Tires slipping on wheels - Mustang Evolution
Old 05-05-2015, 05:17 PM   #1
Redonblackpony's Avatar
Has anyone noticed tires slipping on your wheels?
I probably would have never known but I just got new tires. When mounted, they mark the valve stem location with a circle on the tire. Two of my tires (ink stamped circle) no longer line up with the valve stem.
Should I be concerned about this?
Redonblackpony is offline   Reply With Quote
Old 05-05-2015, 06:06 PM   #2
DWoody's Avatar
Those little marks they make are just to make it easier to balance a new tire on your wheel. Sometimes they have to deflate the tire and spin the tire on the wheel to get it to balance out closer to zero before they put weights on it.
DWoody is offline   Reply With Quote
Old 05-05-2015, 06:19 PM   #3
scott_0's Avatar
when I got my tires mounted recently, my friend that mounted them told me not to lay into it for about a week, due to the fact, he's seen wheels spin inside the tire because of the mounting lube they use, first I had heard of this
Old 05-05-2015, 07:00 PM   #4
Yell I'm really not sure if those little marks ever lined up with the tire stems in the first place.
I had my tires mounted and then 12 hours later I was at the track doing hot laps all day.
Old 05-05-2015, 07:46 PM   #5
Very common, especially with drag tires. However, a little movement in a road tire can happen and is unlikely to have a significant enough effect to throw off the balance if the wheel and tire.
Will 205/75-14 tires fit 14x7 wheels? will 225/45-17 tires fit 16x8 wheels? baudier Classic Mustangs 4 03-29-2016 08:25 PM
Wanted: GT500 wheels and tires or 19inch wheels and tires 2014_MCA_Vert Mustang Parts for Sale and Wanted 1 02-28-2015 07:25 PM
MGW Shifter Slipping out of 5th? hihosilver Pre-2005 V6 Mustang 2 06-02-2011 11:57 AM
TRANMISSION SLIPPING! Debras96stang Pre-2005 V6 Mustang 11 05-26-2006 11:30 PM
12:33 PM
