Is something wrong with my engine ? - Mustang Evolution
Old 07-01-2015, 04:31 PM   #1
I have a 2012 GT 5.0 with 26500 miles between oil changes I have to add 1/4 of oil. It is this correct or is there something wrong in the engine. (no leaking oil and there are no signs of oil in the water of the engine.
almartinezguerr is offline   Reply With Quote
Old 07-01-2015, 04:42 PM   #2
1 quart not bad,how do u drive it.
ALLYDRIVER1 is offline   Reply With Quote
Old 07-01-2015, 04:44 PM   #3
oxford5pointoh's Avatar
It's just eating it through the pcv. Get an air/oil separator and you will catch it before it goes back into the intake. My catch can catches about that much oil in an oil change. I periodically drain it back into the motor so the level stays correct
IG @Oxford5pointoh
---------- Post added at 10:44 PM ---------- Previous post was at 10:44 PM ----------
Not 1 quart. 1/4 quart
IG @Oxford5pointoh
Old 07-01-2015, 04:57 PM   #4
Robostang's Avatar
26500 miles between oil changes?
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-01-2015, 05:10 PM   #5
blackie's Avatar
How much is 1/4 of oil? if 1/4th quart, not bad. My 14 is at 13k had 2 oil changes,at 5k and 10k. Never had to add a drop of oil
between changes.
blackie is offline   Reply With Quote
Old 07-01-2015, 05:14 PM   #6
Strange Mud's Avatar
This, and how much oil do you add?
Old 07-01-2015, 05:37 PM   #7
He is saying he has 26k on it and between oil changes its a 1/4 quart low if I read it correctly
IG @Oxford5pointoh
Old 07-01-2015, 05:49 PM   #8
Robostang's Avatar
IG @Oxford5pointoh
Ah. That elusive missing period!!!
Old 07-01-2015, 06:11 PM   #9
zinc03svt's Avatar
A 1/4 quart every 3-5000 miles is acceptable. No worries Mate.
zinc03svt is offline   Reply With Quote
Old 07-01-2015, 06:23 PM   #10
Thanks for the reply, is that common for this engine?
Anybody else have this issue?
Thanks in advanced.
Old 07-01-2015, 07:03 PM   #11
not a issue
Old 07-01-2015, 07:13 PM   #12
Sorry about the misspell, I have to add a quart of oil between oil changes, so every 5k miles I add a quart of oil.
Old 07-01-2015, 08:23 PM   #13
thats what I read anyway al,dont know where the others came up with their ideas...dont worry about a quart on 5K. oils cheap compared to a re-ring job..i usually change mine when it uses a quart,good sign oil is breaking down and needs to go away..
Old 07-01-2015, 08:33 PM   #14
thats what I read anyway al,dont know where the others came up with their ideas...dont worry about a quart on 5. oils cheao compared to a rering job..i usually change mine when it uses a quart,good sign oil is breaking down and needs to go away..
A coyote takes 8 quarts FYI
IG @Oxford5pointoh
Old 07-01-2015, 09:16 PM   #15
as
AS I SAID A QUART OF OIL USED IN 5K IS NOTHING TO WORRY ABOUT,GEEES
Old 07-01-2015, 09:31 PM   #16
Talking duh
IG @Oxford5pointoh
Old 07-02-2015, 11:53 PM   #17
As long as your tail pipes don't have black soot on them your not really burning enough to worry,pull a plug and look for oil, most likely pcv,oil and vapor could be it.
Sent from my SM-T700 using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 07-04-2015, 06:18 PM   #18
Billgluckman's Avatar
idk how much a 1/4 of oil is but..
IG @Oxford5pointoh
IG @Oxford5pointoh
I slapped on a jlt oil separator about a month ago. After less than 2k miles it had already caught a good bit of oil.
Billgluckman is offline   Reply With Quote
Old 07-05-2015, 09:21 PM   #19
WhiteCali5oh's Avatar
Region: West Virgina
The rear of my car is covered in soot lol.
WhiteCali5oh is offline   Reply With Quote
Old 07-05-2015, 09:59 PM   #20
Catless life 😎
IG @Oxford5pointoh
Old 07-05-2015, 10:20 PM   #21
Catless life 😎
IG @Oxford5pointoh
Damn right lol. Never happened until I went that route.
Old 07-06-2015, 02:51 AM   #22
mark_ash0426's Avatar
Im lucky my car is black i cant really see it lmao
mark_ash0426 is offline   Reply With Quote
something is wrong with my rear end tim11 Pre-2005 V6 Mustang 3 07-02-2015 11:20 AM
I was wrong - Really Wrong- Yep I was ronnie948 AmericanMuscle 4 03-09-2013 02:51 PM
Something is wrong choppa5307 1979-1995 Mustang GT 2 05-13-2012 07:09 AM
There is something very wrong about this site n8r The Bar 28 05-07-2006 01:36 PM
Crazy Vid, wrong place wrong time Black95GT The Bar 19 06-26-2004 03:38 PM
04:47 AM
