Axle camber deflection information - Mustang Evolution
Old 04-23-2015, 12:39 PM   #1
jande063's Avatar
I know that this is a strange question, but what is generally considered to be normal in terms of the camber on each side of the axle? The reason that I ask is that when setting my alignment before an event this week, the laser rack notified me that I had -0.2 degrees of camber on the back left, and -0.3 degrees of camber on the back right.
The reason that I worry is that one of the venues that I frequent for local level practice before a larger event is extremely rough (as in a Z06 had a shock go through the shock tower, and an Audi lost two tires and a wheel to an expansion joint that had become quite a bit less than level), and I am wondering if my 8.8 is starting to deflect where the tubes enter the center case.
Unfortunately, it appears that I am not allowed to weld my tubes in to the center, or run an axle reinforcement tool such as a swarr bar due to the rule book limits on lateral chassis stiffening devices.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
For Trade: Roush Axle-Backs for 13+ GT500 Axle-Backs SecretAgent Mustang Parts for Sale and Wanted 3 06-07-2014 06:41 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 04:16 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
08:46 AM
