes it is. ...
Old 04-23-2015, 09:50 AM   #32
Running lean. Sounds like a vacuum leak.
bodon is offline   Reply With Quote
Old 04-23-2015, 09:59 AM   #33
Originally Posted by bodon View Post
Running lean somewhere.
Old 04-23-2015, 06:25 PM   #34
chopper's Avatar
I'll have to use smoke to find out what the problem. ..
Old 04-23-2015, 06:27 PM   #35
Do these codes pop up when the car is just started? Say if you blip the throttle?
How long does it take to reset the on-board computer? Scrshaw General Mustang Discussion 4 01-01-2012 01:42 PM
gauges reset when started? 04TRV6 Pre-2005 V6 Mustang 8 11-22-2010 08:55 AM
95 GT 5.0 Viper Alarm RESET!! chris7869 1979-1995 Mustang GT 5 02-14-2008 11:11 AM
reset ecu: how? tedness Pre-2005 V6 Mustang 5 07-05-2005 12:10 AM
Vote!! Top100 Reset! Brent The Bar 61 03-02-2005 11:31 PM
02:36 AM
