2014 GT with dead battery and the key won't unlock the door. - Mustang Evolution
Old 05-01-2015, 08:14 AM   #1
Devil Strider's Avatar
My wife tried to unlock it and she said the key won't turn. It's been sitting in the garage for a while now and it needs a jump. Is it possible to physically unlock it with the key? She said she tried it and it would not turn.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 05-01-2015, 09:39 AM   #2
Try to use the spare key you got when you bought the car.
Silver_Stang is offline   Reply With Quote
Old 05-01-2015, 09:42 AM   #3
oxford5pointoh's Avatar
There is a key hole. I can't imagine the key won't work. It's probably because the window won't go down that 1/8 inch and she isn't pulling hard enough on the door. I disconnected my battery to do some work once and went to open the door and was met with some resistance. But I slight tug and the window popped out of the rubber it rolls into.
Old 05-01-2015, 09:59 AM   #4
2014SGM's Avatar
Region: Mexico
When I did my leather seats, I had no problem opening and closing the doors when they were up and I had the battery disconnected.
Should've bought the Prius.
2014SGM is offline   Reply With Quote
Old 05-01-2015, 10:35 AM   #5
Thanks. She couldn't get it open so I'll look into it when I get back to the states.
Old 05-01-2015, 11:07 AM   #6
Thanks guys. It opened after spraying the key with WD40.
Old 05-02-2015, 10:54 AM   #7
tezz's Avatar
She'll probably need to reset the window once it's powered up. Instructions in manual - easy but window won't seal right if you don't. I think it was something as simple as holding the switch in the down position for 3 seconds after it stops.
2013 Ingot GT, 6M, FRAA Susp, GT500 Axle Backs/Wheels/Spoiler, Baer/Shelby brakes, Recaros, Trac-Cal, etc.
tezz is offline   Reply With Quote
Unlock Key- Car Alarm goes off ctrez06 2005-2010 Mustang GT 8 11-30-2014 10:12 AM
programming key remotes - changing unlock settings dpevoar 2005-2010 V6 Mustang 3 07-05-2013 10:05 AM
Program key to unlock both doors with one click? Jukens 2011-2014 Mustang GT 13 05-31-2012 12:10 PM
2005 mustang gt door locks will unlock but not lock!?!? bryanbrock 2005-2010 Mustang GT 9 10-29-2011 11:01 PM
New Battery Dead after 10 days.... snipercop 1996-2004 Mustang GT 8 12-30-2010 04:43 PM
09:37 AM
