Drivetrain noise help. Aluminum xriveshaft? - Mustang Evolution
Old 05-17-2015, 09:42 AM   #1
Sterlingbeast5.0's Avatar
I have a shaftmasters and am lowered on sportline springs. Get a whining noice whether in hear or not. Getting louder. Have tried couple things. Do have lca relocation brackets as well. Noise not engine related. At hwy speed sounds same ifclutch in and glide
Old 05-17-2015, 10:36 AM   #2
From this it is clear that it it something turning while the wheels are, like the rear axle. A driveshaft change won't alter whining, that's a setup issue with rear gears. Steep gears are likely to whine more, you have 3.73s?
Old 05-17-2015, 04:32 PM   #3
I have stock 2013 gears. 3:53 i think it is. Only reallystartedsince changed the shaft. Seems to be definitely coming from right around the rear axle though.
Old 05-17-2015, 07:27 PM   #4
D1STRRBD's Avatar
How low is your drop? Did you adjust the pinion angle after dropping and installing the DS?
D1STRRBD is offline   Reply With Quote
Old 05-17-2015, 07:31 PM   #5
The noise was already there but, it is possible the DS is amplifying it. Part of the reason for using a 2 piece shaft is resonance control.
Stock GT gears are 3:31 on an MT car, btw.
Old 05-17-2015, 09:49 PM   #6
olerodder's Avatar
Region: Oregon
I've got a 14 with Shaftmasters and Sportlines also.
Did you check the pinion angle and transmission angle before putting in the DS?
I've got a TrakPak car and when I lowered it noticed more whine than before, then I put LCA's on an noticed even more. After I installed the Whiteline transmission mount stiffener I noticed quite a lot of NVH above 2000rpm(I did not cut the stiffener or drill a hole in it which could have been the reason I gained quite a lot of NVH). I checked the pinion angle and trans angle before I put the DS in and it was off. Luckily I had put in an adjustable UCA and carrier bushing and had to adjust the pinion angle. My whine is now a lot less and I attribute less noise to a better pinion angle.
Sportline springs lower 2"+ in the rear which has changed the pinion angle, but because of the two piece driveline it's less noticeable than a 1 piece. At least on my car now that the pinion angle is about 0.5 degrees positive it has reduced the NVH and whine.
I have not put any relocation brackets on my car as I don't see the need.......yet.
Old 05-18-2015, 06:31 AM   #7
This is all good stuff. Hoping guy who does installs can get it in today and check out. Have him check alignment as well? For pinion angle right
Old 05-18-2015, 08:08 AM   #8
olerodder's Avatar
Region: Oregon
As long as he follows the instructions that come with the DS you should be golden.
Old 05-18-2015, 12:35 PM   #9
I had the same noise that you are experiencing. My Ford dealership installed mine, checked my pinion angle, panhard rod, LCA, as well as installed my UCA. The noise went on for about 200-500 mi and then it has stopped. My guess would be break-in period ??? I currently have no issues with mine.
HulkSmash is offline   Reply With Quote
Old 05-18-2015, 12:50 PM   #10
It isnt shaft. As first guy suggested it is bearings / gears. He losened differential and the magnet has decent amount of shavings. Guess going to get 3:73 ahead of schedule
Old 05-18-2015, 04:56 PM   #11
Beviking's Avatar
You will notice more whine if you lose gear oil. If you happen to notice any seapage or drips, you will want to investigate that.
I think we tend to pay closer attention after a mod, at least I do so minor whine before might seem like a louder whine after the install. The carrier bearing on the stock 2 piece ds definitely helps quiet noise. I didn't notice much more nvh after installing my shaftmasters.
Beviking is offline   Reply With Quote
Excessive noise in one piece aluminum driveshaft Redonblackpony 2011-2014 Mustang GT 10 12-27-2013 01:28 AM
Drivetrain help clutch, and tranny 99redgt 1996-2004 Mustang GT 18 09-18-2012 07:57 AM
79-93 Be Cool Aluminum 2-row radiator w/ aluminum cap fast64 Mustang Parts for Sale and Wanted 6 07-22-2009 02:14 PM
help putting together list of bullet proof drivetrain tire Pre-2005 V6 Mustang 6 01-15-2004 11:36 AM
suggestion of sticky in "drivetrain" tire The Bar 0 07-18-2003 03:20 AM
06:17 PM
