Nitrous - Mustang Evolution
Old 05-18-2015, 08:35 PM   #1
kona stang707's Avatar
Nitrous
Forgive me for asking because I do not know very much about nitrous but would a zex kit for a 86-04 gt be compatible with my 11 gt. If so what could I possibly need to make it work. It is the same as this ZEX Zex Wet Injected Mustang Nitrous System ZEX-82023 (86-04 V8) - Free Shipping I
2011 Kona blue GT.
kona stang707 is offline   Reply With Quote
Old 05-19-2015, 12:48 AM   #2
2011fastford's Avatar
Region: New Mexico
that appears to be a regular fogger kit.. which are essentially universal...
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 05-19-2015, 07:34 AM   #3
Rapinator126's Avatar
It will work, but you will need the proper fuel rail adapter for the coyote. It will be different from the one that comes with this kit.
Also with a single nozzle, placement of the nozzle itself it critical for proper distribution.
Old 05-21-2015, 09:25 PM   #4
So all I need is a fuel rail adapter and get it professionally installed and I'd be ok? What other things would I need to make sure it was safe.
2011 Kona blue GT.
Old 05-21-2015, 09:49 PM   #5
2011 Kona blue GT.
Auto or manual? How much are you looking to spray?
Old 05-21-2015, 09:50 PM   #6
Manual and probably a 100 shot 150 tops more than likely just 100 though.
2011 Kona blue GT.
Old 05-21-2015, 09:54 PM   #7
Just get the fuel rail adapter
Window switch
Bottle heater
Purge
Air fuel gauge
Custom tune
And you will be good for a 100 shot.
If you decide to go 150, then you need to add
Boost a pump
Colder spark plugs.
Old 05-21-2015, 09:57 PM   #8
How much are you getting this kit for?
Old 05-22-2015, 02:53 AM   #9
D1STRRBD's Avatar
Nitrous
You might want to consider a boost-a-pump too.
To late did not see Rapinators last post. Never mind.
D1STRRBD is offline   Reply With Quote
Old 05-22-2015, 10:02 AM   #10
Agent Kree's Avatar
I'm selling my nitrous setup for 11-14 gt if you're interested.
Agent Kree is offline   Reply With Quote
Old 05-23-2015, 11:10 AM   #11
If you want to keep it really simple up to 125hp both BBR and JMS have nice simple dry kit set ups with tunes. If wet, go with a plate kit, once again BBR has a nice NX plate kit with a tune. You MUST have tune for these cars to spray. Ive been running nitrous for years on a lot of different cars and this is the first one Ive had that you cannot tune the spray via pulling timing and the fuel jets, you must have a custom tune for several reasons. I tune mine with HP tuners myself, but have seen the BBR tune and it's done correctly.
IMO for a simple 125 kit daily driver:
1. your brand of choice dry single fogger - screw that trying to hide it in the sound tube bs - use a fixed mounted single dry fogger in your cai tube or stock intake tube
2. window switch - make sure to set nitrous cut off below your pcm hard rev limiter
3. bottle heater - the brackets with the built in heaters are much nicer than the blankets - most of them also have automatic pressure controlled on/off cycles
4. TUNE - tough to beat BBR-Chris Jones on these nitrous tunes
5. You could probably get away with stcok plugs up to 125 hp, just datalog and see whats going on when you spray.
Nater is offline   Reply With Quote
Old 05-24-2015, 12:38 AM   #12
How much would u want for it and what set up is it?
2011 Kona blue GT.
Old 05-24-2015, 06:40 AM   #13
Agent Kree's Avatar
2011 Kona blue GT.
2011+ mustang Gt NX nitrous plate kit
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
getting nitrous MusclesFromBrussels Pre-2005 V6 Mustang 11 08-06-2003 02:43 PM
SC and Nitrous ERICK Pre-2005 V6 Mustang 11 07-21-2003 08:28 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
10:39 AM
