Tuner wiped my ecu - Mustang Evolution
Old 05-25-2015, 11:38 AM   #1
Tuner wiped my ecu
Yesterday I went to upload a tune with my Bama sct x4 flash tuner. I took all the necessary steps to do so doing the same thing I'd always do. I turned my car off, plugged in the tuner and followed intrusions on the screen. Everything was going fine, I was really just changing the Rev limit in neutral to a higher rpm setting on the tune that was already on the car. After picking my setting the tune began to write to the car when all of a sudden the car freaked out and in the end the ecu seems to be wiped. When I turn the key now the car just beeps a lot and tells me to service everything, and won't even try to turn over. I can't even pop the trunk. I dont know what happens from here? My car got towed to the dealership but has to sit there until Tuesday before it can be fixed. Is my warranty voided because the tuner wiped it? What's the dealership gonna do to fix this?
ty_5oh is offline   Reply With Quote
Old 05-25-2015, 11:49 AM   #2
natestang07's Avatar
Did you return the car to stock/update the tuner?
Old 05-25-2015, 11:54 AM   #3
Stangholio's Avatar
I remember reading that happened to another guy. He had to send his ecu to Sct I think and they fixed it for him.
GHIGitty
Stangholio is offline   Reply With Quote
Old 05-25-2015, 12:52 PM   #4
Rapinator126's Avatar
Depends on the dealership.
My ECU completely got trashed about a year ago swapping to my nitrous tune. Had to completely replace it.
Chances are this is not what happened to you though. Should have let it sit for about 20 minutes updated the tuner and reloaded the stock tune. Then back to your custom tune.
Old 05-25-2015, 12:53 PM   #5
But the #1 question is why would you change the rev limit in neutral? Rice much
Old 05-25-2015, 01:23 PM   #6
oxford5pointoh's Avatar
Hook line and sinker guys.
IG @Oxford5pointoh
Old 05-25-2015, 01:39 PM   #7
DWoody's Avatar
Seeing as how its his first post, I'm gonna go ahead and say he's f-ing with us. I'm sure he's back on his Honda forum. Or camaro forum. Same thing...
DWoody is offline   Reply With Quote
Old 05-25-2015, 02:37 PM   #8
Agent Kree's Avatar
That happened to me once, I was in the middle of tunning my car and turned it on by accident. It wouldn't turn on at all and all the lights were flashing. I called sct and they sent me a stock tune that forced itself into the ecu, and that solved everything. Car turned on normally after that.
Agent Kree is offline   Reply With Quote
Old 05-25-2015, 05:28 PM   #9
Not f-ing with you. I own a Mustang.
Old 05-25-2015, 05:30 PM   #10
I changed the Rev limit in neutral to act as a launch control. It works and it's free, instead of buying a two step module.
Old 05-25-2015, 05:33 PM   #11
Hopefully I can do that too. Tried calling sct today but it's memorial day so they closed earlier than normal.
Old 05-25-2015, 05:39 PM   #12
Lol
Old 05-25-2015, 05:40 PM   #13
That is by far one of the worst ideas ever.
Old 05-25-2015, 05:43 PM   #14
Grabber Blue5.0's Avatar
This is why everyone should have a saved copy of their stock tune file on their computer.
Old 05-25-2015, 05:47 PM   #15
I have the stock tune, the programmer can't unlock the ecu anymore to get it on there. Everytime I try it just says error.
Old 05-25-2015, 06:41 PM   #16
mustanggt2013's Avatar
Sounds like me.
Had to send in Ecu to them and they unlocked it and put stock tune back on all has been good since.
Sent from my iPad using Tapatalk
mustanggt2013 is offline   Reply With Quote
Old 05-25-2015, 06:41 PM   #17
Jon3.7's Avatar
Did you update your programmer via the downloadable updater from sct?
Sounds like you didn't.
I've had customers do the exact same thing, they buy a super chips or hypertech programmer for their vehicle, and don't listen to me when i tell them to update it before they plug it in.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 05-25-2015, 06:54 PM   #18
Yeah I updated it the day before. I always make sure it's up to date before loading a tune.
Old 05-25-2015, 06:57 PM   #19
Jon3.7's Avatar
it's weird it won't return to stock, did it read the stock file?
Old 05-25-2015, 07:29 PM   #20
Ubnbit's Avatar
You're not serious about neutral dropping your car.
Old 05-25-2015, 07:31 PM   #21
It's a manual, when the Clutch is in and you aren't moving it bounces at 3k rpm and once you dump it it goes back to a 7k Rev limit.
Old 05-26-2015, 04:15 AM   #22
Everything was done right. Even programmer finished uploading file to Ecu and said it was done to start the car but as soon as I turned the key nothing and everything went haywire
Old 05-26-2015, 11:42 AM   #23
olerodder's Avatar
Region: Oregon
Just a question. I thought that when you downloaded a tune you were not supposed to update the programmer through the internet unless you had brought the car back to stock tune. They you would update the programmer and then download the updated program back into the car..................I thought that if you tried to revise the tune that was already in the car after you had updated your programmer on the internet that you would cause an issue...............is this true of false?
Old 05-26-2015, 01:02 PM   #24
b2673ad's Avatar
Hello
Was this a second hand tuner or did you buy it direct from AM/Bama?
Kevin C.
2015 Roush RS1 Premium w PP
Roush Performance upgrade-- Tinted Windows
JLT Catch Can--Ford Racing Strut Brace
Flowmaster scavenger "Y" pipe resonator delete
b2673ad is offline   Reply With Quote
Almost wiped out with a deer on the drive home yesterday... tym_v6 The Bar 7 04-08-2015 05:31 AM
Got wiped out :( Blu13stang Pictures and Videos 21 10-01-2013 12:47 PM
Solution for Locked ECU from SCT Tuner Untamed5.0 2011-2014 Mustang GT 7 07-05-2012 01:23 PM
ECU code FA23...sound right? MUSTANGJUNKY420 Pre-2005 V6 Mustang 6 08-11-2003 04:35 PM
Superchip for ECU # BEH1 MUSTANGJUNKY420 Pre-2005 V6 Mustang 3 08-01-2003 11:31 PM
01:37 AM
