will i break anything? - Mustang Evolution
Old 04-30-2015, 03:20 PM   #1
mustang145.0's Avatar
so im headed out to the track tonight im running a 15inch wheel with a M&H 28x10.5 slick, i will be launching about 4-5k rpm do you guys think i will break anything? if i do what will break first? 6M
14 GT 6M, steeda lca, uca & relocation brackets, steeda front & rear sway bars, bmr panhard, 3.73, torsen, kw coil overs
mustang145.0 is offline   Reply With Quote
Old 04-30-2015, 04:23 PM   #2
scott_0's Avatar
how much power? driveshaft or twist an axle tube, which generally happens with drag radials, but something to look out for since you're an MT car
Old 04-30-2015, 04:27 PM   #3
natestang07's Avatar
What differential do you have?
Old 04-30-2015, 04:41 PM   #4
Grabber Blue5.0's Avatar
There's a very good chance that Torsen will break. It's not meant for drag racing.
Old 04-30-2015, 05:51 PM   #5
a torsen
Old 04-30-2015, 05:52 PM   #6
im stock so will just an see lol
Old 04-30-2015, 06:18 PM   #7
That's what I thought. The torsen is really that weak on the strip?
Old 04-30-2015, 06:43 PM   #8
Yes. It's meant for road racing.
Old 04-30-2015, 06:44 PM   #9
Was the torsen only with the track pack?
Old 04-30-2015, 06:48 PM   #10
Yes I believe so.
Old 04-30-2015, 06:59 PM   #11
Roush used them on the 427R track packs too.
Adventure till you drop
Old 04-30-2015, 07:56 PM   #12
2014oxstang's Avatar
Yes I believe so.
Negative. I have it on my base GT
2014oxstang is offline   Reply With Quote
Old 04-30-2015, 08:46 PM   #13
^ The torsen only came on the track pack and boss cars. You may have the 3.73 gears but not a torsen.
ads245 is offline   Reply With Quote
Old 05-01-2015, 01:19 PM   #14
That is right ads245 only on the two cars.
Teak 14 is offline   Reply With Quote
Old 05-01-2015, 01:28 PM   #15
If I could find my sticker, I'd show you lol. Clearly stated it had the Torsen.
Old 05-01-2015, 02:04 PM   #16
Use this link to get your window sticker, all you have to do is enter your vin number. I am curious because if your sticker actually says Torsen that would be very strange.
http://researchmaniacs.com/VIN-Numbe...cker/Ford.html
Old 05-01-2015, 03:10 PM   #17
Name:	ImageUploadedByMustang Evolution1430514557.404948.jpg
Ahhhh, maybe I stand corrected here? What brand limited slip is it if it isn't a Torsen? Maybe the dink who sold it to me said it had the Torsen lol.
Old 05-01-2015, 03:21 PM   #18
You don't have a Torsen.
Old 05-01-2015, 03:26 PM   #19
Thanks for answering the question. And I guess that's good since I drag race right?
Old 05-01-2015, 03:27 PM   #20
Correct
Old 05-01-2015, 03:34 PM   #21
Correct
Old 05-01-2015, 03:45 PM   #22
No worries. It is a common misconception when people see the upgraded 3.73s on their sticker that it is a Torsen. It's not, rather it is simply the stock clutch type LSD with 3.73 gears instead of the stock 3.31s. I think the confusion lies in the fact that the Torsen only comes with 3.73 gears.
Technically though, anyone could swap other gears such as 3.55 or 3.31 onto their Torsen if they wanted.
Old 05-01-2015, 04:22 PM   #23
Hmmmmm interesting...wonder what brand it is (quaife, viscous, etc)
Old 05-01-2015, 11:42 PM   #24
Region: West Virgina
Originally Posted by 2014oxstang View Post
Attachment 181559
Ford Traction-Lok.
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 05-02-2015, 12:03 AM   #25
Originally Posted by scott9050 View Post
Ford Traction-Lok.
Ahhhhh ok. Is it a good system or...?
Old 05-02-2015, 12:14 AM   #26
there really is no point in asking this question. there is always a chance you will break something when racing, that's the risk you take.
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Old 05-02-2015, 12:15 AM   #27
True. I just want to know if the trac-lok is a decent unit
Old 05-02-2015, 12:34 AM   #28
.... There is a very good reason to ask. Everything can break but something break less because they are quality units
Old 05-02-2015, 01:07 AM   #29
Only issue I've had with my diff. was a pinion seal leaking.
Old 05-02-2015, 08:08 AM   #30
I've got over 100 passes on slicks, clutch dump at between 4500 and 6000. Nothing unwell yet. Clutch will likely go first, if you do a lot if this but I wouldn't be too worried based on what I've seen.
Old 05-02-2015, 03:05 PM   #31
Good to know gents
Old 05-02-2015, 04:08 PM   #32
I guess I did actually kill something: The factory sway bar end links didn't last long but, they wouldn't have anyway, based on History and Ford replaced them without batting an eye. I did start to see a little weeping on one shock too but Ford also replaced that w/o complaint.
The factory traction-lok is a good diff. I've had them in 3 mustangs, all using sticky tires and raced and haven't had one fail yet. I did rebuild the one in my supercharged '88 but, that was because I wanted to restack it so it would grip harder.
There's good stuff out back, standard. 31 spline axles, rumour has it 3.73 cars got the carbon clutches out of the GT500.
Old 05-02-2015, 11:38 PM   #33
Very interesting. Good to know man!
Does a tune do anything if you don't change anything else? sbbamafan AmericanMuscle 8 11-14-2013 08:21 AM
Notice anything different? Brent Pictures and Videos 17 07-27-2004 01:44 PM
people will sell anything on ebay fast64 The Bar 13 07-12-2004 09:57 AM
anyone need anything installed? Stylin97V6 Regional Mustang Discussion 4 12-19-2003 04:05 PM
11:04 AM
