Removal of the stock h pipe. - Mustang Evolution
Old 07-05-2015, 03:54 PM   #1
Jreeves30's Avatar
I'm having a little trouble removing the stock h pipe from the manifolds. I can get on the bolts without any issue however, I cannot break them loose. I broke my 3/8ths ratchet earlier. Going to try a breaker bar in a Little while. I'm far from weak but how much force did y'all have to put on the bolts to break them loose. Was the car warm at all? Mine has been sitting on jack stands for a day so it is cold. Any advice would help.
A couple more months and my license plate will say 1fstcpa!!!!
I'm only and accountant to feed my car parts addiction.
Jreeves30 is offline   Reply With Quote
Old 07-05-2015, 07:37 PM   #2
The_Chech's Avatar
Mine took a lot of effort and a huge breaker bar. They're a huuuge Pain!
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 07-05-2015, 08:06 PM   #3
mustanggt2013's Avatar
Broke mine with a 3/8 ratchet and one hand. Came right off. But then again I did my only after being 6 months old.
Sent from my iPad using Tapatalk
mustanggt2013 is offline   Reply With Quote
Old 07-05-2015, 08:14 PM   #4
Jreeves30's Avatar
Mine has 40k on it and I live in Florida close to the beach. I'm assuming the salt in the air has an affect on the bolt as well.
Old 07-05-2015, 08:16 PM   #5
O ya absolutely. I live about 30 min from the coast and the salt in the air is hornblende on metals.
Old 07-05-2015, 09:16 PM   #6
You need to make sure you are soaking the bolts with PB blaster and using a six point socket and not a twelve. Also make sure you are using 3/8 extensions instead of 1/2 inch do you don't have to use a swivel and have straight excess to the bolt.
litfuse is offline   Reply With Quote
Old 07-08-2015, 07:45 AM   #7
Jreeves30's Avatar
Ok so got three out of the four out. Took a breaker bar and a pipe extension. Going for the passenger upper tonight. Wish me luck.Click image for larger version
Name:	ImageUploadedByMustang Evolution1436359463.371311.jpg
ID:	186692Click image for larger version
Name:	ImageUploadedByMustang Evolution1436359487.004515.jpg
ID:	186693Click image for larger version
Name:	ImageUploadedByMustang Evolution1436359508.070689.jpg
Old 07-08-2015, 08:03 AM   #8
dj_james123's Avatar
Fun times I remember when I did mine lol. I broke a ratchet also. All 4 bolts were a pain, its like they welded them in there.
Sent from my HUAWEI H891L using Mustang Evolution mobile app
dj_james123 is offline   Reply With Quote
Old 07-08-2015, 12:41 PM   #9
REG
Are you replacing with an off road pipe?
I did mid length headers and broke one of the studs on the cat.
I used 1/2 bb and 18" extension
REG is offline   Reply With Quote
Old 07-08-2015, 12:43 PM   #10
REG
pull the battery and box on the pass side, you'll have straight access to the last one, if you haven't allready.
Old 07-08-2015, 01:54 PM   #11
Jreeves30's Avatar
Hey reg. did you still have to use a swivel if you pulled the battery box?
Old 07-08-2015, 06:18 PM   #12
REG
Last nut
If I remember correctly to get aa good seat on it.that is the one that broke on me.
I got half a turn and snap everything hit the floor soak the crap outof it
Old 07-08-2015, 06:20 PM   #13
REG
Nut
Sorry I wasn't clear, yes I used a six point and a universal joint
Old 07-08-2015, 07:30 PM   #14
You do not have to use a swivel if you use 3/8 extensions instead of 1/2 inch extensions. It will fit and clear the battery box to have perfect access to the pita bolt on the passenger side. Trust me, I just did this two weeks ago.
Old 07-08-2015, 08:48 PM   #15
Jreeves30's Avatar
It's done!!!! Thank god. Appreciate the advice. I'll have a video tomorrow. My buddy took one but it was too large to send. Thanks again everyone.
Old 07-08-2015, 08:51 PM   #16
Good deal, I'm sure you'll like it. Big change
Old 07-11-2015, 10:34 PM   #17
Jreeves30's Avatar
Finally got a video! I love the sound. http://youtu.be/tNyjmjihBmQ
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 09:35 AM
Fuel Feed Pipe Removal '11+ 5.0 Jackal43x 2011-2014 Mustang GT 8 02-24-2013 06:56 PM
For stock H pipe(boss h pipe with side plates) Mustang_5.0 2011-2014 Mustang GT 8 08-20-2012 06:17 AM
Stock shift knob removal. tenfifteen 2011-2014 Mustang GT 10 05-23-2012 08:08 AM
Removal of 04 model Stock in-dash CD Player BlueThunder Mustang Audio & Video 7 10-31-2004 10:22 PM
01:40 PM
