Couldn't say no - Mustang Evolution
Old 05-04-2015, 04:17 PM   #1
Anthony214's Avatar
Couldn't say no
I own a 2011 5.0. My next door neighbor owns a 2014 5.0 and purchased a JLT Carbon Fiber CAI. He thought it was going to help him get back the sound he liked from his 2009 Mustang. Well it didn't and he took it off and gave it to me. That's right. GAVE IT TO ME lol. I always help him out around his house and stuff so he just said you can have it. Why would I say no? Problem is that his is an automatic and I have a stick so he had to drill the hole into the tube. I didn't know until I was reading a how to that only the autos need the hole drilled. So are there any ideas on how to plug the hole up? Or am I SOL?
Anthony214 is offline   Reply With Quote
Old 05-04-2015, 04:46 PM   #2
zinc03svt's Avatar
Go to Lowes and pick up 1/2 inch plastic plug in the hardware section. Get some gorilla glue to seal it. Done.
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 05-05-2015, 04:22 AM   #3
Anthony214's Avatar
Will the heat from the engine or eventually the sun not melt the glue?
Old 05-05-2015, 06:12 AM   #4
Junior Member
Check the spec of the glue.there are glues certified for the aerospace industry. Check the materials of the plug and their compatibility. Good luck, and share the results...
liampouras is offline   Reply With Quote
Old 05-05-2015, 06:41 AM   #5
Famine's Avatar
Region: South Dakota
Any grommet will work. That's all they give you with the kit anyhow.
Famine is offline   Reply With Quote
Old 05-06-2015, 04:46 AM   #6
agree with Famine. i know the engine bay get hot but those grommets are built for that and its not like its direct heat
greyghost14 is offline   Reply With Quote
Old 05-06-2015, 07:09 AM   #7
Voltwings's Avatar
or go to any autoparts store and get a vacuum cap. My fiance traded her '14 auto in on a '14 stick and we transferred her air raid over with no problems by just capping the nipple.
Old 05-06-2015, 07:25 AM   #8
Waylap1's Avatar
Region: New Hampshire
But your car already has a factory CAI that works better, unless you have a tune that requires some sort of aftermarket one.
Waylap1 is offline   Reply With Quote
Old 05-06-2015, 08:48 AM   #9
Anthony214's Avatar
I'm running 100 shot so I want to see if it makes a difference. Probably will probably won't.
Old 05-06-2015, 09:39 AM   #10
Eric5oh's Avatar
Couldn't say no
I know everyone says that the factory CAI really is designed best for the engine but this dude was handed a K&N FOR FREE and I already see people saying our shouldn't use it. I see this all the time "The stock air box is designed the best way possible for the 5.0 coyote" blah blah blah. Lol it's not gonna hurt the car unless it was made specifically for a tune. Yeah I get it if you wanna spend 400$ and want gains certainly steer clear from a CAI. But a free one seems like a sweet deal to me lol
2013 Sterling Grey GT/Brembo package/SR Performance lowering springs/J&M adjustable panhard bar/Roush axle back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 05-06-2015, 09:42 AM   #11
Some CAI's require a tune change. Mine did, so check it out.
bodon is offline   Reply With Quote
Old 05-06-2015, 10:49 AM   #12
Waylap1's Avatar
Plus a lot of them are very good at sucking up the nice dank hot engine compartment air.
Maybe run it down low, away from the engine heat and clear of the Torretto nozzle.
Old 05-06-2015, 10:54 AM   #13
natestang07's Avatar
You will not notice a negative difference unless it is installed improperly. If it is free then why not?
Old 05-06-2015, 11:00 AM   #14
Waylap1's Avatar
I wouldn't put anything on just because it's free. Spend a few dollars on something like this for more gains than a CAI.
Old 05-06-2015, 11:07 AM   #15
Eric5oh's Avatar
I have an aftermarket CAI and its closed box... No tune and had the car on the dyno before and after. Gained 8hp lol
Old 05-09-2015, 08:24 AM   #16
hctr154's Avatar
Hahaha. ..good one!
2013 GT A6
hctr154 is offline   Reply With Quote
Old 05-10-2015, 05:01 PM   #17
Hampton CIT's Avatar
+1 on Voltwings suggestion. Nice pick up for being a good neighbor.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 05-14-2015, 04:02 AM   #18
Anthony214's Avatar
Did you guys just press it in there? No glue or anything?
Old 05-14-2015, 05:08 AM   #19
20prima10's Avatar
Try a night temp epoxy. I've used that stuff before on a plastic intake and to this day the cars still on the road. It's sand able after fully cured. Works great imo. Intake was done four years and roughly 90000 miles ago
20prima10 is offline   Reply With Quote
Old 05-14-2015, 05:39 AM   #20
20prima10's Avatar
High temp. My mistake
Old 05-14-2015, 02:49 PM   #21
c_rizzle's Avatar
He got it for free, probably b/c the previous owner realized it was really a Hot Air Intake.... not a CAI.
If this is what he got for free, I'd put it in the garbarge before I put it on my car:
1. Its a HOT engine comparment Air Intake (HAI).
2. It will suck up water that drips in from the hood air extractors on the 13-14's.
The only kind of "CAI" I'd consider is a closed box style, that truly sucks ONLY cold air in from the front of the car, AND has the water protection since I have a 2014 with the hood vents.
c_rizzle is offline   Reply With Quote
I couldn't take it anymore!!! whipster24 The Bar 6 11-01-2005 08:08 PM
I couldn't hold off any longer lowflyn Pictures and Videos 35 07-26-2005 04:05 PM
Just when you thought it couldn't get any worst.... lowflyn The Bar 18 07-12-2005 06:56 PM
Couldn't get past the second part Ken The Bar 2 03-23-2004 09:29 AM
12:09 PM
