Low dyno numbers, what could have happened? - Mustang Evolution
Old 05-21-2015, 12:35 PM   #1
Droidman86's Avatar
I ran dyno yesterday for first time, mods are Jon Lund tune, CAI, Cat and resonator delete, gt500 axleback. It made 337 rwhp and 329 rwtq. It was 100 degrees, 73% humidity here in Miami.
Then I did 150 shot, it went up 148 rwhp 171rwtq.
https://youtu.be/haGKajUFhQc
2012 Mustang 5.0
Steeda CAI, Boss Manifold, 3.73 Gears, E85, NX Wet 150 Shot, AED Tuned, LT Headers, Aluminum Driveshaft, Mcleod Twin Disc Clutch, KB Bap, N2MB wot box w/ window switch.
Droidman86 is offline   Reply With Quote
Old 05-21-2015, 01:22 PM   #2
zinc03svt's Avatar
If you were at Ragetek it used to be a low reading dyno. Where was dynoed? What type of dyno?
zinc03svt is offline   Reply With Quote
Old 05-21-2015, 01:23 PM   #3
Droidman86's Avatar
Miami, FL it was a DYNOJET
2012 Mustang 5.0
Old 05-21-2015, 01:26 PM   #4
zinc03svt's Avatar
I would say the heat probably did not help, but that's low humidity for Miami. I used to live there.
---------- Post added at 02:26 PM ---------- Previous post was at 02:26 PM ----------
Nevermind...saw the sig again.
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
Old 05-21-2015, 01:28 PM   #5
Droidman86's Avatar
my bad, it was like 73
Your spraying 150 shot through stock cats?
2012 Mustang 5.0
Old 05-21-2015, 01:32 PM   #6
Rapinator126's Avatar
It's one of 2 things.
1. Verry low reading dyno
2. Something is wrong with the car.
I'm going for dyno though. You are making a little more than 30hp more with your 150 shot then I am on motor alone.
So the dyno calibration is off 90% sure. 10% could possibly be the car.
Old 05-21-2015, 02:20 PM   #7
DWoody's Avatar
Do you have any videos of how your exhaust sounds? I'd love to hear it.
DWoody is offline   Reply With Quote
Old 05-21-2015, 02:55 PM   #8
Grabber Blue5.0's Avatar
Guys put to much faith in dyno numbers. But I'll play.
What gear was it dynoed in?
Old 05-21-2015, 03:00 PM   #9
Droidman86's Avatar
It was done in 5th gear
I don't really care that much about the numbers. Main reason I did dyno was to make sure the 150 show was actually putting down what it advertises and that it would be ready for the track.
2012 Mustang 5.0
Old 05-21-2015, 03:18 PM   #10
D1STRRBD's Avatar
Is your car an auto? You can lose as much as 20% through the auto drive train.
337hp sound like stock auto trans number. But if the dyno is down about 10% and with your mods less the nitrous. The 337hp sound about right.
D1STRRBD is offline   Reply With Quote
Old 05-21-2015, 04:11 PM   #11
These autos do not lose 20% like the old ones and are much more efficient.
And no 337 rwhp doesn't sound even remotely correct.
Old 05-21-2015, 04:19 PM   #12
Droidman86's Avatar
Mine is manual
2012 Mustang 5.0
Old 05-22-2015, 04:57 AM   #13
ncfive0's Avatar
Don't most shops make pulls in 4th gear?
ncfive0 is offline   Reply With Quote
Old 05-22-2015, 05:56 AM   #14
If they do not know what they are doing.
Old 05-22-2015, 06:05 AM   #15
fenixignition's Avatar
i thought you need it in 1:1 gear? which i thought was fourth gear. of course, ive never been to a dyno and i dont have a 6 speed transmission.
2002 GT 5sp. 16x,xxx miles
Old 05-22-2015, 06:08 AM   #16
You do need it in 1:1, which is 5th gear for the mt -82.
Old 05-22-2015, 09:16 AM   #17
Droidman86's Avatar
Exactly what I had to tell everyone at the shop because they would insist I had to do it in 4th.
2012 Mustang 5.0
Old 05-22-2015, 10:44 AM   #18
olerodder's Avatar
Region: Oregon
What RPM were you pulling in 5th?
Old 05-22-2015, 10:48 AM   #19
Droidman86's Avatar
I don't know, it was the performance shop employee. I think he slowly change from 1st to 3rd, then 5th WOT
2012 Mustang 5.0
Old 05-22-2015, 12:49 PM   #20
olerodder's Avatar
Region: Oregon
Do you have the dyno sheet..............it will show the curve in HP/TQ and at what RPM????
Old 05-22-2015, 12:55 PM   #21
All that I have seen was 4th gear don't know about 5th.
Teak 14 is offline   Reply With Quote
Old 05-22-2015, 01:30 PM   #22
Droidman86's Avatar
nitrous numbers were good. However, the nitrous is cutting off for a split second between 4000 and 4200 RPM. I have the window switch setup to run nitrous from 3000 to 6500rpm. I'm currently trying to figure that out with nitrous express and jon lund.
2012 Mustang 5.0
Old 05-22-2015, 01:54 PM   #23
D1STRRBD's Avatar
4th gear dyno pulls are done with the auto trans. It is the closest gear to 1:1 ratio
Old 05-22-2015, 05:26 PM   #24
cjsilen's Avatar
Region: Nebraska
Mine was dynoed in 4th gear, I got 362 trw on cheap 87octane gas ⛽ the first time and I got 368 trw on 93 octane the second time and I was still disapointed, no mods then. I just had a 3 inch Borla racing exhaust installed so I'll be dynoing it soon to see if any gains.
cjsilen is offline   Reply With Quote
Built mach one , low dyno numbers ???? Whtghost1979 1996-2004 Mustang GT 0 04-28-2013 11:40 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
What car would you rather have if you could have either??? 1965 Ford Mustang or 1963 Mercury Comet? colton Classic Mustangs 3 08-29-2009 12:40 PM
r my numbers a little low greg_g70 1996-2004 Mustang GT 27 07-15-2005 06:22 PM
Dyno numbers inside from Amazon Racing.. 03redfire cobra The Bar 19 10-27-2004 05:46 PM
09:52 PM
