3:73s. How close to shifting into 5th? - Mustang Evolution
Old 04-23-2015, 12:06 PM   #1
Jvibe92's Avatar
So I have 3:31 right now and since I'm a manual and staying NA. I'm figuring gears would help me get better times. Although, I don't want to shift. On a full bolt on NA. What's it like at the end of the quarter mile?
Jvibe92 is offline   Reply With Quote
Old 04-23-2015, 12:20 PM   #2
Voltwings's Avatar
Plug in the correct information and go nuts.
Speed/RPM Calculator
Old 04-23-2015, 01:14 PM   #3
Jvibe92's Avatar
Thanks! Now let me look up our gear ratios lol on a stock or mildly modified 5.0. How much of a difference have people seen in times?
Old 04-23-2015, 01:29 PM   #4
Grabber Blue5.0's Avatar
Your times could very well be worst going from 3.31's to 3.73's. Those 3.73 gears aren't the end all be all in these cars.
Old 04-23-2015, 02:01 PM   #5
Jvibe92's Avatar
I know. I just know that most say autos should stick to no higher than 3:31 and manuals seem to be better off at 3:73 unless they go FI. I also plan to do some roll races at a track/airstrip. I was just thinking 3:73 would help with better acceleration while simultaneously giving me a hopeful edge at the drag strip
Old 04-23-2015, 06:48 PM   #6
on the quarter mile, assuming you haven't upped your redline you will be at the very top of fourth by the time you reach the end.
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Old 04-23-2015, 07:43 PM   #7
DallasStang77's Avatar
When I was running 3.31s it was a crawl going to 60mph in second gear. Timing myself I hit 0-60 in 5.0 just after putting on MT Street Comp 305/35/20 which is like 28.1" tall.
My 3.73 now puts me back closer to 3.55 or something which is ok. I still enjoyed the 3.31 on 285/30/20 more than the current setup. It was much faster feeling.
If you get taller tires then yes I say get 3.73 but if your intending to stick with 27" or smaller tires then stick with 3.31. Less shifting.
Old 04-24-2015, 03:07 PM   #8
tezz's Avatar
I haven't 1/4er'ed my car yet but I know on the road course it hits the limiter in the low 120's in 4th with the 3.73s. I didn't track the car with the 3.31s. So assuming your car can make it into the teens in the quarter, you won't be getting into 5th.
2013 Ingot GT, 6M, FRAA Susp, GT500 Axle Backs/Wheels/Spoiler, Baer/Shelby brakes, Recaros, Trac-Cal, etc.
tezz is offline   Reply With Quote
Old 04-24-2015, 03:45 PM   #9
Jvibe92's Avatar
Yeah I trap around 116 issh
Old 04-24-2015, 04:42 PM   #10
Jvibe92's Avatar
But I think I wanna eventually run a slightly taller tire. Fills up the wheel well and a thicker tire looks better and takes impact better. I'm currently running 285/35 nitto nt555
Old 04-26-2015, 11:28 PM   #11
Compstall's Avatar
When my car was stock with factory 3.73s it hit the limiter in 4th just before the finish line.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 04-27-2015, 07:58 AM   #12
Jvibe92's Avatar
Sorry I meant 285/40. I think it's barely less that 27" diameter right now
Old 04-27-2015, 08:26 AM   #13
I'm on a 28" bias slicks at the strip and I am just perfectly under the stock rev limit at the stripe. 11s at 115-ish. I went with a 28 for this reason, and to ease the hit at the front with a longer and wider contact patch. It worked.
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
Transmission not going into 5th gear Jr Sager Pre-2005 V6 Mustang 1 10-19-2014 11:05 AM
Problem shifting to 5th Zeek 2011-2014 Mustang GT 11 09-24-2012 02:07 PM
go into 5th damn you! gt274me 1979-1995 Mustang GT 14 06-08-2012 07:43 PM
4th to 5th shifting issue and hard as hell get into R - Black_Sunshine Pre-2005 V6 Mustang 7 03-18-2010 09:55 AM
» Members Mustangs
66
DAndersen0605
Vevo
vevo08
Add your Mustang
04:55 AM
