Clunking noise won't go away - Mustang Evolution
Old 05-04-2015, 06:12 PM   #1
roadrunner86's Avatar
Ok so this clunking noise is coming from the front of my car. I have replaced the struts and the strut mounts and it still makes the same noise. Any ideas what could be causing this?
roadrunner86 is offline   Reply With Quote
Old 05-04-2015, 06:45 PM   #2
BLKBETTY13's Avatar
Possibly sway bar links?
BLKBETTY13 is offline   Reply With Quote
Old 05-04-2015, 07:51 PM   #3
Billgluckman's Avatar
^^^ def check out sway bar bushings.
Billgluckman is offline   Reply With Quote
Old 05-05-2015, 07:17 AM   #4
Sorry this may be a stupid question, but how do I go about checking these?
Old 05-05-2015, 08:58 AM   #5
olerodder's Avatar
Region: Oregon
When did the clunking start? Did you lower the car and if so what struts and strut mounts did you use, or did you have it done at a shop?
Old 05-05-2015, 09:22 AM   #6
ninjamatic's Avatar
Hmmmm. Have you made sure you tightened the strut mount good? Last year a friend of mine did his and he tightened it but not all the way. With the rubber cap on you should see a few threads. His clunked until he gave it a few ticks with an impact.
Sent from my Nexus 6 using Mustang Evolution mobile app
Video Game Developer | PS4, PC
2014 GT Premium Track Pack | Sterling Gray
ninjamatic is offline   Reply With Quote
Old 05-05-2015, 10:37 AM   #7
I have a 2014 gt and there was a service bulletin about the front control arms. Mine was replaced by the dealer. You would hear the clunking when going over bumps.
buddyrich14 is offline   Reply With Quote
Old 05-05-2015, 11:08 AM   #8
olerodder's Avatar
Region: Oregon
If the clunking was not there before you took it to the dealer I'd be taking it back to the same dealer and asking him to fix it.
I've got a 14GT/TrakPak and have never seen a "service bulletin" talking about the front control arms, do you still have the service bulletin and what was the number on it.
Thanks,
John
Old 05-05-2015, 12:27 PM   #9
rrharley91's Avatar
I looked I couldn't find any bulletin. I would like to see a copy also.
rrharley91 is offline   Reply With Quote
Old 05-05-2015, 01:06 PM   #10
Yes it is lowered with eibach springs and eibach struts and shocks. And it kind of sounds like it's also coming from the rear as well.
Old 05-05-2015, 01:09 PM   #11
olerodder's Avatar
Region: Oregon
What strut mounts did you put in or did you use the stock ones?
Old 05-05-2015, 01:36 PM   #12
Try to rock the car side to side. Push on it and get it rockin. See if you hear the noise.
Old 05-06-2015, 11:40 AM   #13
It wasn't a service bulletin, it was a service advisory. When I brought my car in they showed me the advisory. They will fix it for free. Ask your service department about it.
Old 05-08-2015, 09:11 AM   #14
Can the rear sway bar end links be replaced alone or do I have to buy a new rear sway bar kit?
Old 05-08-2015, 09:52 AM   #15
olerodder's Avatar
Region: Oregon
If you are talking about the bushings the ends of the sway bar go into on the axle.............you'll have to ask your Ford dealer, but would assume them to be a service part. If these are the parts you want to replace can I ask why you need to replace them.
If you are talking about the stabilizer bar links they are part number CR3Z-5C488-Q for both R and L and should cost you $26 each. I am assuming you have a coupe and not a convertible.
Old 05-08-2015, 10:06 AM   #16
Hope you find out
Buster Crabbe is offline   Reply With Quote
Skip that won't go away 03GTDonutz 1996-2004 Mustang GT 12 02-26-2014 08:56 AM
Weird clunking noise. Four Eyes 1979-1995 Mustang GT 15 07-26-2013 02:05 PM
Clunking noise! Jeremyweld 2011-2014 V6 Mustang 10 03-15-2013 01:40 PM
Weird Clunking Noise CodyNelson 1996-2004 Mustang GT 5 08-18-2011 08:20 PM
Clunking noise when shifting Halyssvt 1996-2004 Mustang GT 7 03-08-2011 12:48 PM
03:26 PM
