What's my gear ratio? - Mustang Evolution
Old 06-21-2015, 07:06 PM   #1
nicholasmadill's Avatar
I bought a 2011 5.0 used a month ago. I had a 2011 3.7 for about a year, and it had the 3.31 ratio. The shift points on each car are at different speeds/rpm (I.e. The v6 would be at 2k rpm going 35mph in 4th, but the v8 will be at about 2k rpm going 35rpm in 5th )
Wondering if the v8 has the same ratio, I know stock is the 3.31, but this car has every available option, other than the glass roof, so I could see it might have had the upgraded gear ratio from factory too...
Anyway to figure it out or would I have to take it to a mechanic?
Sent from my iPhone using Mu
nicholasmadill is offline   Reply With Quote
Old 06-21-2015, 07:18 PM   #2
Eric5oh's Avatar
Go under your car and there's a sticker on your diff. If it's not there move the car forward or back slightly and it will be there
2013 Sterling Grey GT/Brembo package/SR Performance lowering springs/J&M adjustable panhard bar/Roush axle back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 06-21-2015, 07:30 PM   #3
oxford5pointoh's Avatar
You can also put your vin into a decoder in fords website and it will show you the window sticker. If it doesn't mention anything about the gear ratio then it's 3.31 for a manual. If it's got 3.55's or 3.73's from the factory the window sticker will notate that.
IG @Oxford5pointoh
Old 06-21-2015, 07:35 PM   #4
Okay thanks guys!
Old 06-21-2015, 07:55 PM   #5
Diehard's Avatar
It's not just the transmission gears and the rear end gear ratios that determine the RPM shift points. Aside from the power input difference...
The cars computer relies on several sensors to decide when and how to shift.
1. Input shaft speed sensor - Engine speed on the transmission side of the torque converter
2. Output shaft speed sensor - Road speed
3. Throttle position - How far the accelerator is pressed
4. MAP sensor - Engine intake vacuum, which is a function of throttle position and engine load.
5. Temperature - Shift firmness varies based on transmission temperature to account for the fluid's properties over the wide range of operating temperatures.
So when you find out the gear ratios, it more than likely won't correlate, due to other variables.
Old 06-21-2015, 08:16 PM   #6
Diehard's Avatar
I believe the auto 2011 GT only came with 3.15 gears. The manual came with 3.31 standard and 3.55 and 3.73 as options.
Here's your trans gears...
6-speed automatic gear ratios(believe the V6 and the V8 are the same.)
1st 4.17
2nd 2.34
3rd 1.52
4th 1.14
5th 0.87
6th 0.69
Final drive 3.15:1
Old 06-22-2015, 10:12 AM   #7
Strange Mud's Avatar
is yours stick or auto (if every option is true never mind) No one yet mentioned on the MT-82's the V6/V8 have different gears inside them.
nice upgrade btw
Old 06-22-2015, 10:44 AM   #8
Diehard's Avatar
OP was comparing shift points. I think it's safe to assume auto.
Old 06-22-2015, 10:46 AM   #9
Tire size can also affect what rpm you are at, at a given speed. Have you compared tire sizes as well?
Old 06-22-2015, 11:04 AM   #10
2011 v6 manual trans, 255/45/18r
2011 v8 manual trans has 19' rim I believe it's 235/45. May be 245 tho..
Old 06-22-2015, 11:16 AM   #11
Diehard's Avatar
I give up!
Old 06-22-2015, 11:16 AM   #12
Region: New Mexico
Gear ratio is on the door panel on my 2007 GT. Just realized you were talking about modified gear ratio. OOPs.
rogcat1 is offline   Reply With Quote
Old 06-22-2015, 11:20 AM   #13
jack it up, put it in neutral, spin the tires compare tire revs to driveshaft revs do math
Old 06-22-2015, 01:29 PM   #14
Don't see it on my door sticker, I'll check the window sticker later this evening Click image for larger version
Name:	ImageUploadedByMustang Evolution1435001320.939012.jpg
ID:	185540Click image for larger version
Name:	ImageUploadedByMustang Evolution1435001347.323137.jpg
Old 06-22-2015, 01:47 PM   #15
KryptonKnight's Avatar
Yeah, what Strange Mud said. The gear ratio is how many revolutions the rear wheels make compared to one revolution of the drive shaft. Put the ride up on blocks/jack stands. Put a piece of tape on the rear section of the drive shaft to use as a reference mark. Put it in neutral and rotate a rear wheel and watch until the drive shaft make one complete revolution. The number of drive shaft revolutions : one is your gear ratio. A .333 to 1 ratio means the rear wheel revolves 3 1/3 times for each engine revolution. (Power) In high gear one revolution of the rear wheels equals one revolution of the engine (Speed) and in over drive one revolution of the rear wheels equals 3/4 engine revolution thus (Economy) saving gas. My 2006 has the ratio stamped on the differential housing.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Old 06-22-2015, 02:37 PM   #16
ddtmoto's Avatar
Region: Utah
Open drivers door. Look at tag, find axle code. Google the two letters for Ford axle ratios. Bingo...someone will say bit the previous owner may changed it. Well, that would be a bummer....
ddtmoto is offline   Reply With Quote
Old 06-22-2015, 03:08 PM   #17
Diehard's Avatar
Drive shaft turns 3.31 revs to the wheels one rev = 3.31:1 gear ratio.
Old 06-22-2015, 03:14 PM   #18
Diehard's Avatar
Don't see it on my door sticker, I'll check the window sticker later this evening Attachment 185540Attachment 185541
The sticker you posted says axle code BB which represents 3.73 ratio
That's why you're at a high or higher RPM in 5th gear then you would typically expect to be with a lower gear ratio.
Old 06-22-2015, 04:18 PM   #19
Oh nice so I don't gotta think about changing the gears 😏
Old 06-22-2015, 04:27 PM   #20
Yeah I found the window sticker when I got home, it verified the 3.73 upgrade gear upgrade for $500
Rear gear ratio? 86gt 1979-1995 Mustang GT 5 05-10-2011 10:00 PM
Gear ratio? Joshfelder 2005-2010 Mustang GT 9 03-14-2011 08:03 AM
Tranny gone did use the 2.3 trans on my v8 n likd the gear ratio but now wat to do? Justbust1n 1979-1995 Mustang GT 18 02-26-2011 08:07 PM
Rear Gear Ratio natestang22 Pre-2005 V6 Mustang 2 07-20-2007 11:31 AM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 07:19 PM
08:44 AM
