Differential leak - Mustang Evolution
Old 06-13-2015, 01:02 PM   #1
stangbaby13's Avatar
Differential leak
Name:	ImageUploadedByMustang Evolution1434221894.334469.jpg
Anyone have a problem like this? My car is a 2014 GT with only 22k miles on it. When I drive in somewhat low speeds the car rocks back and forth somewhat extreme. There is a popping noise that comes from the bottom of the car (most likely the driveshaft) when I let off the gas and press the clutch, this noise also happens when going up a hill, and when reversing the car.
Anyone know if this can be the cause? Click image for larger version
Name:	ImageUploadedByMustang Evolution1434222101.318420.jpg
ID:	184762Click image for larger version
Name:	ImageUploadedByMustang Evolution1434222138.651933.jpg
stangbaby13 is offline   Reply With Quote
Old 06-13-2015, 02:09 PM   #2
Is it the pinion seal leaking? That's an easy fix. Warranty.
litfuse is offline   Reply With Quote
Old 06-13-2015, 02:48 PM   #3
Psmith129's Avatar
The first picture looks very normal , here is a hole in the top of the axle that releases fluid pressure . Mine looks very similar . The differential leak is a different story though .
Psmith129 is offline   Reply With Quote
Old 06-13-2015, 04:01 PM   #4
2014oxstang's Avatar
There's another thread about this, I saw fluid on my axle as well and bought the bleeder hose from ford. Can't remember the part number, but we're A-OK now
2014oxstang is offline   Reply With Quote
Old 06-13-2015, 07:58 PM   #5
oxford5pointoh's Avatar
Yeah there is a replacement breather out there apparently. Mine leaks like that as well. Just need to take it in.
IG @Oxford5pointoh
Old 06-13-2015, 08:24 PM   #6
We're there any noises? Like knocking with the drive shaft or anything?
Old 06-13-2015, 09:49 PM   #7
HKBlue50's Avatar
I had the same issue on my 12. Took it in and got the new breather. The tech over the phone said some fluid is normal but not enough to cover the housing.
As for the question about knocking yes that is what made me look under the car. After the repair you may still hear some noise just have them check the fluid level and add some friction modifier.
HKBlue50 is offline   Reply With Quote
Old 06-13-2015, 11:01 PM   #8
olerodder's Avatar
Region: Oregon
I just had my 14 TrakPak with 7800 miles in the shop last week with a blown pinion seal. The mechanic said it's pretty common and that there is a new "improved" pinion seal which he put in. The old one is just plastic, the new one is metal.
Mine didn't look that bad though. When we had on the lift you could see where the oil had been thrown up on the gas tank on both sides and it was dripping a little at the front of the rear end. When we had it on the lift I actually pushed the seal back in and then drove 100 miles back home..............it's fixed now.
As for the noise. I may have had the same noise, when shifting, starting out from a stop light.........kind of clunking noise and sometime worse than others. I just attributed it the 2 piece drive and maybe the center universal joint. Now that I have a one piece drive line I don't hear it anymore. What I do hear now is a very definite whine around 2000rpm till about 3000rpm. I took the mechanic for a ride this past week and he is not sure if it's the rear end or transmission. This next week we are going to put it back on the dealer's lift and run the car through the gears to see if they can determine where it is coming from.
I love solving (FFPP's) Ford Factory Production Problems.
Old 06-13-2015, 11:22 PM   #9
olerodder's Avatar
Region: Oregon
I forgot to post the pictures I took, but they don't show the pinion. You can see the oil that has been thrown to the left on the gas tank.
Name:	Leaking pinion1.jpg
ID:	184834   Click image for larger version
Name:	Leaking pinion.jpg
Old 06-14-2015, 06:59 AM   #10
zinc03svt's Avatar
Check your tsb's. I had the expansion hose put on mine late last year. After my first trip to the track it was leaking just a little. Easy fix if its just coming out the drain hole on top.
zinc03svt is offline   Reply With Quote
Old 06-14-2015, 09:40 AM   #11
Negative. I saw the leak when I was under the car one day, googled the issue, and came upon the breather solution and figured it was a no brainer. I believe I paid under 15$ for the part.
Old 07-27-2015, 06:43 AM   #12
nicholasmadill's Avatar
How often are you suppose to change the diff fluid in these 5.0's. I went in for an oil change last week and they tried suckering me into it for another $100. They say it's suppose to be changed every 38,000 km or about 25,000 miles
Sent from my iPhone using Mu
nicholasmadill is offline   Reply With Quote
Old 07-27-2015, 07:18 AM   #13
I usually do every two years or 30k miles.
Differential Leak v8pony 1996-2004 Mustang GT 40 06-27-2013 06:35 AM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Auburn Gear ECTED Differential 1995GT306CI 1979-1995 Mustang GT 1 09-24-2004 12:43 PM
how much differential fluid does a mustang hold? Horse Pre-2005 V6 Mustang 5 12-26-2003 02:45 PM
broke my differential, btw long time since i've been back Testicleez The Bar 0 11-05-2003 09:24 AM
02:39 AM
