Hood vibrating at high speeds - Mustang Evolution
Old 06-11-2015, 03:54 PM   #1
Eric5oh's Avatar
2013 GT. 38k miles on it. This started happening to me recently while accelerating at any rate past 80mph and gets more violent as I keep going. I have no what idea what this could be and its kinda scary because it feels like the whole front of the car is vibrating. Anyone heard of this?
2013 Sterling Grey GT/Brembo package/SR Performance lowering springs/J&M adjustable panhard bar/Roush axle back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 06-11-2015, 03:55 PM   #2
Kevin.Cook
Guest
Posts: n/a
Are you sure it's the hood or just the front end in general?
Old 06-11-2015, 03:57 PM   #3
bigmac3's Avatar
Have your tires balanced.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 06-11-2015, 04:03 PM   #4
Kevin.Cook
Guest
Posts: n/a
That is what i was going to suggest. Lol
Old 06-11-2015, 04:12 PM   #5
Strange Mud's Avatar
threw a wheel weight? Inspect your tires
Have you changed ANYTHING?
Strange Mud is online now   Reply With Quote
Old 06-11-2015, 04:22 PM   #6
Eric5oh's Avatar
Haven't changed a thing. Maybe threw a weight but would something as small as that cause this much of a vibration? And from the hood?
100% the hood I watch it vibrate up and down more and more as I go faster
Maybe so
Old 06-11-2015, 05:41 PM   #7
DWoody's Avatar
You would be shocked at how much vibration that can be caused by a single wheel weight depending on how big it is. And some serious vibration from just one wheel could absolutely make your hood shake. I'd start by taking it to a tire place to have them rotated and/or rebalanced. That would be the cheapest and easiest thing to check.
DWoody is offline   Reply With Quote
Old 06-11-2015, 06:32 PM   #8
Eric5oh's Avatar
Thanks I appreciate it
Old 06-11-2015, 07:12 PM   #9
Tominkc's Avatar
Send a message via Yahoo to Tominkc
Could also be a bad tire! I've had a tire go bad with a belt in the tire break and causes the tire to just be a little out of round and it will shake the whole car so bad you'd think the car was falling apart!!
Tominkc is offline   Reply With Quote
Old 06-14-2015, 09:26 AM   #10
Eric5oh's Avatar
I'm still having this problem. It's not the wheel balancing and the hood isn't loose at all. Starting to get pissed because I can't drive my 2013 Mustang Gt past 80mph without it shaking like a piece of ****
Old 06-14-2015, 11:11 AM   #11
DWoody's Avatar
On the bright side though, it could keep you from getting a nasty ticket. 2013 5.0 with the governor set at 80mph...
Old 06-14-2015, 11:14 AM   #12
DWoody's Avatar
Probably a stupid question but have you checked the hood latch and made sure that the hood is closed all the way and made sure that it's actually latching? What about the little rubber hood adjuster bumpers? Can you loosen them up a bit to make your hood sit tighter to the car?
Old 06-14-2015, 12:18 PM   #13
Tominkc's Avatar
I'm serious! Check tire for roundness!! A bad tire well do exactly what your say it's doing!!
Old 06-14-2015, 04:44 PM   #14
Eric5oh's Avatar
Okay what do you mean by roundness lol and it doesn't explain why the ride is completely smooth and normal up to 75-80 mph
I have checked the latch and the rubber stoppers but someone told me I might have not adjusted them enough
Old 06-14-2015, 07:02 PM   #15
Tominkc's Avatar
As i said before! Had a belt in the tire that broke and caused the tire to be out of round! Had it happen to me. It depends how bad it is!' If it's just started it hasn't separated enough to in the tire to really show until faster speeds! If really bad, you'll notice it doing just 5mph
Old 06-15-2015, 10:40 AM   #16
Region: Asia
Check under the car ، it's the engine cover Maybe broke
MooDy5.0 is offline   Reply With Quote
Old 06-18-2015, 04:59 PM   #17
I know that feeling same thing happened to me. The problem on mine was the bumper bein loose cause the tabs on the wind deflector under the car broke n they help hold the bumper. After the dealership replaced that part the hood didn't shake anymore.
13racered is offline   Reply With Quote
Old 06-18-2015, 08:47 PM   #18
Eric5oh's Avatar
What part? This could be my problem because my front bumper does seem a little loose
Old 06-19-2015, 07:11 AM   #19
I can't remember what the part was called exactly either splash shield or wind deflector but it's the part that under the bumper between the bumper n splitter. Basically the shield that's under the radiator. It has screws that help hold the bumper in place at high speeds.
Old 06-19-2015, 10:24 AM   #20
Eric5oh's Avatar
Yeaaaaa I think I might have lost some of those screws/push tabs while taking my bumper on and off multiple times.
Old 06-19-2015, 10:26 AM   #21
Eric5oh's Avatar
Let me make a correction: my wind deflector is not hanging off so it must be that
Old 06-19-2015, 01:14 PM   #22
Yeah I'm pretty sure now that ur bumper is loose like mine was. I couldn't believe a loose bumper could cause my hood to shake like it did. Hopefully u get ur fixed soon. I know how it feels to not be able to drive over 80 without the hood shaking.
---------- Post added at 02:14 PM ---------- Previous post was at 02:14 PM ----------
Old 06-25-2015, 06:32 PM   #23
Eric5oh's Avatar
Okay I solved the problem myself. I'm happy I did because I would have been paying them to put 2 screws in the splash gaurd to keep it from hanging. At first I thought this little solution couldn't be the fix to such a big problem but I was wrong. Took the car up to 80 and drives as smooth as ever. It just goes to show how crazy it is that 2 little screws holding a piece of plastic can throw the car off like that at high speeds. Thanks for the help guys
Rear swaying at high speeds... Mustang32Bill 2011-2014 Mustang GT 10 11-22-2014 09:20 PM
Rattling at High Speeds VTHokiez 2011-2014 V6 Mustang 10 10-28-2014 04:54 PM
Vibrating clutch peddle Mike SVOR Pre-2005 V6 Mustang 5 08-23-2012 10:51 PM
Loud vibrating noise!!! Blackstang 1979-1995 Mustang GT 30 10-29-2011 09:56 PM
Vibrating Noise Problem Dan0066 Pre-2005 V6 Mustang 4 06-11-2006 11:53 AM
07:44 AM
