Best aftermarket rotors and pads - Mustang Evolution
Old 05-20-2015, 10:44 PM   #1
Sunnycalibear's Avatar
I do a lot of daily driving freeway and city and my brakes are due for some maintenance. Wanted to get better pads and possibly rotors for daily driving and racing. Anyone have any ideas? Don't have brembos just the base model brakes.
Sunnycalibear is offline   Reply With Quote
Old 05-20-2015, 11:18 PM   #2
GE3G's Avatar
You can Go with an oem rotor or even a slotted rotor and hawk hps pads all around. Also consider flushing your break fluid with some Good fluid. A.T.E dot 4 is great also pentosin dot 4.
Sent from my SGH-I547C using Mustang Evolution mobile app
GE3G is offline   Reply With Quote
Old 05-20-2015, 11:59 PM   #3
What slotted rotors would be best bang for buck?
Old 05-21-2015, 08:38 AM   #4
olerodder's Avatar
Region: Oregon
If you track your car then get slotted or even dimpled and slotted rotors. If not, just have your rotors turned and use new pads. Flushing the system never hurts and if you have more than 40k miles it would probably be a good idea.
When hauling my race cars with my Dodge Hemi pickup I used
Brake Rotors Brake Discs Drilled Slotted Rotors rotors on all four corners that were dimpled and slotted.
I put over 10,000 miles on these with metallic pads and stopping power was twice what the factory rotors/pads could give me. I had 4500lbs behind the truck and going down 6% grades you want to make sure you can stop at the end..................I also used there rotors on my wife's Venza and will use them on the Mustang when the time comes.
Old 05-21-2015, 09:41 AM   #5
UrMaster's Avatar
Brake motive slotted and drilled rotors. They have good pads or use hawks pads. I've been using their rotors and pads (Brake motive) for years on everything I own and same with some friends cars and trucks. Had them on a 10 second camaro for 2 years no issues, have em on my Denali pulling a 6000 lb boat across state and have them on my Mustang and just did a round trip to TN and back from IL. Never any issues. And you can't beat the price.
http://pages.ebay.com/motors/link/?n...150751&alt=web
Sent from my SM-G925V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 05-22-2015, 05:32 AM   #6
jande063's Avatar
I never recommend slotted or drilled rotors, because they have a nasty habit of catastrophic failure when driven truly hard. I have had good results from Centric blank rotors (excellent venting for better heat dissipation), and a set of HP+ if you don't do anything that is very high intensity (I do not consider drag racing to be braking intensive due to the large time between braking points; I break things like wheel/axle bearings and calipers due to heat on road courses).
I have had good results from the ATE 200 (replacement for super blue). It is not as good as some of the more expensive options, but it is good for the money.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 05-22-2015, 02:56 PM   #7
BEST as in "CHEAPEST"??
Cheapest LINK: (Prices Change, but are low):
Mustang/Cobra Brakes, Speed Concepts
BEST= BREMBO
Old 05-22-2015, 03:15 PM   #8
olerodder's Avatar
Region: Oregon
BEST= BREMBO
The prices for the Brembo upgrade is really good at $700. That means for under $1100 you can have 14" Brembo's up front and GT500 13.8"'s in the rear....with pads.
Exactly what I have on my Mustang.
Old 05-22-2015, 03:28 PM   #9
Thanks for all the input guys. Most likely just going to resurface my rotors and get hawk pads this time. Saving my money towards a driveshaft!
Old 05-22-2015, 03:33 PM   #10
c_rizzle's Avatar
Best... IMO. Is this kit:
Ford Racing Mustang 6 Piston 15" Brake Upgrade Kit w/ 2 Piece Rotors (05-14) 161-M-2300-TA | Free Shipping!
Upgrades:
Front: Brembo calipers + 15" 2-piece rotors, so your overall weight is about the same as the stock rotor/caliper set.
Rear: upgrades to 13.8" rotors
Cons: almost $3k
c_rizzle is offline   Reply With Quote
Old 05-22-2015, 04:11 PM   #11
olerodder's Avatar
Region: Oregon
You can purchase the kit from Ford for $300 less, but beyond that I think for the street it's an overkill............if you mostly track or autocross your car I guess it would be worth the expense, but for $1100 you can have a great street setup with 14" Brembo's in front and 13.8" discs in the rear. With the $1800 left over I could do some really cool suspension stuff or even a Boss 302 intake/tune and LT headers or ????
Spending $1k for two piece rotors for the street is just not practical.....................at least not for me.
Old 05-22-2015, 06:27 PM   #12
The Brembo kit is what i got for the Cobra. Came with 4 rotors, 4 sets of ceramic pads.
I added set of 5 stainless steel breaded brake line kit, rebuild hardware kits, caliper bolts, bunch of Motorcraft HD DOT3 brake fluid.
Old 05-22-2015, 06:49 PM   #13
jande063's Avatar
Even for those of us who run the brutally fast cars in the scary fast classes (ESP cars are a whole different level of fast), the six piston setup is unnecessary. For reasonable length road racing or autocrossing, you NEED to be running an 18'' wheel (19s and 20s just screw you in the corners AND the straights) with room for vents, which means a 14'' rotor. The only time I would recommend a 15" rotor would be for a 24 hour endurance road racing car, and it would not be with those calipers, the only ones I would look at would be the Stoptech ST60 ($3000 for just the calipers, but worth every penny 18 hours in).
New Front Brake pads and rotors? EdinOmaha Pre-2005 V6 Mustang 16 05-01-2012 11:00 AM
Sell: 99-04 PBR calipers pads banjo bolts and rotors silverstangboy Mustang Parts for Sale and Wanted 1 01-31-2011 05:38 PM
brake pads and rotors electricstang Pre-2005 V6 Mustang 18 07-10-2006 03:18 PM
99-04 GT or V6 front calipers with rotors and pads SpectorV Mustang Parts for Sale and Wanted 3 05-27-2005 01:58 PM
Installing Brake Pads and Rotors Mustang414 Pre-2005 V6 Mustang 13 05-21-2005 06:04 PM
02:36 AM
