Clunking Sound When Pushing Clutch In - Mustang Evolution
Old 06-17-2015, 11:28 AM   #1
Kustumb's Avatar
Hey guys,
Not sure if it's the car or I drive like ****.
Sometimes when I'm driving slow and I push the clutch in the car will make a big clunking noise.
Sounds like the driveshaft but I'm not 100%.
Anyone else experiencing this? Doesn't happen every time but when it does it sounds like I'm driving a $5,000 shot box.
2014 gt manual only mod is hurst shifter.
Kustumb is offline   Reply With Quote
Old 06-17-2015, 12:59 PM   #2
Psmith129's Avatar
It's fine, mine makes the same noise .sometimes we all have to remind ourselves that we're driving mustangs and not maybachs haha.It's either the driveshaft or the clutch disengaging . I'm beginning to accept that these cars are just not that quiet when it comes to the driveshafts , clutch, and sometimes suspension .
Psmith129 is offline   Reply With Quote
Old 06-18-2015, 09:57 AM   #3
Eric5oh's Avatar
Originally Posted by Kustumb View Post
Hey guys,
Yeah man I think they all do this lol sometimes if I release the clutch taking off but have to stop real quick and clutch in fast it will clunk
2013 Sterling Grey GT/Brembo package/SR Performance lowering springs/J&M adjustable panhard bar/Roush axle back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 06-21-2015, 07:55 AM   #4
K2Steeda's Avatar
My 02 Gt did it, my 09 Gt did it and my 14 Gt does it.
K2Steeda
2014 GT 5.0 Brembo's and 3.73's. FRPP Shifter, Steeda Intake Bama V2 Tune, Accufab 84.5 TB, Borla S-Type, Lethal Over Axel, JBA X, DSS Shaft, Steeda Panhard, Steeda LCA, Koni Streets, K Springs, GT500 Mounts.
2004 Maxima SE Daily Driver
K2Steeda is offline   Reply With Quote
Old 06-21-2015, 01:09 PM   #5
olerodder's Avatar
Region: Oregon
After replacing the LCA's, UCA, lowering it, putting in the Whiteline trans spacer............still did it. I then replace the carrier bushing with the BMR busing and changed to a 1 piece drive line..............no more clunking............solved!
Old 06-22-2015, 07:34 AM   #6
Hodor's Avatar
I've only had my "new to me" Mustang for about a month now. After buying it, I heard the same sporadic noises sometimes when pushing the clutch in, shifting, etc. Came on here and discovered that it was normal, which made me feel better. Hope you feel better now too
2012 GT Premium, Brembo Package, M6
VMP Gen II S/C & Tune, GT500 Axle-Backs/Spoiler/Strut Mounts
Steeda Sports/Shocks/Struts, J&M PHB, GT/CS Chin, MMD Fog Deletes
Hodor is offline   Reply With Quote
Old 06-22-2015, 12:11 PM   #7
Byock's Avatar
Region: Utah
I believe it's the 2 piece drive shaft. Mine does it as well.
Byock is offline   Reply With Quote
Old 06-22-2015, 12:48 PM   #8
Eric5oh's Avatar
It's the slack in the driveline caused by the two piece drive shaft.
Old 06-22-2015, 09:28 PM   #9
ResilientMidget's Avatar
Try pushing the clutch in when the car is not running and see if it makes the same noise. Mine makes a strange noise too.
2014 GT Premium. Cobra Jet Intake with monoblade throttle body and FRPP CAI. Ford Racing Sport axle backs. Pypes off road H pipe. Numerous appearance mods, it was a plain blue Mustang when I bought it.
ResilientMidget is offline   Reply With Quote
Old 06-22-2015, 09:41 PM   #10
olerodder's Avatar
Region: Oregon
If you are all tired of listening to the clunking of the driveshaft sliding in and out and the center bearing swinging back and forth, just ditch the 2 piece and go with what should have been put in the Mustang..............a 1 piece aluminum driveshaft.
When you replace the UCA you should do yourself a favor and either replace the carrier bushing with a GT500 bushing or the BMR urethane bushing.
Old 06-22-2015, 10:43 PM   #11
R.R.STANG's Avatar
I also had that problem but seems to occur less now that I installed a McLeod Braided Clutch Line. Do you guys also hear the gear changes in the trans? Mines pretty loud sometimes.. like a click/clank sound.
2013 Premium GT with Leather Recaros.
Performance mods: GT500 quadtip mufflers with resonator deletes.
Exterior Mods: Roush front, side and rear splitters. GT/CS rear wing. GT500 rear diffuser. GT500 Replica Wheels in gloss black 19 inch.
R.R.STANG is offline   Reply With Quote
Old 06-22-2015, 10:51 PM   #12
olerodder's Avatar
Region: Oregon
I don't have a braided clutch line, but do have a separate reservoir for the clutch rather than use the brake reservoir for both. The clutch feels different than it did before.
My trans is quite, but the rearend whines quite loudly between 2000/3000rpm. Had a mechanic drive with me last week and he wants to check in on the rack and is not sure if it's the transmission or rearend. They just replaced a pinion seal that started leaking at 7800 miles.
Just need to get all of the factory bugs out of the way so I can go play.
Rattling/Clunking Sound While Idle aw85 Pre-2005 V6 Mustang 0 04-09-2015 12:31 PM
Clunking sound after spring instal Mattjohnson 2011-2014 V6 Mustang 13 04-16-2014 11:22 AM
Transmission clunking sound robin_gt 1996-2004 Mustang GT 5 02-12-2014 06:23 PM
Clunking sound coming from rear?? ricklmesa Pre-2005 V6 Mustang 6 11-14-2006 09:36 PM
Pushing the engine too hard? Seph Pre-2005 V6 Mustang 25 01-14-2004 08:20 PM
09:12 AM
