47# injectors and tune loud noises... - Mustang Evolution
Old 07-09-2015, 06:35 PM   #1
Dub9stang's Avatar
I installed my Ford racing 47# injectors and loaded my Lund 93 octane tune and started my car, I only let it run for about 30 seconds because of this god awful noise, like a LOUD tick. It ran smoothish, rpms went up and down a little but smoothed out over time. Any ideas before I contact my tuner? I'll post a video if needed
Dub9stang is offline   Reply With Quote
Old 07-09-2015, 07:04 PM   #2
Dub9stang's Avatar
Ran it a little more, Oil pressure normal, oil doesn't smell like fuel, no leaks, I slightly smell raw fuel in the garage but I did just swap them out yesterday so fuel did get out. Also runs smooth now. faulty injectors? Or do they just need to be dialed in more via my tuner?
Old 07-09-2015, 07:52 PM   #3
why did you install #47 injectors?
NoTop5.0 is offline   Reply With Quote
Old 07-09-2015, 08:26 PM   #4
hctr154's Avatar
Did you re-install the sound deadening foam blocks that fit around the injectors?
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 07-09-2015, 08:29 PM   #5
Dub9stang's Avatar
Yes I did.
And I installed the injectors for an e85 conversion tune, Lund just wants to get everything dialed in with pump gas then I'll switch over
Old 07-10-2015, 04:25 PM   #6
Dub9stang's Avatar
Update:
I pulled one electrical connector for the fuel injector at a time while running, The noise stayed consistent. I also used a stethoscope and the fuel injectors all make a mild clicking noise which seems normal. The ticking is coming from the intake manifold I can hear it most towards the front. As the RPMs increase so does the ticking. I am almost certain I didn't drop anything through the injector port. I even tried running the 47 injectors with the stock tune and still heard the tick. Just for kicks I am swapping the old injectors back in
Hheelllppp
Knocking and pinging. Weird noises? Joser714 Pre-2005 V6 Mustang 5 01-08-2014 02:53 PM
are loud pop noises coming from one tire in speedbumps normal ebgonzalez1 2011-2014 V6 Mustang 26 10-28-2012 10:51 AM
Anyone else have loud injectors? Yellow50 2011-2014 Mustang GT 0 06-02-2012 09:44 PM
Rear and or drive shaft noises Mean green 91 1979-1995 Mustang GT 9 04-07-2011 05:41 PM
Help: Loud gear noises JimMoser Pre-2005 V6 Mustang 12 06-29-2004 08:36 AM
04:43 AM
