Cobra T56 swap in place of MT82 - Mustang Evolution
Old 05-04-2015, 11:40 PM   #1
Compstall's Avatar
Anyone know details on a possible 03-04 Terminator trans swap? Looking at alternatives. My MT82 has been notchy from day one. At first I thought it was just new and needed to be broken in. 4 years and 36,000 miles later it has not changed, and just recently the clutch pedal stuck at the floor. I'm confident it's either the master cylinder or the pressure plate, and will find out once I get it into a dealer what the problem is.
But, if they only want to change the pressure plate and charge me the difference in labor costs, I'm considering just buying an aftermarket clutch and doing it myself.
Otherwise, I read the article in MM&FF recently on the T56 Magnum swap and it got me thinking about going that route. However, that's a $4k+ purchase. I'm sure it's a great swap, just weighing the options here..
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 05-04-2015, 11:45 PM   #2
It'll me a far less headache to go with the one that is meant for your car. All the custom work needed to make a 03/04 Cobra transmission work with your car will probably raise the cost up to that also....... And the gearing in the Cobra transmission most likely isn't too favorable for a coyote with such a steep 1st gear at 2.66
Old 05-05-2015, 12:04 AM   #3
bazinga11's Avatar
Ben calimer from rev auto sells rebuilt mt-82s (replaces all of the plastic junk) for $1800 I believe. And you can get $600-800 core charge for your unit if nothing is wrong with it. Be a cheaper alternative.
The transmissions itself are not that bad themselves.. Stock shifter, clutch, and rubber brake line are major culprits. The only downside of a good working stock mt-82 would be plastic shift pads.
Old 05-05-2015, 06:14 AM   #4
scott_0's Avatar
he is not affiliated with Revolution Automotive, he does do MT82's but not for Revolution, Ronnie Reynolds does Rev's transmission work.
OP. as said, to avoid any issues with a swap, Id do the Magnum XL version of the t56 as it has the extended tailshaft designed for our cars
Old 05-05-2015, 07:19 AM   #5
bazinga11's Avatar
Ah my bad! But yeah Ben Calimer would be your guy for rebuilt mt-82s. I have heard nothing but good things about his work
Old 05-05-2015, 08:54 AM   #6
olerodder's Avatar
Region: Oregon
I've thought about this swap also and although I have only put in the Whiteline trans mount and replaced the stock rubber shifter rear mount with a urethane piece I still have the stock shifter. I would like to replace the rubber hydraulic line with a braided piece but only after separating the clutch hydraulic system from the brake system.
I had a Tremec in my 97 Cobra after replacing the stock 5spd and loved it. The only issue with the T56 Magnum is the gearing. The current gearing in my MT82 is perfect with the 3:73's I currently have and the T56 doesn't offer gearing that will match my MT82.
Unless I would be making 500hp at the rear wheels I think I'll stick with the MT82, and if something happens I'll rebuild it with better parts.............or maybe change the shifter. Although with the mods I've done now it feels 100% better than it did stock.
T56 swap Ewokjax95 1979-1995 Mustang GT 8 11-13-2012 11:06 AM
T45 99 gt can i swap for t56? 99redgt 1996-2004 Mustang GT 2 09-10-2012 09:27 PM
TR 3650 to T56 swap Cobraman8801 1996-2004 Mustang GT 0 06-15-2012 06:19 PM
02 mustang gt>forged cobra swap,t56, $10,000 SimplyOrange Mustangs for Sale and Wanted 44 10-08-2008 02:19 PM
T56 SWAP madmax680 1979-1995 Mustang GT 13 05-03-2007 11:33 PM
05:26 AM
