Start up Sound - Mustang Evolution
Old 06-03-2015, 06:56 PM   #1
Renuco612's Avatar
Start up Sound
I'm sorry if this is a stupid question. Can someone explain the sound that I hear coming from under the hood or under the car after I start it up after a cold start. It sound like something g adjusting itself or screeching sound. It goes on for a couple seconds then goes away.
Maybe I should record it so yall can hear it.
Renuco612 is offline   Reply With Quote
Old 06-03-2015, 07:51 PM   #2
HKBlue50's Avatar
You should not hear a screech when you first start up. Might be time for a trip to the dealer if you are still under warranty.
HKBlue50 is offline   Reply With Quote
Old 06-03-2015, 08:24 PM   #3
Renuco612's Avatar
Screeching I think would be the wrong term. I can't exactly describe the sound. I going to have to wait until tomorrow morning to record the sound.
Old 06-03-2015, 10:03 PM   #4
Waylap1's Avatar
Region: New Hampshire
Sounds like you're describing a power steering pump or pulley bearings. Common on Ford 4.6, 5.0 and 5.4 V8s. Happens mostly right at startup especially when cold out. Goes away after 30 seconds or so.
Just record yourself imitating the sound and post it...should make it clear to us then.
Waylap1 is offline   Reply With Quote
Old 06-04-2015, 08:05 AM   #5
Strange Mud's Avatar
does it come on when you put the key to position 2 (run not start)? mayhap fuel pump/vents adjusting. neither of those should be a screech like a bearing but they will make noise.
Old 06-04-2015, 10:29 PM   #6
Renuco612's Avatar
https://youtu.be/YFCmEHCAIBs
Here is quick clip. The sound goes on at 28 seconds.
Old 06-04-2015, 10:38 PM   #7
oxford5pointoh's Avatar
Mine does the EXACT same thing.
IG @Oxford5pointoh
Old 06-04-2015, 11:07 PM   #8
Renuco612's Avatar
IG @Oxford5pointoh
What sound is it? Only on cold starts right?
Old 06-05-2015, 12:24 AM   #9
Waylap1's Avatar
Something with the HVAC system maybe? You may need to try starting it cold with the HVAC system off or in different settings to confirm or eliminate that as a cause.
Old 06-05-2015, 03:34 AM   #10
Renuco612's Avatar
So I'm guessing yours doesn't make that sound?
Old 06-05-2015, 03:51 AM   #11
bucko's Avatar
At the 28 second mark, all I heard was that your fast idle dropped off to the warmed idle.
On cold starts, the engine ECU/PCM sets the idle (and fuel/air mapping) higher, and then reads the engine temp sensor. Once the engine temp sensor reaches a pre-assigned setting, the ECU/PCM changes the idle and air/fuel mapping so that the engine now idles at its normal setting.
Old 06-06-2015, 11:16 PM   #12
bazinga11's Avatar
I have this same exact noise on cold start ups, goes away when rpms come down. Its more like when you rub a spoon on marble floor or metal on metal.. Idk you know what I mean.
Now is this completely normal, or if this is a result of a mechanical problem?
|| Low 5oh ||
Old 06-07-2015, 04:42 AM   #13
It sounded to me with my cheap desktop speakers like some type of rattle that mine makes a lot of various ones. Keyed on by the high/low idle rpm change over.
Old 06-07-2015, 06:18 AM   #14
Yeah exactly. And it's really loud in the garage (which is where the cold starts usually happen) but it's harder to hear in the parking lot at work when it's quitting time. I thing it's the exhaust honestly.
IG @Oxford5pointoh
Old 06-07-2015, 06:20 AM   #15
Not a factor. At least with mine. I drive windows down and hvac off most of the time. So it's usually off when the car is started.
IG @Oxford5pointoh
Old 06-07-2015, 08:56 AM   #16
Renuco612's Avatar
IG @Oxford5pointoh
Yeah I think so too. It goes away after startup and comes back every so often when the car is still at low temp. After about 5 to 10 minutes of driving it's gone.
Remote start/push to start GT_Man 2011-2014 Mustang GT 9 01-31-2015 11:57 PM
Thought I'd share pics of my successful Push-to-Start/Remote start install! Jordan.Cortina General Mustang Discussion 32 01-30-2015 08:29 AM
V6 start-up signature sound, replicate? ArtU 2011-2014 V6 Mustang 1 02-16-2013 09:44 PM
grind sound on start up austinknoll Pre-2005 V6 Mustang 6 12-16-2011 11:46 PM
Wineing start sound liveAstang Pre-2005 V6 Mustang 1 08-24-2004 04:29 PM
01:01 AM
