Single Use nuts/bolts - reuse? - Mustang Evolution
Old 05-01-2015, 11:40 AM   #1
ninjamatic's Avatar
Doing some suspension work tomorrow. Have you guys reused your one-time hardware? If so, blue should do the trick.
Just trying to see if I need to get replacement hardware when I do my springs, control arms and panhard tomorrow.
Appreciated all!
Sent from my Nexus 6 using Mustang Evolution mobile app
Video Game Developer | PS4, PC
2014 GT Premium Track Pack | Sterling Gray
ninjamatic is offline   Reply With Quote
Old 05-01-2015, 05:40 PM   #2
olerodder's Avatar
Region: Oregon
Ford says use the hardware once and that is for a good reason.
I replaced all my hardware when I lowered my Mustang last year. When we were putting the adjustable panhard bar in I couldn't find the new nut for the drivers side(so re-used the old one)but did replace the bolt. A number of friends were helping me and I didn't personally check the torque on the panhard bolts. When I replaced my LCA's I rechecked the torque settings on all of the suspension and the panhard bar had only been torqued to 75ftlb, so I re-torqued the passenger side to 130ftlbs and then went over drivers side.............I didn't make it to the torque setting before the nut stripped..............and that was the used one.
There is a thread somewhere here where I posted all of the Ford part#s needed for the complete suspension. You can do what you want, but my suggestion would be to order them and and install new not used.......................IMHO
Old 05-01-2015, 06:05 PM   #3
ninjamatic's Avatar
Roger that. Weird. All of the BMR install manuals say to reuse factory hardware, except in cases where they provide you with new hardware like UCA mount or LCA brackets.
Hmmm. I'll dig for #s
Old 05-01-2015, 06:47 PM   #4
Grabber Blue5.0's Avatar
I reused all my original hardware. If Kelly @ BMR says it's okay that's good enough for me. He's the suspension expert.
Old 05-01-2015, 07:11 PM   #5
20bmr14's Avatar
I too have reused all old stuff and it has held up to to a fair amount of abuse.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 05-01-2015, 07:27 PM   #6
Region: Nevada
I replaced mine. Because my wife also drives the car and we carry the grandkids and other passengers. It’s more of a safety obligation to them and just good engineering practice to do it right.
2014 SGM GT, 300A base coupe, 6R80, daily driver.
silverstate777 is offline   Reply With Quote
Old 05-01-2015, 08:43 PM   #7
olerodder's Avatar
Region: Oregon
It's a matter of preference and for me it's always been wanting to feel that if I push my vehicle to the limit or beyond I'll never worry about the suspension failing.
Over the past 35+ years I've built numerous drag cars, sports cars along with hot rods and have always either bought new hardware or replaced existing suspension bolts/nut/washers after working on them. To me it's like building a $20k motor and reusing the same main/rod/head bolts....................are there people that do this, sure, but I'm not one of them.
It's your car, you do what you feel comfortable with.
Old 05-01-2015, 08:48 PM   #8
oxford5pointoh's Avatar
I am doing all mine. Thanks again for that list olerodder. Only one number didn't work. I still need to figure out what one it was
Name:	ImageUploadedByMustang Evolution1430534816.039097.jpg
Name:	ImageUploadedByMustang Evolution1430534887.223039.jpg
Old 05-02-2015, 12:04 PM   #9
I reused hardware for everything back there and just ensured it was torqued to value. They've all been fine with 100+ dragstrip passes slicks, in an MT car.
The bolts don't look like torque to yield, they appear to be all standard place bolts so, it's fine to reuse them, as long as you torque them properly. If these huge bolts/nuts strip, I'd say your torque wrench is out of calibration. 130 pounds on a standard length torque wrench barely feels like anything.
I'd expect Ford is being a little liability happy.
Old 05-02-2015, 01:26 PM   #10
olerodder's Avatar
Region: Oregon
Up until last year I maintained my 9.80 drag car and had my Snap-on 3/8" and 1/2" drive torque wrenches recalibrated at least once every two years. I had just had both torque wrenches recalibrated just last May at AIR, so I know they were dead on...........maybe you should have yours recalibrated.
Old 05-02-2015, 04:24 PM   #11
Beviking's Avatar
Ditto for me except the drag passes. Totally agree. Still, never hurts to be safe.
Beviking is offline   Reply With Quote
Old 05-02-2015, 05:40 PM   #12
I suppose I'm willing to pay 120 bucks for peace of mind on my 35k car
Should I get new valve cover grommets or reuse mine Iryan7 Pre-2005 V6 Mustang 0 09-07-2014 11:38 PM
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Can I reuse my old Head Bolts? FORDGT14 1996-2004 Mustang GT 8 10-27-2011 05:31 PM
Can't Use Lights or Defroster or 01 Mustang goes nuts!! twnations Pre-2005 V6 Mustang 4 12-04-2005 08:59 PM
What nuts and bolts do I need? njstang97 Pre-2005 V6 Mustang 4 02-17-2004 07:19 AM
06:31 AM
