Mystery whine - Mustang Evolution
Old 05-19-2015, 10:50 PM   #1
Sunnycalibear's Avatar
Mystery whine
So I just put in my boss 302R lcas and a week after I noticed I get this random whine from my rear end only in 5th gear between 16-1900 Rpms. Other than that I hear it slightly in 4th. I had 3:55s installed but that was 21k ago. Does anyone have any ideas? I drive this car everyday so I don't want to make things worse and throw myself into a pit. Any advice would help thanks yall!!
Sunnycalibear is offline   Reply With Quote
Old 05-20-2015, 12:39 AM   #2
Also get a vibration from the rear end after 100 mph. Doesn't matter if the car is in gear or not the vibration is still there. Only suspension mods are the lcas, panhard bar, and coil overs. The fronts lowered at 2.5" and the back is just about 1". Stock driveshaft
Old 05-20-2015, 09:26 AM   #3
olerodder's Avatar
Region: Oregon
Just a couple of thoughts. Did you check the center to center distance on the old LCA's and new Boss 302 to make sure they were exactly the same.
With spherical rod ends you are going to transfer the slightest amount of NVH through the body/frame directly to the LCA's and directly to and from the rear end.
Have you checked the balance on you wheels or the run-out of the wheels and or axle.
When you say over 100mph, does the vibration continue or do you go through it at a higher speed.
Have you ever checked the pinion/trans/two piece drive shaft angles.
Just a note; spherical rod ends are great for race cars but for street cars they are just not practical..................IMHO
Old 05-20-2015, 10:49 AM   #4
Yeah the distance is the same I checked it after install. My wheels should be balanced they never gave me the issue before but I am putting on new wheels this week so that shouldn't be a factor. The vibration continues to get worse and worse the faster I go. How would I check the angles on the pinion/trans/driveshaft?
Old 05-20-2015, 10:58 AM   #5
olerodder's Avatar
Region: Oregon
Give this a quick read.
Also, you should really have the car on a 4 post lift so that the chassis is fully loaded when you check the angles. You could do it by jacking the rear up as far as you can get it then put sometype of block under the rear wheels so that the chassis is loaded, this will be ok if you can't get to a 4 post lift.
Google-Ergebnis für http://www.cherod.com/mustang/HowTo/LCA%20_adj_files/image002.jpg
Old 05-24-2015, 06:27 PM   #6
Thank you for the article olerodder! I solved the issue. It was my boss lcas I had on. I guess because they are not adjustable and I am lowered it was knocking off the alignment of everything back there. They came out to be shorter than my stock arms.
who has solved the power steering mystery on the 05's bryanbrock 2005-2010 Mustang GT 3 11-04-2011 08:13 AM
Mystery Mustang redbird2289 1996-2004 Mustang GT 7 09-28-2009 10:07 PM
I alway thought that this was a pretty interesting unsolved mystery JROC The Bar 1 01-03-2008 02:13 PM
Cold Air Intake Mystery chris7869 Pre-2005 V6 Mustang 7 02-10-2007 05:37 PM
Guess the Mystery Celeb 00vertstang The Bar 16 11-02-2004 02:33 PM
11:48 PM
