Barton question - Mustang Evolution
Old 06-14-2015, 04:49 PM   #1
Barton question
Just did the shifter install. Is it me or does 1st gear feel more away and a lil harder to get into with this shifter then stock? any imput would help
EDIT: In a really noob move and from being in a rush, i didnt notice the part where if i have a 2013 mustang i need to take the screw out on the Barton and spin the unit to the 2013 side....... what a moron move.....anyway works great now lmao
Jstorm is offline   Reply With Quote
Old 06-14-2015, 05:08 PM   #2
Famine's Avatar
Region: South Dakota
Are you sure you installed it correctly? I haven't done it myself yet, but I thought I heard others that installed it incorrectly claim similar things.
Famine is offline   Reply With Quote
Old 06-14-2015, 05:12 PM   #3
i dont see anything i could have gotten wrong. Made sure the clip was on made sure the boot was seated around the bottom. bolts tight. It shift thru all the gears. just feels really close together and has like no wiggle room for mistakes , When i took off the stock one i noticed when i shift to first it was up against the wall on the shifter box, the barton going into first is not ,,,
Old 06-16-2015, 08:57 AM   #4
BigBry0311's Avatar
I have the barton and bracket.
Did you buy the bracket for the trans with the shifter, or just the shifter alone? I would Highly advise that you buy the Stainless steel braided clutch line too, it makes the shifts so much smoother. Had I have known how much of a difference the braided line makes I would have done it when I did my shifter and bracket. This is how Ford should have built all of the 11-14 stangs, instead of the nylon clutch line and horrible trans mounting bracket.
BOSS intake, Steeda CAI, SCT livewire TS, A.R. long tubes & 3" X-pipe, Bassani axle back, AMR wheels, Steeda upper&lower control arms, Raxiom Black Projector/HALO headlights, Trufiber hood, CS/BOSS front & rear valence, BOSS splitter, Stainless Braided Clutch Line, TruCarbon CF Grille, MMD Black tail light trim & Trunk Emblem Surround, Carbon Fiber Dash Overlay Kit. Barton Industries Short Shifter and Bracket, DSS 3.5" Aluminum driveshaft. 417 HP 373 lbsft at wheels and loving it.
BigBry0311 is offline   Reply With Quote
Old 06-16-2015, 09:01 AM   #5
Yea I got the 2 post bracket too.... gonna do the line but I'm still trying to figure out why I have a grind from 2nd to 3rd under hard shifts
Old 06-16-2015, 02:38 PM   #6
Member
Ya I have a grind going into 5th on hard shifts under 1850 rpm.
Sent from my SAMSUNG-SM-G920A using Tapatalk
crbauhs is offline   Reply With Quote
Old 06-16-2015, 02:44 PM   #7
Naw I get when I shift over 6500 from 2nd to 3rd that's it
Old 06-16-2015, 02:45 PM   #8
Member
Interesting.
Barton bracket question. MrMike 2011-2014 V6 Mustang 12 04-12-2014 09:54 PM
Barton shifter bracket question. FastFord13 2011-2014 V6 Mustang 6 07-07-2013 02:33 PM
Shifter question for Barton and Hurst for 2013 5.0 Mustang_5.0 2011-2014 Mustang GT 15 09-09-2012 07:20 PM
Barton 2 Post Bracket vs Standard Barton Bracket SilverBullet12 2011-2014 Mustang GT 8 08-23-2012 09:43 AM
Barton shifter question mmike87 2011-2014 Mustang GT 2 07-16-2012 08:49 PM
11:27 AM
