Programming a new key - Mustang Evolution
Old 07-08-2015, 12:50 AM   #1
Noodles76's Avatar
Hey guys I just got an additional key off of eBay and was wondering if anyone knew how to program a new key. I have the original keys neither of which is a mykey. Any help is appreciated thank you.
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 07-08-2015, 02:50 AM   #2
bucko's Avatar
There's usually a procedure in the owners manual on how to do this. If you do not have a copy of your owners manual, then it's easy to get a PDF copy: type your year, make, model, and the words "owners manual". A site (or several) will pop up pointing you to a location to download a free copy from Ford's web site.
I took a guess that you owned a 2013, and this site came up:
http://www.motor-talk.de/forum/aktio...hmentId=731340
It mentions in the "Security chapter on how to program one:
Programming a Spare Key
Note: A maximum of eight coded keys can be programmed to your
vehicle. Only four of these eight can be integrated keyhead transmitters.
You can program your own integrated keyhead transmitters or standard
SecuriLock coded keys to your vehicle. This procedure will program both
the engine immobilizer key code and the remote entry portion of the
remote control to your vehicle.
Only use integrated keyhead transmitters or standard SecuriLock keys.
You must have two previously programmed coded keys and the new
unprogrammed key readily accessible. See your authorized dealer to have
the spare key programmed if two previously programmed coded keys are
not available.
Read and understand the entire procedure before you begin.
1. Insert the first previously programmed coded key into the ignition.
2. Turn the ignition from off to on. Keep the ignition on for at least three
seconds, but no more than 10 seconds.
3. Turn the ignition off and remove the first coded key from the ignition.
4. After three seconds but within 10 seconds of turning the ignition off,
insert the second previously coded key into the ignition.
5. Turn the ignition from off to on. Keep the ignition on for at least three
6. Turn the ignition off and remove the second previously programmed
7. After three seconds but within 20 seconds of turning the ignition off
and removing the previously programmed coded key, insert the new
unprogrammed key into the ignition.
8. Turn the ignition from off to on. Keep the ignition on for at least six
seconds.
9. Remove the newly programmed coded key from the ignition.
The key will start the vehicle’s engine and will operate the remote entry
system (if the new key is an integrated keyhead transmitter) if it has
been successfully programmed. The theft indicator light will illuminate
for three seconds and then go out to indicate successful programming.
If the key was not successfully programmed, the theft indicator light may
flash on and off. Wait 20 seconds and repeat Steps 1 through 8. Take
your vehicle to your authorized dealer to have the new key programmed
if you are still unsuccessful.
Wait 20 seconds and then repeat this procedure from Step 1 to program
an additional key.
Old 07-08-2015, 02:55 AM   #3
Noodles76's Avatar
Thanks I didn't think it would be in there. I appreciate the response!
Rollin' in my 5.0
Old 07-08-2015, 05:28 AM   #4
Noodles76's Avatar
Pain in the butt... No one will cut the key. Trying Ave hardware them maybe a locksmith.
Rollin' in my 5.0
Old 07-08-2015, 06:03 AM   #5
REG
Key
We were down to one key for my wife's Honda and I bit the bullet and went to Honda.
Even if you can find a Ford dealer that will cut it, there is no guarantee it will work.
Sorry, there are just too many horror stories out there about keys from ebay.
REG is offline   Reply With Quote
Old 07-08-2015, 06:20 AM   #6
shunc01's Avatar
Rollin' in my 5.0
Locksmith will be able to cut it for you.. I did mine for 5 bucks and sync it with your two Ford keys.
MPT TUNE, Borla S-Type, Airaid Cai, Ford racing X pipe, Mac ceramic shorty headers, 2010 GT500 rims, 35% tint, Sr Springs, J&M phb, camber bolts, blacked out side markers, front and taillights.
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 07-08-2015, 06:53 AM   #7
Noodles76's Avatar
I read all the reviews and everything looked good. I wanted a flip key as the regular keys get stuck in the net pockets in some of my shorts. I'll try a locksmith as soon as I finish at the Apple store.
Rollin' in my 5.0
Old 07-08-2015, 09:44 AM   #8
Noodles76's Avatar
Name:	ImageUploadedByMustang Evolution1436370189.312200.jpg
ID:	186698Click image for larger version
Name:	ImageUploadedByMustang Evolution1436370203.084393.jpg
Got a locksmith to cut it and I just got done programming it. Works like a charm. $38 not bad for a spare key
Old 07-09-2015, 02:39 AM   #9
Mlp07's Avatar
I still have mine, ordered it a month ago. NO ONE is able to do it (tried Walmart, Lowes, Home Depot). I called several locksmiths in my area, and they want to charge me between $60-$90. I think that's too much just to get a key cut! A lot of people have, had theirs cut for no more than $10
Mlp07 is offline   Reply With Quote
Old 07-09-2015, 03:35 AM   #10
Robostang's Avatar
Had mine cut at my local ACE hardware. Less than $10.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-09-2015, 03:47 AM   #11
Noodles76's Avatar
I stopped at a locksmith in Orlando and he cut the key for $3.00 a side. Good thing I was out there for the Apple store. Every where in Daytona was giving me a hard time.
Old 07-09-2015, 06:15 PM   #12
Mlp07's Avatar
Same here man, I don't know what's the big deal. I just want it cut, it's just it cutting any regular key. Supposedly they have a machine just made for "vehicle keys" not any machine can do it.
Old 07-10-2015, 12:04 PM   #13
Noodles76's Avatar
A lot of them want to program it or the machine cannot fit the key. Call the locksmiths in your area someone will cut it.
programming key remotes - changing unlock settings dpevoar 2005-2010 V6 Mustang 3 07-05-2013 10:05 AM
Programming an ignition key geepoons General Mustang Discussion 0 05-29-2013 12:00 AM
Ecu programming Thrasher13 1979-1995 Mustang GT 2 06-28-2012 10:20 PM
Programming connector 96mustangmaine 1996-2004 Mustang GT 2 03-31-2011 08:27 AM
Help with Programming class tealstangman The Bar 7 02-18-2005 12:25 PM
05:03 AM
