Ticking noise when driving - Mustang Evolution
Old 05-29-2015, 04:54 PM   #1
So I was driving my car today with the windows rolled down.. I herd a ticking noise.. kinda like taking 2 pics of aluminum and tapping them together. Put the car in neutral and coasted and the motor rpm has no effect on it.. but speed does. Brakes bad? Aftermarket 20" tires with 305 rubbing?
brett.fries23 is offline   Reply With Quote
Old 05-29-2015, 04:56 PM   #2
Kevin.Cook
Guest
Posts: n/a
Some people mentioned their breather valve on the differential causing this. One person found a sticker on their driveshaft causing this. Could be other things depending on what area it is actually coming from. Have you tried to get a buddy to cruise next to your and see if it is coming from the rear or front?
Old 05-29-2015, 04:59 PM   #3
My buddie who works at vw is gonna ride with me.. I'll try having him ride next to me on his bike.. but it's annoying and need it fixed. Like I said sounds exactly like 2 pieces of aluminum clicking
Old 05-29-2015, 05:02 PM   #4
Kevin.Cook
Guest
Posts: n/a
Yup. And its annoying. I have a sound like that but its because i installed shorty headers. So i am still isolating it.
First need to figure out a general area where it might be coming from.
Old 05-29-2015, 05:10 PM   #5
Yeah well hope I can get her done.. thanks for the help
Old 05-30-2015, 04:06 AM   #6
Strange Mud's Avatar
outside the box
we used to mess with buddies and put a tie-wrap around their drive shaft...every revolution it would hit.
did you remove the brake retaining clips?
can you put the oems back on to see if that is issue?
Old 05-30-2015, 09:01 AM   #7
If it comes down to it I'll throw them on.. and no I don't even know what these clips are lol
Old 05-30-2015, 09:35 AM   #8
small retaining clips (star washers) on studs that hold the brake disc on for assembly. OEM rims have indents but aftermarket rims often don't. If yours are still on (1 per wheel) pull them off.
Old 05-30-2015, 09:37 AM   #9
If they are on could that be the ticking
Old 05-31-2015, 03:05 PM   #10
Waynes World's Avatar
Region: Utah
check for a screw in your tire, i had a roofing screw in a tire and it sounds like that.
Waynes World is offline   Reply With Quote
Old 05-31-2015, 03:06 PM   #11
Well I hit the brakes and it went away so I pulled my ebrake and that also made it go away so I think it's the rear brakes
Old 06-01-2015, 03:32 AM   #12
try greasing the backs of the pads and the caliper pins
2013 Hooked on Driving/Camp Steeda Driving Event tj@steeda General Mustang Discussion 3 04-24-2013 06:31 AM
engine making belt noise engine ticking sounds like a diesel 3k miles on car Yellow50 2011-2014 Mustang GT 34 05-04-2012 09:56 AM
Ticking Noise Cervantes107 1996-2004 Mustang GT 4 02-02-2012 09:02 PM
Ticking type noise back n a stang 2011-2014 Mustang GT 0 01-07-2012 10:19 AM
Ticking noise in the engine.... eNvy Pre-2005 V6 Mustang 11 05-09-2004 11:41 AM
04:19 AM
