h&r super sport suspension with 20" wheels will they rub ? - Mustang Evolution
Old 06-07-2015, 11:18 PM   #1
I am looking to purchase 20" wheels 20x9 in the front and 20x10.5 in the rear for my 2014 mustang gt and i am thinking about lowering it on h&r super sport lowering springs and I'm wondering if they will rub or not, the springs drop the car about 1.7" in the front and 2.4" in the rear
karanvirgill5.0 is offline   Reply With Quote
Old 06-08-2015, 08:55 AM   #2
The_Chech's Avatar
You won't, I just wouldn't go more then a 315 in the rear depending on your off set of your wheels I'm a little over 2.5" in the rear and do not rub Click image for larger version
Name:	ImageUploadedByMustang Evolution1433775305.309876.jpg
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 06-08-2015, 02:18 PM   #3
Socal Stangman's Avatar
You might. 2.4" is really slamming it. Make sure to get the proper offset on your wheels. Youre going to want at least +45. I was told that for a 10.5" wheel on our cars you need +52...do your homework.
Old 06-08-2015, 08:20 PM   #4
20bmr14's Avatar
H&R "states" a 1.7 and 2.4 drop but that is extreme. 20's are perfect with these springs, you will love them. I called tirebuyer.com and they did the homework/math for me and everything turned out perfect.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 06-09-2015, 09:14 AM   #5
hctr154's Avatar
How does that ride Chech?
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 06-09-2015, 09:29 AM   #6
Voltwings's Avatar
your wheel diameter makes zero difference on what will and will not rub, its the overall tire height that matters.
You can have the stock ... what is it 235 / 55 / 18, which is a 28" tall tire.
You can also have a 245 / 45 / 19 which is just under 28" tall
You can have a 245 / 40 / 20 which is also just under 28" tall
Makes no difference, just check the height of the tires you want. Obviously this speaks nothing for strut clearance and all that, my comment is strictly in regards to height.
Old 06-09-2015, 10:05 AM   #7
What about 255/35/20 and 305/30/20 will they rub or would 255/35/20 and 275/35/20 ? which would be better because I am trying to get wide tires in the back but not too wide I'm trying to buy wheels and tires and lowering springs all together
Old 06-09-2015, 12:26 PM   #8
The_Chech's Avatar
It rides really well actually, and I put my car through its paces too. I plan on lowering the rear a bit more for some upcoming shows here soon as well just to get the rear tires tucked.
Old 06-09-2015, 12:30 PM   #9
The_Chech's Avatar
The only way I see that rubbing is if you lower the car and don't adjust your panhard bar to compensate for the axle moving under the body.
I'm personally running a 305/35/20 in the rear on a 20x10 and have had zero issues.
Old 06-22-2015, 10:28 PM   #10
the rear wheel offset is +45mm and the front is +35mm do you think ill be fine ? i also don't want tires that are going to be super skinny that if they do get damage that they hurt the rim
Old 06-30-2015, 09:47 PM   #11
k1DBLITZ's Avatar
Are those Vossen CV3's?
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 07-14-2015, 10:06 PM   #12
no velgen vmb5
Old 07-15-2015, 06:31 AM   #13
k1DBLITZ's Avatar
no velgen vmb5
My bad, I was referring to The_Chech's wheels.
Old 07-16-2015, 06:53 PM   #14
The_Chech's Avatar
They are not, they're the MMD 551c's. They discontinued the silver ones in 20's though.
H&r super sport vs eibach pro kit huhalbert 2011-2014 Mustang GT 10 10-29-2012 04:33 PM
Selling brand new in box h&r super sport springs Nate98stang Mustang Parts for Sale and Wanted 23 10-05-2012 05:24 PM
What were Super Heros before they were super? Seph The Bar 0 06-21-2005 11:29 PM
03:54 PM
