Took 13 5.0 for diagnosis of engine tick. Here's the results - Mustang Evolution
Old 06-25-2015, 09:53 PM   #1
Jvibe92's Avatar
Is this a valid response or complete dealership BS. He then went to say that stock ones do it too, well then how do you blame it on off-road pipes -__-Click image for larger version
Name:	ImageUploadedByMustang Evolution1435290809.587643.jpg
Jvibe92 is offline   Reply With Quote
Old 06-25-2015, 09:55 PM   #2
It's BS.
Old 06-25-2015, 10:06 PM   #3
Rapinator126's Avatar
That statement is verry true.
However is it the tick that you have in your case Idk.
Old 06-25-2015, 10:56 PM   #4
Jvibe92's Avatar
Just incase you dont want to read what he wrote
"Could not verify any abnormal concern/noise with engine. Was able to localize ticking noise to after market exhaust. Altering factory exhaust can cause different scavenging effects of gasses leaving the cylinder. Therefore causing abnormal tick at certain RPMs. No problem found at this time."
Old 06-25-2015, 11:24 PM   #5
Mlp07's Avatar
Did you recently changed the oil? If you did, it will go after driving it a couple of miles
Mlp07 is offline   Reply With Quote
Old 06-26-2015, 12:57 AM   #6
Jvibe92's Avatar
I changed the oil about 800 miles ago. Why would a oil change cause pronounced ticking?
Old 06-26-2015, 01:25 AM   #7
Mlp07's Avatar
A lot of ppl have complained about the ticking. Most get them get them when they change the oil on the car. Some people have had their whole engines replaced, get a new engine block, or some dealers would say it's normal. Also some ticks are caused by the a/c ( there's a tbs on this). When I changed the oil on my car, I started to hear some ticking. Later after some 700-900 miles the ticking has disappeared, but not completely. When I turn off the car, let it off for Around 2 minutes and turn it back on. I can hear at least 2 ticks then disappears.
Old 06-26-2015, 07:18 AM   #8
k1DBLITZ's Avatar
Do all of you guys with the ticking have aftermarket x-pipes?
I've heard this same ticking on my car from time to time, but I always chalked it up to the x-pipe as it didn't seem to start happening till I tightened up the bolts on my exhaust clamps. (see here: Ghost Knock)
I just assumed the noise was caused by something expanding under heat.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 06-26-2015, 08:08 AM   #9
zinc03svt's Avatar
Offroad x pipe here no tick. No bar-b-que tick to clarify. I know what exhaust pulses sound like running catless.
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 06-26-2015, 08:08 AM   #10
K2Steeda's Avatar
The x pipe has nothing to do with the tick. I just changed my oil last month and developed the tick. Mine was ticking when the AC is off, however when AC turned on, NO TICK at all. Weird. Took it to the dealer and they replaced my AC Compressor and new belt. Guess what, still ticks. Just not as much. I'm hoping that as I put more miles on this oil it will go away. Car seems to be running strong and still pulls hard. Oil was Royal Purple 5-20. Might throw a ZDDP add in as some said it has helped. I don't know. I've read just about every thread on every forum about the tick. Ford had the tech that did my fix turn off cyl 1 and 4 and listen for Tick, said it could be something with thrust bearing. Tech said tick was still present with cyl 1 and 4 off so that ruled out the thrust bearing issue per Ford. I was there during the test cause the Tech is one of my good friends. He had my car hooked up to VCM2. Pretty awesome device. Good luck, hope your tick goes away
K2Steeda
2014 GT 5.0 Brembo's and 3.73's. FRPP Shifter, Steeda Intake Bama V2 Tune, Accufab 84.5 TB, Borla S-Type, Lethal Over Axel, JBA X, DSS Shaft, Steeda Panhard, Steeda LCA, Koni Streets, K Springs, GT500 Mounts.
2004 Maxima SE Daily Driver
K2Steeda is offline   Reply With Quote
Old 06-26-2015, 08:12 AM   #11
zinc03svt's Avatar
K2, look into HyperLube product. It uses KetJenLube 135 (research that) which is supposedly much more effective than the older zinc formula's. Been running it for past two oil changes. Motor is quieter than a mouse fart. fyi
Old 06-26-2015, 08:37 AM   #12
Mlp07's Avatar
Did they performed the tsb 12-8-14? If they did they were suppose to put a new engine front cover, a/c compressor drive belt idler pulley and some other things.
Old 06-26-2015, 08:46 AM   #13
K2Steeda's Avatar
They did not put the front cover and idler pulley on mine. Just new compressor and belt. Dealer said I already had updated front cover per my VIN. Actually I did put the hyperlube in a few nights ago but haven't driven the car much the last few days to see if it made a difference. Will check it out later.
K2Steeda
Old 06-26-2015, 09:00 AM   #14
DWoody's Avatar
Originally Posted by Jvibe92 View Post
Is this a valid response or complete dealership BS. He then went to say that stock ones do it too, well then how do you blame it on off-road pipes -__-Attachment 185826
You're in Houston? What dealership did you take it to? I'd stay clear of AutoNation Ford Gulf Freeway at all costs. I bought my car there and I've had my car repaired there and have had nothing but a miserable experience all the way around. Hopefully I don't have to take my car back to them to get the oil changed to keep my warranty...
DWoody is offline   Reply With Quote
Old 06-26-2015, 09:09 AM   #15
Mlp07's Avatar
Mine would make some ticks noise when the a/c would be on. I search in every forum and I saw one that they did the tsb on a 13 gt. The guy confirmed the noise was completely gone when they did the tsb work. The thing is that that tsb is suppose to be for the 11-12 models. You might want to look into that, if yours still is a 13-14. I told the dealership about it and they didn't do anything, so I think I might go to a different one.
Old 06-26-2015, 09:26 AM   #16
doyouevenforum
Guest
Posts: n/a
Mine is making this strange tick like every 5-10 seconds on light throttle where it sounds like an exhaust leak almost then stops. Sounds like it's coming around the x pipe area. Gonna check it out this weekend. Just started doing it and x pipe is welded in.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-26-2015, 11:45 AM   #17
REG
Tick
My tick is an exhaust leak at the converter to h pipe which ticks like made then goes away in a minute. I've often thought of replacing the clamps and h pipe with x pipe abut not sue if x pipe does anything.
Had an oil change and no change in tick. Once the thing heats up enough it goes away.
REG is offline   Reply With Quote
Old 06-27-2015, 05:37 PM   #18
Jon3.7's Avatar
You don't need to take it to the dealer to keep warranty.
Keep reciepts of the oil and filter in your records.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-27-2015, 10:06 PM   #19
HKBlue50's Avatar
I agree with DWoody on Autonation. Depending on the side of town I would try McRee Ford further south. Autonation guys gave me a ton of grief over my Barton shifter when I took it in for some transmission noise that was not normal. I do my own oil and keep track of it with receipts and mileage on a spreadsheet. Takes me about 30 minutes on a weekend to do the oil and filter.
HKBlue50 is offline   Reply With Quote
Old 06-27-2015, 10:54 PM   #20
Devil Strider's Avatar
I need to start doing this myself. I'm at 7k miles and had one oil change at about 6k because I was moving from Oklahoma to Colorado.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
New diagnosis Whitelightning 2011-2014 V6 Mustang 4 10-28-2013 01:06 PM
who on here is living with engine tick Mustangman705 1979-1995 Mustang GT 5 10-01-2013 12:55 PM
TICK TICK TICK Mustangman705 1996-2004 Mustang GT 13 09-21-2013 06:30 AM
Diagnosis help! Tranny/PATS alarm problems Pewter04 1996-2004 Mustang GT 1 03-15-2009 02:08 AM
diagnosis Ken The Bar 20 06-17-2004 09:13 PM
10:53 AM
