Issue after Installing CJ intake - Mustang Evolution
Old 06-02-2015, 02:04 AM   #1
Region: Asia
There is a code P0457 ( Evaporative emission system leak detected fuel cap loose/ off) and message says check fuel fill inlet After installing the CJ intake. Any suggestions are welcome.
Thanks
MooDy5.0 is offline   Reply With Quote
Old 06-02-2015, 02:33 AM   #2
natestang07's Avatar
Have you checked your fuel cap? Lol
Old 06-02-2015, 02:34 AM   #3
Region: Asia
yes it's normal
Old 06-02-2015, 02:37 AM   #4
Was it normal to begin with? If it was loose and you tightened it the code will stay on for awhile
Old 06-02-2015, 02:43 AM   #5
Region: Asia
it's showing up since 2 weeks !!
Old 06-02-2015, 02:48 AM   #6
Hm, maybe the intake isn't seated properly?
Old 06-02-2015, 04:31 AM   #7
Region: Asia
how can i know if it seated properly or not??
Thanks
Old 06-02-2015, 05:45 AM   #8
Grabber Blue5.0's Avatar
What did you do with the purge valve?
Old 06-02-2015, 05:54 AM   #9
Region: Asia
actually i don't know , the mechanic guy installed it.
what should i do with it?
Old 06-02-2015, 07:11 AM   #10
DWoody's Avatar
You had it installed by a mechanic? Why wouldn't your first thought be to take it back to the guy that installed it?
DWoody is offline   Reply With Quote
Old 06-02-2015, 08:49 AM   #11
Voltwings's Avatar
The issue is the purge valve, not the gas cap. Do you have the means to datalog the vehicle? You can both digitally and visually check for leaks, but that is going to be your issue.
Old 06-02-2015, 08:57 AM   #12
zinc03svt's Avatar
Yep, 99% sure he either did not hook up your purge or did not connect it correctly. I just installed mine 3 weeks ago. I hope you did not use the Ford boss install kit...
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 06-02-2015, 09:00 AM   #13
Waylap1's Avatar
Region: New Hampshire
CAI....does nothing, costs a lot. Creates faults for you to try to resolve because you don't have enough to do anyway and let's face it....who wants a perfectly running Mustang with a factory CAI.
Waylap1 is offline   Reply With Quote
Old 06-02-2015, 09:03 AM   #14
zinc03svt's Avatar
Cannot run factory box with CJ Waylap...
Old 06-02-2015, 09:06 AM   #15
Voltwings's Avatar
Willing to bet the 5" intake and 1500 CFM filter on my CJ does something
Old 06-02-2015, 09:14 AM   #16
Rapinator126's Avatar
Stop repeating what you see on here. The whole CAI no gain BS is BS at that. It all depends on your application. Can't relate it to every build
Old 06-02-2015, 09:18 AM   #17
But OP your issue is your purge valve
Old 06-02-2015, 09:46 AM   #18
All he does is say something about the "hot air intake" as he calls it every chance he gets. It's about as annoying as it can get.
tidecrazy3193 is offline   Reply With Quote
Old 06-11-2015, 08:24 PM   #19
WhiteCali5oh's Avatar
Region: West Virgina
A cai won't add as much hp n/a as it would once you go forced induction. That is true. They will add power like rap said it just depends on your application.
WhiteCali5oh is offline   Reply With Quote
Old 06-11-2015, 08:44 PM   #20
Mechanic probably didn't hook up the purge valve because the connector wont reach and didn't want to cut and splice.
Turd Fergusen is offline   Reply With Quote
Old 06-12-2015, 07:58 PM   #21
Oh I agree. It's just tedious listening to him (and other people) rattle of that same line over and over.
Old 06-22-2015, 08:41 PM   #22
ResilientMidget's Avatar
I agree with Turd Ferguson. The mechanic probably thought it was as simple as bolting on the parts and giving the car back to you. You did purchase the boss intake manifold intstall kit right (or relocated the purge valve some other way?). I have heard that the code/light is just a nuisance, you don't have to worry about any damage being done to your engine FYI.
2014 GT Premium. Cobra Jet Intake with monoblade throttle body and FRPP CAI. Ford Racing Sport axle backs. Pypes off road H pipe. Numerous appearance mods, it was a plain blue Mustang when I bought it.
ResilientMidget is offline   Reply With Quote
Old 07-26-2015, 03:51 AM   #23
How does the line reach I just bolted my valve to the block and used hose from the Intake to the valve. But the purge line doesn't reach now I don't know what to do.
bigslick440 is offline   Reply With Quote
Old 07-26-2015, 03:56 AM   #24
Strange Mud's Avatar
you are going to have to cut and splice in an extension piece...the original mechanic needs to be given a chance to fix it or $ back.
Old 07-26-2015, 04:00 AM   #25
It doesn't say anything about cutting and splicing in the late model restoration instructions it just says to used their kit. Which is hose a couple clamps and the bolt to attach it to the block
At first I Just plugged up the valve that was sucking vacuum. But the check engine light came on.
So I don't know how to get that purge line to reach under the throttl. Body all the way from. Where it's attached to the driver side strut mount.
Old 07-26-2015, 06:58 PM   #26
bazinga11's Avatar
I had this same code come on for me yesterday, got boss installed at a local shop. He didn't take out the purge value from stock intake..its literally 2 bolts. Follow LMR instructions and it be good to go.
Sent from my SGH-I337M using Mustang Evolution mobile app
Problems after installing spark plugs Mustangreazon50 2011-2014 Mustang GT 38 10-21-2013 10:17 PM
Do i need a Wheel alignment after installing new wheels Mdazi 2011-2014 Mustang GT 8 05-29-2013 02:50 PM
Tuning after installing a CAI bob1726 2005-2010 Mustang GT 3 08-09-2012 06:48 PM
Help installing an after market head unit 07AlloyPony 2005-2010 V6 Mustang 1 06-16-2012 05:14 PM
dash lights out after installing aftermarket radio vblic 1996-2004 Mustang GT 3 08-10-2007 05:46 PM
04:23 PM
