Need upgrade suspension please help - Mustang Evolution
Old 07-06-2015, 12:37 PM   #1
Eric5oh's Avatar
2013 Gt Brembo pack. I'm lowered on SR springs. I want to get koni yellow or orange shocks and struts because obviously the OEM ones are wearing fast. I'm also confused as to why you need gt500 strut mounts as well as why people switch and get the older 05-09 shocks and struts. Thanks in advance sorry if this is a novice question but I need to know exactly what to get before starting.
2013 Sterling Grey GT/Brembo package/SR Performance lowering springs/J&M adjustable panhard bar/Roush axle back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 07-06-2015, 01:04 PM   #2
BLKBETTY13's Avatar
The GT500 mounts are more durable then the stock 11-14's. However only fit the 05-09 struts due to the shaft length. I'm running Strange struts up front "05-09" with GT500 mounts and have no problems.
BLKBETTY13 is offline   Reply With Quote
Old 07-06-2015, 01:33 PM   #3
Eric5oh's Avatar
So the 05-09 struts will be the same if not better than the 10-14?
Old 07-06-2015, 01:35 PM   #4
oxford5pointoh's Avatar
Performance is no different. It's just the length of the shaft at the top that is different. That's all. Don't get hung up on the fact that it's 05-09, it's also 11-14 GT500. So they used them on 2014 models, just not the GT.
IG @Oxford5pointoh
Old 07-06-2015, 01:45 PM   #5
2014oxstang's Avatar
What everyone here said. The GT500 strut mounts are beefier, which is exactly why I went with 05-09 Koni oranges all around in conjunction. I also have your same springs. It's a helluva combo and the total price can't be beat.
2014oxstang is offline   Reply With Quote
Old 07-06-2015, 01:55 PM   #6
rockhillgt's Avatar
I run the eibach sportlines and the koni yellows. love the combo I like how you can adjust it for mountain runs
rockhillgt is offline   Reply With Quote
Old 07-06-2015, 01:56 PM   #7
Eric5oh's Avatar
Okay so I should I get the 05-09 oranges all around plus 05-09 gt500 strut mounts
Old 07-06-2015, 02:54 PM   #8
I would, but that's just my opinion. For my needs, a daily that handles and hooks well, it suits me perfectly.
Old 07-06-2015, 05:19 PM   #9
Eric5oh's Avatar
I mean I want Konis I just don't know what to buy but seeing as you have the same springs as me and you daily drive it that's all I'm looking for
Old 07-06-2015, 08:21 PM   #10
Grimkreg's Avatar
I just installed my koni yellows with bmr lower and adjustable upper control arm with mounts, adjustable panhard bar and ebiach springs. Kept stock mounts easily and they are working just fine. The adjustable feature is really nice and playing with it you can get it set to what you like and what the car likes. I also upgraded my wheels and tires which made a big difference also, I couldn't stand the stock tires
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Grimkreg is offline   Reply With Quote
Old 07-07-2015, 12:24 PM   #11
Fabman's Avatar
Koni Yellows, Eibach Prokit and MM CC plates here.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 07-07-2015, 06:49 PM   #12
BlackBetty5.0's Avatar
[QUOTE=Eric5oh;2256322]Okay so I should I get the 05-09 oranges all around plus 05-09 gt500 strut mounts
That is what I did. I also have the SR springs along with BMR ADJ. UCA and mount, LCA and relo brackets and PHB. Another benefit for the GT500 mounts is that with a mild drop they can keep the camber in spec by pointing the arrows inward toward the engine. Just got my alignment today. Click image for larger version
Name:	ImageUploadedByMustang Evolution1436316495.023469.jpg
ID:	186676 this was before the toe was aligned.
BlackBetty5.0 is offline   Reply With Quote
Old 07-09-2015, 06:58 PM   #13
Good info here. Another benefit is that I feel like the oem strut mounts are junk. When I put on steeda cc plates and took off my oem mounts the bearing looked like it was encased in cheap plastic and actually separated easily on its own. I was more glad to have a better designed mount installed which further justified the cc plate purchase.
Sent from my SM-N900T using Mustang Evolution mobile app
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
Suspension gurus please help Crewchief15 2011-2014 Mustang GT 11 04-28-2014 05:12 AM
1996 Mustang GT upgrade suggestions!! please help! calebnaasko 1996-2004 Mustang GT 35 04-24-2013 07:28 AM
suspension upgrade for convertible nekronos Pre-2005 V6 Mustang 6 07-13-2008 01:52 PM
Brakes and Suspension Upgrade McGrail482 Pre-2005 V6 Mustang 116 05-09-2005 08:27 PM
Suspension upgrade... 98GreenStallion Pre-2005 V6 Mustang 37 11-21-2003 10:57 AM
06:08 AM
