Panhard Bar SR triple adjustable on 2014 GT - Mustang Evolution
Old 05-18-2015, 01:02 PM   #1
Just got the S&R triple adjustable Panhard Bar for my 14 GT...any hints on easy install...it looks like a no brainer??
davec is offline   Reply With Quote
Old 05-19-2015, 11:43 AM   #2
olerodder's Avatar
Region: Oregon
I'll bite.
Take the OE panhard out, measure center to center distance and adjust your "triple" adjustable bar to match. Put it in and lower your car off the lift/jackstands. Remember to not support the car under the rear axle, let the axle drop down. It's easier to take the wheels/tires off the car when you do this but you can keep them.
After putting the adjustable bar in, lower your car so the chassis is loaded...........roll it 15/20' and back to set the chassis. Put plumb bobs down each side of the rear quarter panel, make sure the strings pass through the center of the wheel. Measure both sides, subtract the larger number for the smaller number and divide by two. This will give you the amount and direction you need to move the rearend to get it centered under the car. Spec is to have both sides within 1/8" of each other or closer. Each time you adjust the "triple" adjustable bar you need to lower the car and roll it out and back in to set the chassis, and also recheck the measurements to make sure nothing has moved. If all is Ok, put locktite on the threads and torque the nuts down. It is always prudent to take a permanent marker and mark the flats of the lock nuts and extend the line to the panhard bar. This way you can see if anything changes..................just something I've always done in 35+ years of racing..........safety first!
Old 05-19-2015, 11:54 AM   #3
Strange Mud's Avatar
I like the marking idea....
---------- Post added at 01:54 PM ---------- Previous post was at 01:53 PM ----------
Old 05-19-2015, 12:18 PM   #4
K2Steeda's Avatar
What he said
K2Steeda
2014 GT 5.0 Brembo's and 3.73's. FRPP Shifter, Steeda Intake Bama V2 Tune, Accufab 84.5 TB, Borla S-Type, Lethal Over Axel, JBA X, DSS Shaft, Steeda Panhard, Steeda LCA, Koni Streets, K Springs, GT500 Mounts.
2004 Maxima SE Daily Driver
K2Steeda is offline   Reply With Quote
Old 05-19-2015, 12:47 PM   #5
Thanks....I have 20's all around with 275/30x20 on the rears on 10" wheels. Had it lowered by 1 & 1/2 inch and the driver's side is off by about 1/2 to 3/4 of an inch outward from the passenger side.
For Sale: UMI Performance Adjustable Lower Control Arms and Adjustable Panhard Bar BadCon Mustang Parts for Sale and Wanted 8 04-10-2015 12:58 AM
2005-2014 Mustang Panhard Bar Steeda Adjustable - Overview & Installation tj@steeda 2011-2014 Mustang GT 0 01-22-2015 01:11 PM
Adjustable panhard bar mmike87 2011-2014 Mustang GT 23 11-04-2014 04:15 PM
For Sale: H&R Super Sport Lowering Springs for 2011-2014 and Hotchkis Adjustable Panhard Bar sleeperstatus Mustang Parts for Sale and Wanted 12 11-20-2013 06:41 AM
Adjustable panhard bar gtstyles2 2011-2014 Mustang GT 7 10-08-2011 04:05 PM
08:40 AM
