E85 conversion - Mustang Evolution
Old 06-11-2015, 10:19 PM   #1
Sunnycalibear's Avatar
E85 conversion
What do I need to swap out to run on flex fuel? I want to be able to run both e85 and 91. It would be nice to be eco friendly in a v8 😄
Sunnycalibear is offline   Reply With Quote
Old 06-11-2015, 10:28 PM   #2
47 lb injectors and a tune for E85. You will have to swap tunes each time you go from 91 to E85, or vice versa.
Old 06-11-2015, 11:16 PM   #3
There's no need to change the fuel pump?
Old 06-12-2015, 09:58 AM   #4
hctr154's Avatar
Fuel pump is fine. All you need is 47 lb injectors and a tune. Obviously, you'll need a tuner/programer if you don't already have one.
You will also need to perform a couple of data logs so you're tuner can get the tune customized for your particular car.
Good luck!
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 06-12-2015, 11:02 AM   #5
Good luck!
Sick! I thought I would need to change fuel lines as well. Thanks!
Old 06-12-2015, 11:26 AM   #6
Anyone have any recommendations on 47lb injectors?
Old 06-13-2015, 01:22 AM   #7
bazinga11's Avatar
Ford racing. Inexpensive and work great.
|| Low 5oh ||
Old 06-13-2015, 03:31 PM   #8
|| Low 5oh ||
Yeah I'm gonna go with FRPP lu47s. Is e85 corrosive though? Would it cause any other problems like to my lines or plugs?
Old 06-13-2015, 04:02 PM   #9
bazinga11's Avatar
Nope, you're safe! Just make sure you're running good quality E85, that's all.
|| Low 5oh ||
Old 06-13-2015, 04:12 PM   #10
Lucky y'all. VA only has 1 E85 station... and it's out in Charlottesville.
Old 06-13-2015, 04:47 PM   #11
Rapinator126's Avatar
Just don't let your car sit for a long period of time with e85 in the tank. 2+ months.
Old 06-16-2015, 07:55 PM   #12
Make sure not to mix the fuels when filling up. You'll need to empty the tank every time you want to change fuels.
KushBandit is offline   Reply With Quote
Old 06-16-2015, 10:31 PM   #13
Sounds good! Thank you everyone for the feedback
Old 06-20-2015, 12:51 AM   #14
Kustumb's Avatar
Any specific benefit to swapping over?
Kustumb is offline   Reply With Quote
Old 06-20-2015, 12:57 AM   #15
Engine runs cooler
Allows for more timing to be added
In a sports car the pros outweigh the cons. Only thing is you use about 30% more so mpg goes down and it's hard to find in some areas.
Old 06-21-2015, 01:43 PM   #16
Region: New Mexico
How much more power can you make with a tune over a tune for 91-93?
It seems like if it's that easy replacing the injectors might be worth it.
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 06-21-2015, 02:52 PM   #17
hctr154's Avatar
I didn't dyno mine so can't say for sure. Your tuner should be able to look at your datalogs and take a good guess.
Regardless, my exhaust doesn't smell stinky anymore. ...
2013 GT A6
Old 06-21-2015, 03:47 PM   #18
Region: New Mexico
I guess I'm wondering if it's worth the coast of changing the injectors over.
I "eventually" plan on FI so then I know it'd be worth it but what about in the mean time?
Old 06-21-2015, 03:57 PM   #19
hctr154's Avatar
If e85 is readily available in your area, then switching isn't a big deal.
Most tuners will give you a 93 or 91 octane tune with your e85 tune. So if you're not happy with the corn stuff just switch tunes.
Used 47lb injectors are always on Craigslist. ..I believe they are OEM on GT 500s.
2013 GT A6
E85 conversion Mweigt07 2011-2014 Mustang GT 7 09-18-2012 07:13 PM
E85 302fritz 1979-1995 Mustang GT 40 01-30-2011 11:06 AM
E85 testing on NA 08 Mustang GT 4.6L 3V justin00stang 1996-2004 Mustang GT 8 07-30-2008 01:49 PM
Anyone heard of E85? Dom The Bar 5 04-27-2006 12:20 PM
Has anyone filled up with E85 105 Octane gas? Vash Pre-2005 V6 Mustang 5 01-05-2006 08:08 AM
11:16 PM
