qtp cutouts - Mustang Evolution
Old 05-12-2015, 12:52 AM   #1
andyx5oh's Avatar
qtp cutouts
just got my qtp low profile cutouts. ill be having a shop weld them in and I'm having my friend do the wiring. only question i have is where should i get them welded? 14 gt running longtubes with an o/r x pipe. stock cat and axle back.
andyx5oh is offline   Reply With Quote
Old 05-12-2015, 11:20 PM   #2
andyx5oh's Avatar
i find it hard to believe that nobody here has cutouts installed.
Old 05-14-2015, 09:51 PM   #3
oxford5pointoh's Avatar
I've seen these installed in the mid pipe after the exhaust meets. Basically like the boss side pipe set up.
IG @Oxford5pointoh
Old 05-14-2015, 10:20 PM   #4
You can put them where ever you want. No real specific place for it. Most people who get cutouts get them so it can be as loud as possible, in which case put it on the midpipe as close to the headers as you can.
Old 05-15-2015, 12:03 AM   #5
bsyo1021's Avatar
I'm planning to get some installed on mine and was going to do it at the first bend of the x-pipe before the actual x part and right after the headers so its basically a straight shot out of the headers when I open them up. If you have ever started your stand with just the headers on it sounds awesome! Best of luck
2012 GT with lots of stuff. ---> Youtube Channel:
https://www.youtube.com/channel/UCuX...HPINiD_fDxyaVw
bsyo1021 is offline   Reply With Quote
Old 05-15-2015, 02:43 AM   #6
andyx5oh's Avatar
Good advice from everyone. I was planning on welding them after the longtubes on the x pipe but before the actual x. That way when I do have them open its pretty much open headers. but wouldn't that hurt the power gains that the x pipe puts out?
Old 05-15-2015, 06:58 AM   #7
I would think the tune would need to be adjusted opened vs. closed.
bodon is offline   Reply With Quote
Old 05-15-2015, 09:33 AM   #8
08Mustang's Avatar
Put them directly after the x pipe so you still get the exhaust scavenging benefits of the x pipe
08Mustang is offline   Reply With Quote
Old 01-25-2017, 05:41 PM   #9
Rickster_1823's Avatar
sorry to bump this old thread. I was curious to know which will be better, a single or dual cutout? I seen a lot of post that only recommend to install 1.
Just want to get a final input as I am fixing to purchase my QTP cutouts. Greatly appreciated.
2013 5.0 DIB; Airaid, JBA LT Headers / JBA Off Road X Pipe to Cutouts; 4.10s; BBK Lower Arms; Barton Short Shifter; E85 BAMA race.
Rickster_1823 is offline   Reply With Quote
Old 01-25-2017, 07:44 PM   #10
For the mustangs your better off with two since you have true duels. Often times if you have a y pipe setup you can do a single cutout at the y pipe. That is the setup I had on my trans am.
StarzTA17 is offline   Reply With Quote
Old 01-25-2017, 10:06 PM   #11
No idea why you'd only run 1 cutout, I imagine it'd sound awkward as well as effectively shorten the exhaust travel distance for half of the exhaust leaving the engine. Sounds like a horrible idea for a full dual exhaust car.
nate714 is offline   Reply With Quote
Old 01-26-2017, 07:18 AM   #12
That's what I was thinking. I guess some people just like to throw a curve ball on some topics. I will post a video of my exhaust once I get them installed. I will weld them right after the X on off road pipe to take advantage of the little power.
Thanks folks!
QTP Electric Cutouts? Should I do this? shaneyusa General Mustang Discussion 0 03-07-2015 04:00 AM
QTP Cut off switch Jtrejo_03 2005-2010 Mustang GT 2 10-20-2013 11:41 PM
QTP Electric Cutouts Installed maldog 2005-2010 Mustang GT 26 05-26-2013 10:08 AM
V6 Bumper Cutouts? Dark04ShadowV6 Pre-2005 V6 Mustang 14 10-13-2008 04:55 AM
351 exhasut/cutouts silverado_nolan 1979-1995 Mustang GT 0 04-22-2007 07:31 PM
05:04 PM
