Mustang won't go into gear - Mustang Evolution
Old 06-28-2015, 05:49 PM   #1
Redonblackpony's Avatar
Any advice or thoughts on why my car will not go into gear? With the motor running it will not go into gear. When the motor is off, the cargoes in the gear in the clutch works perfect. I'm currently stranded and so any advice would be great
Redonblackpony is offline   Reply With Quote
Old 06-28-2015, 07:12 PM   #2
Here's more info...
I put the clutch pedal in and it went to the floor. After that I could not get it into any gear.
I'm locked out and it grinds a lot
Old 06-28-2015, 08:11 PM   #3
Noodles76's Avatar
Idk worn out clutch maybe. Sounds like it needs to get towed to a reputable shop.
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 06-28-2015, 08:57 PM   #4
Robostang's Avatar
Sounds like a hydraulic leak somewhere in the clutch line or one of the cylinders. Time for a tow to the shop.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 06-28-2015, 08:57 PM   #5
Compstall's Avatar
Slave cylinder. Covered under warranty for 50k
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-28-2015, 09:17 PM   #6
I had it towed home it's in my garage.
I'm thinking it's the clutch or slave cylinder.
I'm just glad that I got at home. I was 1.5 hours from my house. It's not my daily driver so I don't have to worry about getting it into the shop right away.
I checked the price of some different clutch packages. Not super expensive, but can anybody tell me the cost of the labor?
Old 06-28-2015, 09:33 PM   #7
Change it yourself. It's not a bad job. But to change a master/slave cylinder usually takes 1.5-2 hours.
litfuse is offline   Reply With Quote
Old 06-28-2015, 09:59 PM   #8
Cool! I didn't know if it was too advanced. I've done all the work on my car myself.
Old 06-28-2015, 10:38 PM   #9
Compstall's Avatar
Gotta pull trans
- Brent
Old 06-28-2015, 10:42 PM   #10
I think I can do that
Old 06-29-2015, 02:00 PM   #11
Find out what the problem is before pulling trans
ALLYDRIVER1 is offline   Reply With Quote
Old 06-29-2015, 06:12 PM   #12
Absolutely!
Actually I have a Mustang mechanic that will diagnose the problem and install a new clutch and slave cylinder for $400. I would be more than willing to pay $400 for that much work!
Old 06-29-2015, 09:11 PM   #13
bout 2 hrs to r/r clutch
Old 06-30-2015, 09:40 PM   #14
Compstall's Avatar
BS
- Brent
Old 06-30-2015, 11:10 PM   #15
I agree! 4-6 hour minimum
Old 07-01-2015, 12:16 AM   #16
I just changed one on 96 v6 in a little over two hrs.using air tools and 55 years exp also am master tect retired ford flat rate book says 3.8 hrs.If u can't beat flatrate you will starve to death working on cars
Old 07-01-2015, 12:20 AM   #17
Compstall's Avatar
Not everyone is in super galactic oneness with a transmission. And I'd bet money it took longer than two hours from the time you first step foot in the garage with the car sitting there, jacking, disassembly, running off to the parts store once or twice, reassembly, etc up to the time you had the tools put away, car on the ground and driving it. Go check the batteries in your 55 year old timer, I think it died.
- Brent
Old 07-01-2015, 12:30 AM   #18
#1 car was in shop on my lift
#2 knew what tools needed and on cart
# time to turn flywheel not included as not related to r&r labor
#4 tools left on cart for next repair
#5 be prepared,only trip to dealership was to turn flywheel 2 or 3 trips to partshouse says amature
#6 knew another guy from washington, he was slow also
goodnight trolls
Old 07-01-2015, 09:30 PM   #19
DallasStang77's Avatar
Hey comp respect the elders. If allmydrivers says his 80yo *** can do it maybe he can. Never judge a book by its wrinkly covers no matter how frayed the edges... or stained... or even if it's written in some weird 1920/30's English that sounds kinda... old.
Old 07-01-2015, 09:59 PM   #20
thanks for the kind words dallasstang,I'm only 69.been working on cars since 16 when bought a '56 crown vic with a tbird 312 with 2 4 bbl carbs. and a four speed changed a trans every payday but had lots of winnings and fun
Won't go into gear when upshifting @ high rpm ModularMayhem General Mustang Discussion 8 05-29-2015 03:23 PM
HELP PLEASE!!! 2000 Mustang GT won't go into gear with car on!?! WICKED STANG 83 1996-2004 Mustang GT 22 10-18-2012 05:24 PM
91 gt won't go into gear robert3188 1979-1995 Mustang GT 4 08-14-2012 05:35 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
Won't Shift Into Gear-Need Help! Mstngsalli87 Pre-2005 V6 Mustang 1 10-24-2008 01:06 PM
03:10 PM
