Brakes dragging when hot? - Mustang Evolution
Old 07-09-2015, 05:00 PM   #1
After the car has been heated up, brakes have been heated up (normal street driving) Im getting a squeaking noise from what sounds like the left from brakes.
-When it starts to squeak, I apply slight brake pressure and the squeak will go away for 8-10 seconds then come right back. The noise is usually only noticeable at 45+ mph and consistent at highway speeds.
-Pads are in fine condition and have plenty left. The brakes do not squeak in the slightest under normal driving conditions both front or back and are no where near the metal wear indicators. OEM Everything in the braking system, original clutch/brake fluid as well.
Car has 13k miles, GT M6 car. Any insight. Reason I was thinking they might have been dragging is because it doesn't do it when its cold and the fact that when I apply any brake pressure it instantly goes away.
slick3 is offline   Reply With Quote
Old 07-09-2015, 08:35 PM   #2
Psmith129's Avatar
Rotors could be glazed , I had the same problem and had to get them cut . Problem was fixed after that .
Psmith129 is offline   Reply With Quote
Front brake dragging escottcarp 1996-2004 Mustang GT 8 04-12-2014 10:44 PM
Brakes Dragging? sixpac 1996-2004 Mustang GT 2 12-28-2013 04:34 PM
Brakes are dragging on my 1997 Mustang asilentfire Pre-2005 V6 Mustang 3 05-06-2012 09:18 PM
dragging with auto? 5.slow At the Track 14 09-11-2011 10:20 AM
Car Dragging customsixstang Pre-2005 V6 Mustang 5 12-10-2007 09:11 AM
08:22 AM
